Long Idle Times?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MudFlap, May 6, 2015.
  1. May 6, 2015 at 8:48 PM
    MudFlap
    MudFlap [OP] Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    So I'm working 2 jobs now and sometimes I have a 2 hour window between them to eat and catch a nap. Am I doing any harm to my 4.0 to let it idle with the AC blowing for like and hour and a half?
  2. May 7, 2015 at 4:13 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    No, but you might want to change your oil more often.
  3. May 7, 2015 at 4:21 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    excessive idling is bad for any engine. almost any owners manual will say so, even idling to " warm" the engine is usually warned against and preferred method is to drive slowly to warm the engine. Plus you have the whole carbon monoxide poisoning risk sitting in an idling vehicle
  4. May 7, 2015 at 4:28 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Ive heard it both ways. I've idled for hours during power outages without any trouble. It would be nice if someone could point to an article discussing this with some actual stats to back it up either way
  5. May 7, 2015 at 4:53 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Yes. You do run the chance of shortening the life of your air-conditioner. The air-condition is not set up to handle long idles and low airflow across the condenser thus you are running higher head pressures and lessening the longevity of the unit. They put different refrigerant in a vehicle then they do a stationary unit and the refrigerant in a vehicle has a different boiling point and does not cool the same and not suited for long idles.
  6. May 7, 2015 at 6:04 AM
    ejl923
    Eric
    Western Mass
    Good point, i was only thinking about the engine, but the a/c is probably the more worrisome component
  7. May 7, 2015 at 11:47 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    your gas bill will hate you.
    Took my truck to the dealer and they idled the truck for some time (maybe an hour or so) while they worked on it (checking the AC and master cylinder)..... typical mpg is around 17.5 ... that tank was 15.8mpg.
