Long Headers 2013
Discussion in 'Performance and Tuning' started by SanDiegoTaco, Aug 9, 2014.
  1. Aug 9, 2014 at 7:46 AM
    SanDiegoTaco
    SanDiegoTaco [OP] New Member
    Yousef
    San Diego
    TRDOFFROAD
    Stock
    Hey there everyone!
    I got me a stick shift 2013 V6 tacoma, and I think its about time to put me some headers on it.
    Can anyone recommend where I can buy or order some Long Tube Headers for my truck?
    Thanks in advance!
  2. Aug 9, 2014 at 8:01 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  3. Aug 9, 2014 at 8:08 AM
    SanDiegoTaco
    Yousef
    San Diego
    TRDOFFROAD
    Stock
    Thanks man that looks good!
    What about Y pipes? Do you know if the URD Y pipes would work with the JBA/Doug Headers sold on the site?
    Thanks.
  4. Aug 9, 2014 at 8:11 AM
    XXXX
    sKiP
    05 Prius
    Their Y pipe "should" bolt right up to all the long tube headers. I got a set of JBA long tubes in titanium ceramic along with the URD Y pipe a month ago, but haven't installed it yet.
    If your worried call Gadget at URD before you place your order. He's very helpful and can tell you if there will be any fitment issues.
  5. Aug 9, 2014 at 2:10 PM
    SanDiegoTaco
    Yousef
    San Diego
    TRDOFFROAD
    Stock
    That looks like a good setup!
    Thanks for your help!
    What exhaust are you planning to put on that too if you dont mind me asking?
  6. Aug 10, 2014 at 5:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. The y-pipe is designed to bolt up to stock, or aftermarket headers/catbacks which bolt up to stock. :thumbsup:
