Long Crank, Hard Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by malhebir, Jul 8, 2021.
  1. Jul 8, 2021 at 10:48 PM
    malhebir
    malhebir [OP] New Member
    Mohamed
    2015 white Tacoma
    Hello to all
    I have 2TR-FE engine
    When I want to start the engine in the morning it works and start normally
    But after 30 min its take a long time (long crank) I usually take two to three times then start
    i changed fuel injectors, fuel pump and crankshaft position sensor
    I check the fuel pressure regulator by gauge about 41 PSI
  2. Jul 8, 2021 at 10:56 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Pop the #4 coil out (it’s easiest to get to). Is the coil (at the plug) dry or wet and covered in oil? If it’s wet you need new valve cover and spark plug tube seal gaskets. Welcome to TW!
    Hawapino and 12TRDTacoma like this.
  3. Jul 8, 2021 at 10:58 PM
    malhebir
    Mohamed
    2015 white Tacoma
    I forgot to say I changed a new plugs (laser)
    And 4 new coils
  4. Jul 8, 2021 at 11:00 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Check a coil, again to see if they are wet
  5. Jul 8, 2021 at 11:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Take it to a shop and have compression (both static and dynamic) and have a cylinder leakage test performed on it. Those 2TRs are indeed notorious for having either bad valves or a blown head gasket.
    TnShooter likes this.
  6. Jul 8, 2021 at 11:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    So, essentially it’s hard to start once the truck has warmed up?
    But starts normally when it’s cold?
  7. Jul 9, 2021 at 1:08 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I believe that's what OP is saying. I had this issue on my old truck. But it sounds like OP already eliminated what I was going to suggest.
    Are there any codes?
  8. Jul 9, 2021 at 1:36 AM
    malhebir
    Mohamed
    2015 white Tacoma
    No code issue
  9. Jul 9, 2021 at 2:37 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    News to me. Got any backup links on that info?
    TnShooter and SR-71A like this.
  10. Jul 9, 2021 at 2:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No links. Hard evidence at the shop I worked at over the course of many many years.
    We didn't have a major slough of them coming through but when they did and they involved anything related to misfires, hard starts, or intermittent misfires at start which would then smooth over the longer the truck would run. It was always either valve or head gasket issues.
    This assumed that the customer or prior shops replaced all secondary ignition components including coils, and even went as far as replacing injectors and/ or fuel pumps.
    Jimmyh[QUOTED] likes this.
  11. Jul 9, 2021 at 3:14 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Sounds like a hot soak issue; my first tests would be starter and coils.
    SR-71A likes this.
  12. Jul 9, 2021 at 6:24 PM
    TnShooter
    Deogee
    STOCK
    OP says it cranks and has replaced all for coils.
    OP, how long after you turn it off is it that it is hard to start?
    As in, what is the amount of time in between turning off the engine, and then restarting the engine?
  13. Jul 9, 2021 at 8:29 PM
    tirediron
    D'ohhh... missed that.
    In that case, a good scan tool with live data; look at the outputs of all the key sensors (MAF, TPS, Cam, would be a start) and compare their data to what you should be getting, both when running normally and during the hard/no start condition.
  14. Jul 9, 2021 at 8:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check coolant temp sensor. Preferably with a code/data reader
    That's the first thing the computer looks at on startup
  15. Jul 31, 2023 at 1:53 PM
    44newman
    44newman Member
    05 2.7 5spd Prerunner 4x4 access cab LB
    4x4 Swap, FJ Case, SAW 2.5 Shocks, 18 Taco suspension,
    Any resolution to this? Mine suffers same problem, once warm, randomly takes a long crank to get it started, and the start is slow/low RPM like low fuel pressure. Even only being shut off for 1-2 min. No oil in my spark plug tubes either, last owner replaced #4 coil. I will check the coolant temp sensor reading.
