long distance towing
Discussion in 'Towing' started by DSMissed, Apr 27, 2011.
  1. Apr 27, 2011 at 5:42 AM
    DSMissed
    DSMissed [OP] Well-Known Member
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    3" lift with adjustable shocks and AAL, TPS disabled, anytime locker mod, MOOG greasable ball joints and adjustment pins, URD M3 s/c, Pioneer nav headunit, xplod 1000w amp, 10" infinity sub, tinted windows, lightly tinted tails, color matched front grill with blacked out emblem. Do battle scars count as mods?? =D
    Here's the thing. I'm planning on taking a trip this summer to TX, and my mom is letting me have here Jeep Wrangler, so I'd probably be towing that back with me, just on a car dolly for less weight.
    So, I'm a little worried about towing a 3500lb vehicle for 1400 miles with the Tacoma. I do have an 03 Ford 1 ton diesel I could use (no 6.0 bashing please:eek:), but its just a single cab clunky work truck. So I would have to sacrifice ride quality by taking it, as well as paying the extra cost of diesel, even though mileage for the ford and tacoma are about the same.
    So. Do the right thing and use the bigger truck to do the job? Or should I not give up my quality of the ride and just make the Tacoma pay its dues?
  2. Apr 27, 2011 at 5:49 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I'm kind of in the same situation. Next week I will be towing my boat which is about 4500lbs plus gear, and 4 people 8 hours south to Lake Norman NC. I'm a little nervouse as well but I think our Tacoma's can handle it. The 4.0 has decent power for towing. Just take it easy and give yourself plent of stopping distance and money for gas. Your MPG will drop to about 10-12.
  3. Apr 27, 2011 at 5:50 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I would bet the Ford diesel would get better mileage towing. I'd look into a flat bed though, it's not recommended to tow a 4wd vehicle with the front tires up and the back tires on the ground spinning (although with the transfer case in neutral I doubt it'd cause any damage, it's just not recommended).
  4. Apr 27, 2011 at 6:03 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    I planned on towing it backwards, so the front wheels were on the ground because then it shouldn't matter, should it?
    The diesel would get better mpg towing, and be able to tow it faster up hills and stuff. But diesel is also about 50 cents more per gallon, so I don't know if I would end up saving money or not.
    Holy crap, MAXTacoma, just looked at your sig pic, that boat makes your taco look pretty small!
  5. Apr 27, 2011 at 6:12 AM
    Pugga
    Massachusetts
    F-150 Mod
    Whether the front wheels are on the ground or the back wheels, it does not matter, the issue is in the transfer case. The Jeeps have a "neutral" setting for the transfer case I believe so that should keep things spinning freely so it doesn't matter which set of wheels is on the ground. I was just giving you a heads up because it's still not technically recommended to tow a 4x4 that way. Again, I doubt you'd do any damage at all, just throwing it out there.
    You're right about the fuel cost, you'd probably end up breaking even on total overall cost but the diesel will tow much easier than the Tacoma so why beat on the smaller truck when you have access to the bigger truck that won't even be phased by the weight? Your Tacoma will do it just fine, the diesel will make short work of it.
  6. Apr 27, 2011 at 6:24 AM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    You should be fine towing the jeep with the Tacoma. I tow regularly a 4100 lb toy hauler and when loaded it probably weighs in at about 5200 lbs. The weight itself isn't that big a factor but the height and drag it causes makes the mpgs drop. But you towing that jeep should give you about 10-11 mpg. Oh, I did tow that travel trailer about 1200 miles from Mesa, AZ to Houston, TX. I think you'll be fine, but give yourself more time for braking, since, I guess you won't have anyway to slow down dolly or jeep independently.
  7. Apr 27, 2011 at 6:26 AM
    MAXTacoma
    Lexus GS 350
    Yes she is a pretty good size, 20.5 ft, but is ton of fun :) The Tacoma really handles it pretty well. Just wish I had some bigger mirrors as I can only see the sides. Oh yeah and more power wouldn't hurt either.
  8. Apr 27, 2011 at 10:36 AM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Don't rent a tow dolly for the jeep. Just go to harbor freight and get a tow bar, and flat tow the jeep. I do this my brother's wrangler. My truck with 33's tows it just fine. I can keep 75mph up a 8%+ grade hill with a head wind (I don't recommend doing that though). Just remember: put the transfer case in neutral, tranny in any gear from 2-4 (if a manual). I says all of this in the owners manual of the Heep.
  9. Apr 27, 2011 at 10:49 AM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    I own a dolly, but I didn't think about the tow bar... thats a good idea. Don't you have to drill holes or something with a tow bar though?
    How come you would want to tow it in gear? Just curious, that doesn't sound right!
  10. Apr 27, 2011 at 11:31 AM
    S.B.
    Sean
    You only need to drill 4 holes in the bumper of the Jeep.
    The manual says to tow in gear (but transfers case is in neutral). Its something about keeping it lubricated.
    EDIT: I forgot to add that I've tow my brother's jeep from SD, CA to Flagstaff, AZ which is about 600 miles.
  11. Apr 27, 2011 at 1:23 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I flat towed a 68 dodge pickup from East Texas to NE Tennessee with a tow bar I found in the barn of the house we bought in texas. I just build an adapter plate and turned the bumper bolts around, plus since it was an automatic, I pulled the driveshaft.
    The tow vehicle was a 24' box truck full of household goods...very slow up the hills.
    Howard
  12. Apr 27, 2011 at 1:28 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i towed my honda s2000 on a dump trailer about 2.5 hours with no issues. it was about 7000lb bc the trailer weighted a couple ton but no issues even up hill. i know it's not as far as your asking but it tows no problem
  13. Apr 27, 2011 at 8:17 PM
    DSMissed
    Kerri
    Lead South Dakota
    06 4x4 TRD OR
    I've towed cars with my Tacoma before, and I just don't like how it feels going up the hills, I feel like I'm just being so hard on it, lol. I'm torn :l
  14. Apr 27, 2011 at 8:35 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    i think you would be fine...just take your time and check evrything (oil, tranny, tire pressure, straps) when you stop for gas. what ever you decide on, be safe and good luck!
  15. May 6, 2011 at 1:37 AM
    SPORT
    SPORT Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    I towed a 12' pop up trailer everywhere witj my Gen 1 V6 prerunner in CA...including up I-5 and NEVER had an issue. In 2004 I pulled that trailer, 3 bicycles and a motorcycle 3,000miles across country. Though it was overmax and it worked hard, it proved its name. It's a Tacoma!
  16. May 6, 2011 at 5:04 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    We have towed our trailer around lake superior every year now for 3 years in the fall. Around 4000 km trip (2500 miles) up and down very large hills which is part of the canadian shield ( rocks left over from the ice age). No problems at all. Drive with care and lots of room up front for braking and i can not see you having a problem.
  17. May 6, 2011 at 6:57 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
  18. May 6, 2011 at 7:16 PM
    showmeballer
    showmeballer Well-Known Member
    st. louis
    08 trd off-road
    None yet
    I would just take the Ford, you wont even know the Jeep is back there and you wont put any stress on your Taco. :cheers:
