Long bed in 6spd Manual Transmission?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by QikSandTaco, Jan 22, 2020.
  1. Jan 22, 2020 at 4:09 PM
    QikSandTaco
    QikSandTaco [OP] New Member
    2017 Tacoma TRD Sport 6MT QuickSand
    Hi guys,
    Not sure if there is already a thread on this or not but I wanted to know if the long bed configuration came in the 6speed manual transmission. Before I bought mine, I've searched all over but it seems like only the automatics come with the long bed option. I love look of the long bed and the space that it provides. Too bad I couldn't find any in manual.
  2. Jan 22, 2020 at 4:12 PM
    Dc2tacoma
    Dc2tacoma Well-Known Member
  3. Jan 22, 2020 at 4:13 PM
    81shark
    81shark Well-Known Member
    Yes. You can get an access cab six ft bed with a six speed. Woot
  4. Jan 22, 2020 at 4:15 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Access cab TRD Sport is the only one that isn’t a 4-door short bed.
  5. Jan 22, 2020 at 4:15 PM
    nathan298
    nathan298 Well-Known Member
    Nathan
    Bristol, VA
    '21 Voodoo Blue Off-Road 6MT
    There seem to be a lot of people who want that configuration, but unfortunately it doesn't exist. The only way to have a long bed manual transmission truck in a 2005-2020 is to get the smaller access cab. No double cab long bed has ever been made with a manual.
  6. Jan 22, 2020 at 4:31 PM
    QikSandTaco
    Thanks for the info guys. Drove 4hrs out of state for my truck so if this configuration ever existed, you can bet I'll drive any distance for it.
  7. Jan 22, 2020 at 4:59 PM
    Shellshock
    Iowa
    Just extend your frame and drop a long box on. Problem solved.
    QikSandTaco[OP] likes this.
  8. Jan 22, 2020 at 5:01 PM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    I want one too and keep mentioning it here hoping Toyota will notice, but they don't
    mistareeman and Junkhead like this.
  9. Jan 22, 2020 at 5:55 PM
    Trd_omar
    Trd_omar Active Member
    Reno NV
    2019 Trd Sport Access Cab MT
    Exactly what I was looking for I settles for a trd sport access cab
    nathan298 likes this.
  10. Jan 22, 2020 at 6:08 PM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    It would have made my decision a little tougher if they had a DCLB in manual but I ended up with what I wanted with the access cab. I wish there was more choices for manual but it is a dying breed...
  11. Jan 22, 2020 at 6:12 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Why, toyota why!?
    That would be a perfect configuration for me.
  12. Jan 22, 2020 at 6:12 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    :rofl:
  13. Jan 23, 2020 at 5:36 AM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    I did the same and ended up swapping out for a DCLB Off-Road a few months later. Lost a few grand that I mostly made up saving a couple points on promo financing and the fact I'd need tires on the Sport. Not to mention I've driven away from several situations where ATRAC saved my ass that I'm not very confident the Sport would have pulled off.
  14. Mar 21, 2020 at 2:05 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    For a really long time in Canada if you wanted DCSB you had to get a 6MT and if you wanted DCLB you had to get AT.
    Unfortunately DCLB has never been made with a manual anywhere. If you really wanted one you can either frame swap a manual (hard) or transmission swap an automatic (less hard).
    Jeff
    Blackbeard83 likes this.
  15. Mar 21, 2020 at 3:50 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Is in the US only the TRD sport Access Cab is available with the 6MT. 2016-2017 had also the SR Access Cab with the 2.7 4cyl with a 5MT. If in Canada, you can get the TRD OR V6 Access Cab.
    I imagine a DCLB could be converted to manual.
    You would need a RC62F 6MT
    an manual trans ECU and wiring harness
    Custom length driveshaft
    Swap for 4.30 B06A differential
  16. Mar 21, 2020 at 4:37 PM
    Jeff Lange
    Calgary, Canada
    Probably wouldn’t need a custom driveshaft. Just use the front half from a DCSB 6MT and the rear half from a DCLB TRD OR.
    Jeff
    shakerhood likes this.
