Lone Star Toyota Jamboree Live! (2018)
Discussion in 'Off-Roading & Trails' started by BigMike, May 1, 2018.
  1. May 3, 2018 at 9:06 PM
    #101
    BigMike
    BigMike [OP] Applied common sense Vendor
    Fresno, CA
    2016 56-speed 580:1 Triple Marlin Crawler-equipped TRD Sport
  2. May 3, 2018 at 9:07 PM
    #102
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Jeez. Rockin 40”s plus!
    BigMike[QUOTED][OP] likes this.
  3. May 3, 2018 at 9:11 PM
    #103
    BigMike
    Fresno, CA
    I know, they're crazy awesome! I edited my post and added a third pic.
    The 4R is on 39", the white AC is on 41", and the silver DC is on 42" :eek:
  4. May 3, 2018 at 9:25 PM
    #104
    BigMike
    Fresno, CA
    Our good friends from RSG Offroad (https://www.rsgoffroad.com) from the Denver CO area were setup with their amazing 5th gen 4R also on 40s...
    Rock'n our Marlin Crawler TacoBox Supreme
    So beautiful
  5. May 3, 2018 at 9:30 PM
    #105
    BigMike
    Fresno, CA
    Few misc pics from the pavilion area
    This one looks cool. Love the Pitbull ROCKERs
  6. May 3, 2018 at 9:36 PM
    #106
    BigMike
    Fresno, CA
    There wasn't much going on and it was pretty quite. Did have a fair amount of ppl hanging out. Rained off and on. They had a simple and very good burger and hotdog dinner. Thank you for offering non-Pork choices unlike the stupid FJ Summit event!!! >_<
    There were rigs parked all around. Some heading out for late day trail runs while others were returning. I'm looking forward to checking out and sharing pics from some wheeling finally tomorrow!!
    I just hung out and chatted with ppl and then headed to my hotel to do some marketing work on our website. Gonna call it a day and hit the sack. It's almost midnight here. Looking forward to meeting a lot of awesome Toyota owners soon!
    Good night from Texas!
  7. May 3, 2018 at 9:37 PM
    #107
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    That would be @SMKYTXN with the Trail Toys rig.
    SMKYTXN and BigMike[QUOTED][OP] like this.
  8. May 3, 2018 at 10:24 PM
    #108
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    How would the Automatic fair if it was triple cased?
  9. May 4, 2018 at 5:35 AM
    #109
    SubCultureNM
    SubCultureNM Well-Known Member
    Brian
    Houston, TX
    2017 DCSB
    Just fine. The trans doesn't see any more stress based on what's downstream. If anything, you're taking stress off the trans.
  10. May 4, 2018 at 9:48 AM
    #110
    BigMike
    Fresno, CA
    While SubCultureNM is correct, the problem the driver will have is that it would literally be impossible to stop the truck with the drivetrain loaded where you can't shift into neutral.
    Consider how a torque converter is designed to stall when the torque load of its output exceeds the torque load of its input. In operation, there exists, depending on ATF temperature, about a 2:1 to 2.5:1 ratio of input torque vs output torque when the ECU has not electronically locked the torque converter, ie. while idling, but for the sake of illustration let's assume it's a 1:1 stall ratio.
    To simply state stall, if the engine is outputting 10 lb-ft of torque and the input to the transmission requires 10 lb-ft of torque to rotate it (because it's connected to your tires and maybe they are 1 foot sunk in mud, then nothing happens. The system is in a static equilibrium and has "stalled". To "unstall" you simply increase torque input by giving it some more skinny pedal. ;)
    Now consider the following examples.
    1) Imagine what would happen if you were stopped on an up hill slope at a red light towing a small trailer. Imagine that the conditions were just right that while in Drive you could let off the brakes and the truck would not move forward or reward. It would just sit there stalling with gravity.
    2) Image what would happen if you were in Drive and 4WD high range and let the truck idle forward on it's own with good traction and into a giant sequoia tree. Without pressing the brakes the truck would bump into the tree and simply come to a stop ("stall") despite the engine still idling.
    3) Finally, imagine what happens when you're in Drive approaching a red light and press the brakes to slow down to a complete stop. This is also stall. Torque converters are stalling every day of their life.
    In all three scenarios the Torque Converter is simply doing it's job, spinning around getting dizzy with no clue what's going on in the outside world. It sees a load at the transmission that is higher than the torque input from the engine, so it stalls and nothing moves.
    Now let's see what happens when we shift into low range. Suddenly, according to the torque converter, the perceived drive train load has reduced by 2.57:1 (the t/case low range gear ratio). This means that in scenario #1 you'd need a trailer with a rolling resistance 2.57-times higher for the truck to sit stationary on the slope. It also means that in scenario #3 we need a brake-force 2.57-times greater to bring the truck to a stop and keep it stopped.
    Now, with a Marlin Crawler TacoBox Supreme, which is a 4.70:1 ratio added in front of the 2.57:1 t/case for a compound ratio of 12.08:1, the driver has to hit the brakes 12 times harder than stock to stop the vehicle. This isn't so bad. You just gotta press the pedal firmly. Also, this ratio in an auto is mostly used for showing off; Most of the time you'd only have the TacoBox in low (4.70) and the t/case in high (1:1). In fact, this is even how I drive my Tacoma 90% of the time. I only need that extra double-low gearing when I'm really in trouble or need the maximum control otherwise impossible without a Marlin Crawler. But to have that option... To have that extra gear lever at your disposal at all times. That sense of security is PRICELESS to those who have it!!
    But now, with Triples and an auto, should you decide to engage all three low ranges, you'd have a 27.54:1 total t/case ratio meaning you must hit the brakes nearly 28 times harder to bring the truck to a stop. While I've never seen this done, I am most certain this would be entirely impossible as I can demonstrate this simply in my Tacoma: Shift it into Triple Low and step on the brake pedal with BOTH feet while simultaneously pulling into the steering wheel with my upper body at my full might and the engine doesn't even deflect from it's idle RPM speed. Of course for me I can just engage the clutch pedal and come to a stop, but under a load it might not be so easy with an auto.
    To explain and someday I will do the math for this, let's assume that at 800 RPM idle the engine is developing 10 lb-ft torque without any throttle, just the torque from the ECU maintaining idle speed and the inertia from all spinning objects such as a 35-lb flywheel + pressure plate (or in the case of an auto the flex plate + torque converter). Now, multiply 10 lb-ft by my Crawl Ratio of 580. Not including parasitic losses, there is 5,800 lb-ft of torque............and we haven't even touched the gas pedal. There is no way in hell my brakes are going to stop 6K lb-ft of torque. This is around two to three times more torque output than a modern 18-wheeler Big Rig's 15-liter turbo diesel engine at full throttle and boost.... and yet my engine is still just quietly idling. Now..... for an automatic.... we need to add in the 2:1 ~ 2.5:1 multiplication from the torque converter and................ you'll have to turn the ignition off in order to stop the truck :D
    I hope this doesn't scare anyone. If there is no load on the auto then you can just simply shift into Neutral using your pinky finger even in Dual Marlin Crawler Low Range as if the truck was coasting to a red light. No big deal. The above is just an extreme scenario and is why we've never had a customer try it haha We are open to anyone who'd like to be the first :D
    Regards,
    BigMike
  11. May 4, 2018 at 9:51 AM
    #111
    SubCultureNM
    Brian
    Houston, TX
    2017 DCSB
    I WILL have your doubler in my wife's '17. Don't need more than one, but I'm looking forward to that 4.7:1.
  12. May 4, 2018 at 10:03 AM
    #112
    BigMike
    Fresno, CA
    That's a BIG 10-4 good buddy!!
    I edited and added a bit more to my reply for clarity after proof reading. :thumbsup:
  13. May 4, 2018 at 11:27 AM
    #113
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Looks like I have a new neighbor.
  14. May 4, 2018 at 1:43 PM
    #114
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    So triple case with Auto is just to show off and useless for 90%.. so just tacobox for me...
    BigMike[OP] likes this.
  15. May 5, 2018 at 7:54 AM
    #115
    BigMike
    Fresno, CA
    Good morning from Gilmer, TX everyone!
    Sorry for the lack of updates yesterday. Running a vendor booth at this large of an event was a lot of work for one guy and I never got a chance to post up! I don't have much time right now but wanted to get some updates to the thread :D
    May 4, 2018 - Thursday
    This is what I woke up to outside my hotel room <3
    Over the years I've really disliked how Toyota keeps making the 4R larger, and larger, and larger, and when I was standing here I was thinking..... holy smokes this Tacoma is way too big. We need a small, simple, compact Mini-truck again Toyota!! >_<
    dskakie, ETXTacoma, ODNAREM and 3 others like this.
  16. May 5, 2018 at 8:02 AM
    #116
    BigMike
    Fresno, CA
    May 4, 2018 - Event, Thursday (continued)
    Here is what the day had in store for us. Scheduled to rain until evening
    There were certainly many more people on Thursday! Just look at all these trucks parked at the pavilion!! And there are many more out on trails getting super muddy! (yuck!)
    ETXTacoma, ODNAREM and nDub like this.
  17. May 5, 2018 at 8:04 AM
    #117
    BigMike
    Fresno, CA
    Moar!!
    Sa-weeeeeeeeeeeet!!! Check out this 1979-1981 1st gen representing!!!!
  18. May 5, 2018 at 8:27 AM
    #118
    BigMike
    Fresno, CA
    Finally for now, here I am setup in the vendor section at the wettest vendor show I've ever done!
    Short video from inside our booth :hattip:
    https://www.youtube.com/watch?v=KyITD83rOQA
    I'll try to post more soon!!
  19. May 5, 2018 at 11:51 AM
    #119
    BigMike
    Fresno, CA
    Misc pics from yesterday
    ETXTacoma and ODNAREM like this.
  20. May 5, 2018 at 11:53 AM
    #120
    BigMike
    Fresno, CA
