Long cranking period when starting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MattN03, May 28, 2009.
  1. May 28, 2009 at 5:08 PM
    MattN03
    MattN03 [OP] Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    I picked up a 07 DC at the beginning of this month. It was owned by an older couple who rarely drove it and only had 3800 miles on it when we picked it up. It has about 5200 miles on it now and I've noticed it taken several seconds to start (maybe 5-7 seconds of cranking before it turns over) on two occasions now. It's done it twice this week and only when it's been sitting at my work for about 4 hours after arriving and then when I leave for lunch. Anyone else heard of such an issue? The closest dealership is 45 minutes away, so it's not really convenient to take it in during the work week and the dealership probably would have a hard time replicating it anyways.
  2. May 28, 2009 at 5:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The ECU wont give the engine spark until a pre set oil pressure is reached. 3-4 seconds is normal. If you can time it with a stop watch (what they will do at the dealer) and make sure its cranking longer, There WAS a TSB for longer crank times, so If its much longer than 3 to 4 seconds, take it in.
  3. May 28, 2009 at 5:23 PM
    MattN03
    Bluegrass State
    Interesting...I did change the oil this weekend using 5.5 QTS of Toyota 5W-20 & a Toyota filter. I'll triple check the oil level tomorrow morning before startup.
  4. May 28, 2009 at 5:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok...If you have the V6 engine, You need 5w-30. That could be the reason.
  5. May 28, 2009 at 5:39 PM
    MattN03
    Bluegrass State
    mmm, I'll double check. I can't remember what the Toyota parts guy gave me. I told him I had an 07 with the 4.0L though.
  6. May 28, 2009 at 5:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If he gave you 5w-20, go back and smack him. I have read a few reports of this happening with the wrong oil weight in the enigne.
  7. May 28, 2009 at 5:45 PM
    MattN03
    Bluegrass State
    Just checked, it was 5W-30.
  8. May 28, 2009 at 5:49 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I believe we're supposed to use 5W-30... Not sure if going to that 20 will make a difference in oil pressure though.
  9. May 28, 2009 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok, time it with a stop watch and see how long exactly it is cranking...
  10. May 28, 2009 at 6:13 PM
    MattN03
    Bluegrass State
    Will do. It seems strange that's done it at work but never at home, etc.
  11. May 29, 2009 at 1:04 AM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    this might be useless, but my old Jeep would crank for 5 seconds, not start and then on the second time I tried it would start
    There is a valve near the fuel pump that is supposed to maintain some pressure in the fuel rail. If this valve leaks, to much pumping is required to get fuel pressure up. The ECU gives the pump 3 seconds to achieve the proper psi, otherwise it will never start. When I crank it the second time, the fuel has not had time to drain back and thus the pump can achieve pressure and the Jeep would start.
    So, I'd suggest trying this. Crank for 3-5 seconds. Stop. Crank again. If it starts, it might be the same problem as I had.
    The valve and fuel pump were integrated on the Jeep (probably the Toy too) so the ntire pump must be replaced to fix this problem.
