Lomax Hard Tri Fold Tonneau
Discussion in 'Tonneau Covers, Caps and Shells' started by zztacoma, Apr 29, 2019.
  1. Nov 5, 2021 at 10:46 PM
    #801
    winewiz
    winewiz New Member
    2022 Tacoma OR 4x4
    Just managed to install the cover yesterday after work fighting against daylight. Did manage to snap a bolt though from rushing through the install a bit to get it done ASAP. Will have to probably order a new set from Agri-cover just for peace of mind. Shoutout to Luke at truck alterations for hooking it up!
    truckalter likes this.
  2. Nov 6, 2021 at 8:49 AM
    #802
    truckalter
    truckalter Well-Known Member Vendor
    Luke
    Waynesville, NC
    Thanks! We appreciate the opportunity and support!
  3. Nov 16, 2021 at 6:02 PM
    #803
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    Id be interested in a price quote also; shipped to 19468.. or if somewhere close to PA; pickup! Looks great!
  4. Nov 16, 2021 at 6:16 PM
    #804
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    The support from LoMax is fantastic. I moved my trifold from my 2019 to my 2021 and contacted them for a new rubber seal that goes under the side rails as it did not peal off cleanly from my 2019. I explained my situation and they sent me a new seal no charge. I had it in a couple days.
  5. Nov 21, 2021 at 1:07 PM
    #805
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Installed this today and when I put the cover on and rolled it out, I noticed the last seal was tweaked. I’ve reached out to the vendor to see what can be done. I didn’t check the cover carefully/open it up before I installed it. In hindsight I absolutely should have. I would advise everyone check the seals and seams before they install this. Packaging was perfect so didn’t expect a problem. 08B59C7E-9409-4EE1-8122-15B5C236CFAF.jpg2949A9DA-6B59-4555-8F91-443B277AF1CC.jpg
  6. Nov 22, 2021 at 7:09 PM
    #806
    Timbo.slice
    Timbo.slice New Member
    PNW
    2022 Lunar Rock TRD OR
    Hey recently got myself a Tacoma and looking for a hard tri fold tonneau. These Lomax ones seem great but I'm curious how the weatherproofing has held up for those who've had them a while?
  7. Nov 23, 2021 at 3:11 AM
    #807
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
    Mine's been on for 2 1/2 years and still looks and works like new!
    The weather here is probably much different than the PNW but I'd still recommend this cover.
  8. Nov 29, 2021 at 10:39 AM
    #808
    Fairln
    Fairln Member
    What was your decision on this? I’m torn between these 3 as well
  9. Nov 29, 2021 at 6:04 PM
    #809
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    I actually went diamondback due to the Lomax price increases....guess it doesn't make much sense but it's what I did. Should be installed shortly
  10. Dec 23, 2021 at 7:45 PM
    #810
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    To those with the lomax cover, have you ever tied down any items on top of the cover?
  11. Dec 26, 2021 at 2:59 PM
    #811
    NickThornton
    NickThornton Well-Known Member
    2021 TRD OR 4x4 super white
    I haven’t, it can support up to 300lbs so depending on what you want to do it may be good for it. Only thing is lack of places to secure whatever is on top..
    Just_A_Guy[QUOTED] likes this.
  12. Dec 26, 2021 at 3:10 PM
    #812
    Biker88
    Biker88 Well-Known Member
    Len
    NYC
    '18 Off Road manual.
    I really would advise against it. Is pretty thin, im less than 300lbs and i wouldn't even consider standing on top of it.
  13. Dec 26, 2021 at 7:29 PM
    #813
    truckalter
    Luke
    Waynesville, NC
    Key point is he 300 pounds has to be evenly distributed and a person standing on a cover is far from evenly distributed weight... sheets of plywood stacked on top would be an example of evenly distributed weight...
    Either way I would use a rack system if I wanted to carry items over the top of the cover
    davidstacoma, hfjeff and Just_A_Guy like this.
  14. Dec 26, 2021 at 7:50 PM
    #814
    Just_A_Guy
    On the hunt
    A truck
    Thanks for the responses/info
  15. Dec 31, 2021 at 7:47 AM
    #815
    Montana_Actual
    Montana_Actual ;)
    Had the dealer install mine. Have to take it back in on the 5th because it's pretty leaky. This is what happens when I don't do things myself... Hopefully they can resolve it but I already have a tailgate sealer on the way and a Bed Rug cover that also extends to the tailgate. I know it leaks from the two spots on the front of the bed, but the weather has been hard to judge what else is leaking. I check it after a car wash, or rinse, and there are definitely spots. But it's freezing and I'd like to see how much it leaks normally without spraying straight towards it. I hate having to bring stuff back in to get checked on because it wasn't done right the first time or has an issue, so hoping to seal it up and pinpoint the weak spots this weekend so I can just tell the dealer not to worry about it. I really don't want them touching more than they have to. But, I like the tonneau cover. I almost went with a retractable one instead. I just wanted the most flush looking cover and this was what I saw. Family has one on their Ram 2500 and it doesn't leak at all. Really solid cover. Hopefully mine will play out that way too. They also had to have their looked at a second time.
  16. Dec 31, 2021 at 1:02 PM
    #816
    Just_A_Guy
    On the hunt
    A truck
    Could potentially be leaking due to install in Montana during the winter. Might not be sealing properly due to the extreme cold?
  17. Dec 31, 2021 at 1:22 PM
    #817
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    My Lomax has never leaked at the seals that it came with, I have had small drip leaks in heavy rain at the two corners front of the bed where the gaps are, that’s a Tacoma gap issue. some have sealed these joints but I don’t really want my bed totally airtight for the hot summers here prefer a little vent path and those small drip leaks are not an issue if they do occur, runs right down to the drain holes anyway. Most rains and even car wash the bed is bone dry.
    Others have had leaks at the seams of the tailgate but i’ve not noticed that, those can be sealed as well.
  18. Jan 6, 2022 at 4:47 PM
    #818
    MGMDesertTaco
    @truckalter I'm interested in one of these, sending you a PM.
  19. Jan 7, 2022 at 7:26 AM
    #819
    truckalter
    Luke
    Waynesville, NC
    Replied!
  20. Jan 7, 2022 at 2:45 PM
    #820
    JHusky
    JHusky Active Member
    James
    2021 Army Green Tacoma Off Road
    Has anyone installed the adarac bed rails that are made to go with the Lomax? Heres a link: https://www.agricover.com/adarac/utility-rails/
    I wanted to use these so I can then put bed rails above the lomax. It wont be able to be flipped, but it would be nice for security below a RTT. Any pictures appreciated.
    truckalter and GrizzledBastard like this.
