Long Canyon Update
Discussion in 'Moab' started by Chooter, Jun 13, 2020.
  1. Jun 13, 2020 at 7:45 PM
    Chooter
    Chooter [OP] Well-Known Member
    Colorado Springs Area
    2019 TRD Off Road
    Alaskan Malamute Fur and a plethora of mods... because ...
    Hey everyone... according to FunTreks This trail is rated as easy (Time changes ratings). It is not suited for 2WD. Just did it this weekend... NOT rated for 2WD. Mostly easy.. but right as you pass under the boulder... it gets a bit sporty. Rocks in front kicked me to the left and almost off the cliff. Maybe the line, but not a 2WD trail. Super fun and scenic... but this is just a PSA.
    Moab is SIC!
  2. Jun 13, 2020 at 7:49 PM
    Chooter
    2019 TRD Off Road
    Moab!
    Bad internet. Upload pics / vids when I get home.
    Edit:
    Unable to upload the video.
    Bad extension? Not sure.. but in my 2019 TRD Off Road... it was sic. Very cool trail. Tame for the most part... but not really a sedan or 2WD vehicle trail.
  3. Jun 21, 2020 at 6:29 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Thanks for the head's up. We plan on running the Long Canyon,Shafer, Potash loop in October.
  4. Jun 21, 2020 at 6:31 PM
    tcjacado
    tcjacado Well-Known Member
    Video needs to be uploaded to YouTube and then post the link here.
  5. Jun 29, 2020 at 9:41 AM
    Chooter
    2019 TRD Off Road
    That is what we did on the same day. Very doable. For Long Canyon, we started at the top and went down.
    Thanks JaCado. I will try.
    Hilborn[QUOTED] likes this.
  6. Jul 7, 2020 at 4:14 PM
    Chooter
    2019 TRD Off Road
    Just some shots from the trip. I DO NOT recommend blowing through large mud puddles if you like your engine compartment clean...:)
    Moab is something special. Can’t wait to go back!
    Durango95 likes this.
