Loginfailed's Stolen Idea Emporium (plus BS)
Discussion in '2nd Gen. Builds (2005-2015)' started by loginfailed, Nov 20, 2017.
  1. Feb 24, 2019 at 10:38 AM
    #581
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That truck going to be ready for Coffee and Cars next weekend?
    loginfailed[OP] likes this.
  2. Feb 24, 2019 at 11:11 AM
    #582
    loginfailed
    loginfailed [OP] Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Thanks, I hope you are right. The goal for today is just to get the primary pump online so I can continue to drive the truck. The secondary boost referenced pump I can set up next weekend.
    Can you think of any reason why I shouldn’t bypass the stock fuel pump resistor? Why not give the pump full voltage all the time? I wonder if they do that for less pump noise at idle or something.
    Wouldn’t be much work to try out your exhaust idea. Even better, I’d like to somehow integrate two cats into the @Roostfactor y-pipe (maybe by lengthening it some) and change the merge from a 3” out to a 2.5” out.
    Hope to have it running today. :fingerscrossed:
    Roostfactor likes this.
  3. Feb 24, 2019 at 11:23 AM
    #583
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Because unless it's rated for continuous duty at full voltage, it needs that resistor circuit. Or it'll burn up.
    loginfailed[OP] and Roostfactor like this.
  4. Feb 24, 2019 at 11:25 AM
    #584
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As for the exhaust, I'd stick with the easiest portion first. Add a flange on to the inlet of the muffler, and the other half of the flange have the reducer attached. dynafit needs more of what you want it will be easy to adapt then to that, as you lined out above.
  5. Feb 24, 2019 at 11:51 AM
    #585
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I have another idea I may try to quiet the exhaust more. URD header, JFR y-pipe, merge/flex/cat all 3" then an 18" long 3" inlet to dual 2.25" outlet muffler. This will mate to dual 18" 2.25" mufflers.
    The merge has to be there for the exhaust tuning effect but splitting the exhaust again after the merge theoretically will help to attenuate sound because it's easier to silence a smaller diameter exhaust. Since we will have 2 2.25" mufflers it should flow equal or better than the single 3" because csa of the two pipes combined is bigger than a single 3".
    Magnaflow also makes an offset style metal spun cat which may work well if youre wanting to seriously modify the y-pipe.
  6. Feb 24, 2019 at 11:56 AM
    #586
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    If you need more therapy and happen to make more gauge pods...
    Asking for a friend. :anonymous:
  7. Feb 24, 2019 at 12:27 PM
    #587
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup yup. As well as increase scavenging velocity.
  8. Feb 24, 2019 at 12:29 PM
    #588
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh all of the ideas for this exhaust playground. :D
  9. Feb 24, 2019 at 12:57 PM
    #589
    ThomasMore66
    Dallas/Fort Worth & Durango
    I still think JFR equal length y-pipe will improve sound. Should be equal pulse frequency I’d think.
  10. Feb 24, 2019 at 3:15 PM
    #590
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The right rear bracket has me baffled. Either my truck is different or they sent me the wrong bracket. Also the outboard mounting holes are a good 1/4” off from being able to put the bolts through the holes and successfully engage the holes in the frame @Cruiser Brothers
    No idea WTF they are talking about in the instructions with the right rear bracket. In the end I decided to modify the bracket and weld the damn thing onto the truck and drill new mounting holes in the bracket and the tank. Also had to elongate both of the outboard side holes.
    Maybe next time up that way, we can get underneath and do more brain storming.
  11. Feb 24, 2019 at 6:20 PM
    #591
    ThomasMore66
    Only bought LRA tanks for my 80. They’ve bolted in. Just looked back at my last invoice. Shouldn’t have...
    Roostfactor and loginfailed[OP] like this.
  12. Feb 24, 2019 at 9:45 PM
    #592
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Tank is mounted and hoses are all attached. All that’s left is to run the pump wiring to the engine bay and to hook the -8an line to the fuel rail.
    I ran out of 3/4 split loom. I ordered some more and it should be here tomorrow. So maybe I can get this thing running and check for leaks tomorrow evening.
  13. Feb 24, 2019 at 11:41 PM
    #593
    Roostfactor
    TX panhandle
    Of course I'm biased but I thinks so big time! Rasp is eliminated and overall sound is lower but it is tough to really quiet a 3" performance exhaust. Sound is also very subjective, when I was down in Houston I gave a few guys a ride and they all said my truck was almost too quiet....but I want it quieter. Drone is a whole other animal all its own and many factors come into play on what causes drone and at what frequency it occurs.
    I want to test more but have work to do....customers waiting.
  14. Feb 25, 2019 at 12:18 AM
    #594
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I might have to claim TE1#26 if you’re not sick of welding by then. Hurry up ;)
  15. Feb 25, 2019 at 5:42 AM
    #595
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I just want a y pipe that doesnt hit the frame. Lol
  16. Feb 25, 2019 at 6:41 AM
    #596
    rmepilot
    Rob
    Huntsville, AL
    My truck is very quiet, almost too quiet. However, the y-pipe/TRD CB was setup for the upcoming headers install. Zero rasp and zero drone, which is what I like.
    I can't wait for the final results. :thumbsup:
  17. Feb 25, 2019 at 12:05 PM
    #597
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  18. Feb 25, 2019 at 5:53 PM
    #598
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Working on it. Went outside tonight and got the undercarriage portion of the fuel line and pump wiring all routed, secured and ran up into the engine bay.
    Just need to figure out how to access the fuel rail input with a blower in the way. For now I might just tap in at the junction where the hard lines end. I need to figure out which of the lines is input and return. They go back behind the engine and its too dark to see at the moment.
    Flake Boost and ChadsPride like this.
  19. Feb 26, 2019 at 10:37 AM
    #599
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'll have to check with AEM to see what their specs are for that.
    Since I don't have a spare under the truck, there's plenty of room after the axle for add'l mufflers.
    Flake Boost likes this.
  20. Feb 26, 2019 at 2:57 PM
    #600
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Wish this damn damp weather would GTFO. Got things to mod!!!
    Flake Boost and loginfailed[OP] like this.
