Loginfailed's Stolen Idea Emporium (plus BS)
Discussion in '2nd Gen. Builds (2005-2015)' started by loginfailed, Nov 20, 2017.
  1. Feb 27, 2019 at 1:45 PM
    #621
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Is that so the resistor gives off the heat from the excess energy instead of the pump running full bore when not needed (possibly transferring heat into the fuel)?
  2. Feb 27, 2019 at 4:17 PM
    #622
    loginfailed
    loginfailed [OP] Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I got the pumps powered up and there’s a huge leak somewhere in the plumbing on top of the tank. I may have overtightened one of the PTFE fittings when I made up the hoses.
    That means the tank needs to come back out and I really won’t have time to mess with that until Saturday. Hopefully the clouds will open up and the rain will stop long enough to get some work done. If not, I might just leave it be until spring break.
    Looks like no C&C this time. :pout:
    Well it can’t be to save electricity since the resistor is eating the power that the pump would.
    Roostfactor and Stryker420 like this.
  3. Feb 27, 2019 at 5:38 PM
    #623
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Grrrrr. Blasted leaks.
    loginfailed[OP] likes this.
  4. Feb 28, 2019 at 3:46 AM
    #624
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Indeed. It’s fine, just forces me to take the tank back out.
    I want to re-route the fuel lines between the pump to the filter anyway. I also want to re-work those holes I enlarged a bit more, now that I have a fresh carbide burr. It will make the tank bolts a tad bit easier to line up.
  5. Mar 1, 2019 at 3:55 PM
    #625
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    It’s not raining this evening. Or at least it’s not supposed to until 10pm.
    I may try to get that fuel leak fixed tonight. If successful, I can make the C&C in the morning. It would be a good one to attend, since TTC is planning to make a showing this time around.
    @Torspd @Biscuits
  6. Mar 1, 2019 at 5:31 PM
    #626
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just finished a few simple mods on Lucario Runner's PreRunner. We'll be there.
  7. Mar 1, 2019 at 5:37 PM
    #627
    ThomasMore66
    Dallas/Fort Worth & Durango
    :burnrubber:
  8. Mar 1, 2019 at 11:11 PM
    #628
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Took longer than I planned (what else is new) but it’s alive again. I got the fuel pump rigged up temporarily so I can drive it.
    I had filled it at the house with a 5 gallon gas can. I just went and topped it off and it held another 27 gallons. I’m going to like this added range.
    I’ll be at C&C provided I can wake up. :pccoffee:
    Truck is dirty AF it’s been sitting under my tree all week and it’s full of leaves.
    Roostfactor, ChadsPride and DocME like this.
  9. Mar 2, 2019 at 8:58 AM
    #629
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Some pics from Houston Coffee and Cars
    33F59553-FBFA-4502-B5C0-71CE064ED5E1.jpg 11ED6012-23E5-4364-8EAA-17186406EDDA.jpg E0615B84-9C46-46F0-84F7-CFA662F83652.jpg 82F58172-2C69-4C9B-92B0-3C1BF49E4097.jpg DCBF6E26-306A-454C-86A3-DC3038FFBE8C.jpg 5924767D-272F-443C-AA9E-F63CE1047A80.jpg 4A00B14B-E8B2-4A1D-B801-C391021131D3.jpg D673C497-9CFA-48E2-B526-7DFFBBC3AC02.jpg 4BF52143-96ED-43BD-9A70-87DAB7F7E6FD.jpg 366339D7-C037-447D-A38D-BFD6D20C9B5C.jpg F37F7364-0209-465D-8A03-B60C8BFC0B73.jpg 9169885C-EA5D-443C-8B86-484D80B0B92C.jpg
  10. Mar 2, 2019 at 9:00 AM
    #630
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Someone has a sense on humor. This taco doesn’t do burnouts.
    :D
    1B9AD219-E005-41B6-818C-A70450ED1DA1.jpg 3D4226D7-B552-4036-AF70-614DDB25AE20.jpg
  11. Mar 2, 2019 at 11:51 AM
    #631
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Suspicion is strong with this one...
  12. Mar 2, 2019 at 12:17 PM
    #632
    ChadsPride
    Sponsored by TacomaWorld.com
    Heck of a show today, really great to meet you!
  13. Mar 2, 2019 at 5:05 PM
    #633
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Finally glad to put a face with the screen name. :cheers:
    The Force was strong with the Tacos today! Tons of eye candy out there as well! :devil:
  14. Mar 2, 2019 at 5:36 PM
    #634
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  15. Mar 2, 2019 at 6:21 PM
    #635
    Lucario Runner
    Robert
    06 Toyota 4Runner
  16. Mar 2, 2019 at 10:07 PM
    #636
    ThomasMore66
    I really want to make it to TX2K and see those cars. Going skiing with my daughter the weekend before. Not sure how I can swing another weekend away from home.
    Roostfactor likes this.
  17. Mar 8, 2019 at 7:09 PM
    #637
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I melted two pieces of metal together. Bunch of booger’s, but go me!
  18. Mar 8, 2019 at 7:28 PM
    #638
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your flange didn't warp. All good.
    What size cup were you using?
    What CFH were you flowing?
    Are you using a gas lense?
  19. Mar 8, 2019 at 7:39 PM
    #639
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Excellent questions.
    Good job D-Bo! That's about how my first TIG welds worth a crap looked. It'll hold better than a MIG job or any muffler shop job for sure. Run it!
  20. Mar 8, 2019 at 7:40 PM
    #640
    ChadsPride
    Most of the time I have no idea what's going on in here but it all looks good!
    :drunk:
