Long Island, NY Tacos
Discussion in 'North East' started by brutalguyracing, Jul 6, 2010.
  1. Apr 18, 2018 at 12:27 PM
    #3241
    harl3ygonewiild
    harl3ygonewiild Well-Known Member
    Harley
    2017 tacoma TRD off-road
    guessing a 2g then
  2. Apr 18, 2018 at 12:28 PM
    #3242
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    you dont count here with that boost lol
    dirtdigginjoe[QUOTED] likes this.
  3. Apr 18, 2018 at 12:30 PM
    #3243
    harl3ygonewiild
    Harley
    from what ive always thought 4low was only when you were stuck or pulling some one stuck out, never used to to just drive on snow/sand or any off roading
    uurx likes this.
  4. Apr 18, 2018 at 12:31 PM
    #3244
    uurx
    '12 t|x pro
    if you get stuck in 4lo, without self recovery gear, you pretty much shit out of luck
    you get stuck solo on 4hi, without self recovery gear, you know you at least have 4lo to give it a shot before throwing in the towel and hanging yourself
  5. Apr 18, 2018 at 12:32 PM
    #3245
    harl3ygonewiild
    Harley
    and then my locker :locked: and then crawl control :mudding:
    crazychris4124 and uurx[QUOTED] like this.
  6. Apr 18, 2018 at 12:34 PM
    #3246
    uurx
    '12 t|x pro
    i crawl on the beach in 4lo just to work out the locker for a couple miles
    i also find the ride much smoother while using a trac (although the added heat on the brakes makes me not use this option too often)
    4hi & locker would be nice, maybe in the future with some extra parts from marlin :spending:
  7. Apr 18, 2018 at 2:21 PM
    #3247
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Well I mean, I won't be cruising around in boost! Shinnecock I find having to use 4Lo is almost mandatory once you get out there. Smith's you can easily do 4Hi unless you go to the end of the day area where it's more fresh sand than travel lanes. Starting out on the sand is a pain in the ass with the new clutch in!
  8. Apr 18, 2018 at 2:23 PM
    #3248
    crazychris4124
    crazychris4124 Earn those pinstripes
    Westchester County, NY
    '17 Inferno Moneypit
    Too many but also not enough mods
    Any other tips for driving in the sand? Already have a snatch strap and tow hitch shackle
  9. Apr 18, 2018 at 2:30 PM
    #3249
    uurx
    '12 t|x pro
    yea plus with the tides that we get here the conditions change dramatically season to season if not week to week sometimes
    if you air down properly you greatly greatly decrease the chances of getting stuck and airing down after you are stuck doesn't do shit, simply too little too late at that point with some of the soft sand we have here
    you can easily burn a quarter tank of gas running back and forth a couple times at smiths point so I tend to like at least half a tank of gas...
    I have come across people using gas tanks out there so it does happen...
    sun reflector for the windshield is nice also if you plan on being parked for extended periods of time.
    maybe an extra shackle or two, chances are you will be pulling someone else who got stuck before your taco hits the SOS button located in the glove box :burnrubber:
  10. Apr 18, 2018 at 3:00 PM
    #3250
    crazychris4124
    Forgot to mention I do have a portable compressor that hooks up to the battery and extra shackles.
  11. Apr 18, 2018 at 3:17 PM
    #3251
    harl3ygonewiild
    Harley
    Got a jack and a board to put it on if you ever need it?
  12. Apr 19, 2018 at 5:24 AM
    #3252
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    I normally carry:
    • Fire extinguisher
    • Tow straps
    • Jack
    • Jack board
    • 50' air hose
    • Collapsible Shovel
    • Emergency toolkit (10-14mm sockets, hose clamps, JB Weld, Screwdrivers, little bit of primary wire)
    • Coolant
    It all fits in a small tote, so whenever I go to the beach, I just toss it in the bed.
    crazychris4124 and Bastek like this.
  13. Apr 19, 2018 at 6:17 AM
    #3253
    uurx
    '12 t|x pro
    here is the list that is posted on the suffolk county parks department page
    http://www.suffolkcountyny.gov/Departments/Parks/ThingsToDo/OuterBeachAccess.aspx
    Required Equipment for Outer Beach Off-Roading
    Jack
    Jackboard
    Shovel
    Rope, Chain or Snap Line
    Fire Extinguisher
    Spare Tire
    Tire Gauge
    Flashlight
    First Aid Kit
    Portable Air compressor or Air Tank
    I usually have an extra couple bottles of water as well, people easily get dehydrated and like everything else as far as emergency gear and recovery gear goes chances are the gear you carry will be for helping someone else who is in need that was not properly prepared...
    Bastek and crazychris4124 like this.
  14. Apr 19, 2018 at 6:30 AM
    #3254
    harl3ygonewiild
    Harley
    anyone local interested in a set of 285/75r17 mint cooper discoverer at/3 tires? about 34x11
    really nice all terrain just too big for me getting my 265/70s on today
  15. Apr 23, 2018 at 11:05 AM
    #3255
    uurx
    '12 t|x pro
    If anyone here is like me and has been running the trd exhaust with the mudflaps removed, you have probably suffered from some sort of tar & paint from road work and or hard water stains and oxidation from the elements on your exhaust tip.
    well give this stuff a try because :itllbuffout:
    That spring cleaning fever has hit strong around here...
    conifers4 and Bastek like this.
  16. Apr 24, 2018 at 4:12 PM
    #3256
    uurx
    '12 t|x pro
    anyone here? i think owner may be an employee at smithtown toyota.
  17. Apr 24, 2018 at 4:39 PM
    #3257
    crazychris4124
    odd seeing a Taco with a snorkel with no other mods like lightbars or an aftermarket front bumper
  18. Apr 24, 2018 at 4:53 PM
    #3258
    uurx
    '12 t|x pro
    it has some sort of lift and tire package but i did not peak under her panties. i think people put too many lights on these days.
    and funny enough, I feel like it may have had a light bar inside the lower cut out on the factory bumper, the picture cuts it out if i am not mistaken
  19. Apr 24, 2018 at 4:58 PM
    #3259
    uurx
    '12 t|x pro
    same truck, confirmed light bar hah
    truck stalking :drevil:
  20. Apr 24, 2018 at 5:12 PM
    #3260
    crazychris4124
    feel like he needs a nice aftermarket bumper, still looks odd
    Tacoma/Taco likes this.
