Long Life Oil Filters??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PPower05, Jan 14, 2011.
  1. Jan 14, 2011 at 7:29 AM
    PPower05
    PPower05 [OP] Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Recently at WalMart for my latest oil change, and picked up a Fram 10,000 mile oil filter. It says so long as you use fully synthetic oil (I use Mobil 1), you dont have to change the filter for 10,000 miles... What do you guys think?? I know in the commercial trucking business, this is common practice, OTR trucks can go approx. a year w/out filter changes....
    Thanks!
  2. Jan 14, 2011 at 7:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OTR truck engines are engineered completely different than a gas engine. Not a good thing to base oil use on between the 2.
  3. Jan 14, 2011 at 7:33 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Yeah, its good for it according to FRAM..
    I like mobile one, KN and amsoil filters over FRAM anyday of the week if I'm gona trust my oil 10k. I usually go 6-7 on Mobile one or KN.
  4. Jan 14, 2011 at 7:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not worth it for the price of an oil filter in my opinion. Nothing against Fram, I like and use their filters but it's just cheap insurance for your engine. Otherwise Chris is correct, you can't compare our trucks to OTR trucks for something like this.
  5. Jan 14, 2011 at 12:13 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I don't care what brand or type it is.....
    I'm changing my filters every time!
  6. Jan 14, 2011 at 2:36 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    the filter is still going to accumulate the same amout of dirt, as any other filter. I don't get that?? Thats like these new extended OCI's ppl keep talking about. The type of oil you use (or filter) has nothing to do with the amount of wear that is taking place, or the amount of "junk" in the oil for that matter. If you switch to synthetic an think the engine is creating less dirt and moisture than before your wrong. Oil is fouled by moisture as well as a few other items. I think if you use a quality oil, and filter and change it no longer than 5k, you should fair well. IF you are more interested then send off your oil at the end of the interval to a testing lab to see what kind of wear you do have. And it will also tell you if the oil should or needs to be changed. I would do a test with your current filter, check the microns to see what is slipping by then test with the NEW filter to see the difference. Personally I would never use a Fram filter (now that I have seen how they are made and what kind of inferior parts they use.) as they are super cheap, I have seen videos of how they are put together, very cheap. Here check this link out http://minimopar.knizefamily.net/oilfilters/index.html it is very helpful and he has done alot of them now. When I found this site years ago it was awesome to see this. You can also get alot of good info about motor oils from this site http://www.bobistheoilguy.com/cms/ Enjoi!
  7. Jan 14, 2011 at 3:41 PM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    Look for an oil filter rating between 2 to 25 micron, if your brand of oil filter doesn't give you its micron rating then don't buy it.
    You want an oil filter to trap dirt, when you use a higher quality full synthetic oil, it does an excellent job cleaning the engine, but it also needs a high quality low micron rating oil filter to collect the dirt.
    The way I do it is I change the full synthetic oil at 8000-10,000 miles, BUT at every 3000-4000 I change just the oil filter ONLY and just add enough of new oil to replace what I lost just changing the filter.
    I have learned that the synthetic will more quickly fill up the oil filter more quickly and with more dirt cause it does a better job cleaning the engine and I fear of a clogged or bypassed oil filter, I trust the oil, but not the filter.
    There are some high quality brands of oil filters out there, but the Fram brand is on the bottom of the list.
    I think you can figure out yourself what brands of filters are the best cause I don't want to get into a fight with people in this forum if I name some of best brands of oil filters, there is an excellent brand of filter for $3-$4 thats the same as a brand name $20 oil filter, but not going to tell you what brand that is, don't want to fight.
  8. Jan 14, 2011 at 3:45 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i use Mann....7500 mile or 6 months
  9. Jan 14, 2011 at 4:51 PM
    ASE_MasterTech
    ASE_MasterTech Well-Known Member
    Monmouth County, NJ
    2010 TRD Sport DBL\Cab
    Wet Okole seat covers, Westin Platinum Oval tube steps, Rear spring TSB plus Super Springs, D-Rings in all bed bolts, Tailgate reinforcement mod (for loading Harley)
    In today's large/heavy duty trucks, the oil itself may get changed at 100k intervals, this is possible with triple filtration, which illustrates the importance of filtering.
    The oil is changed less frequently because it is a synthetic-blend oil which is not subject to the same 'breakdown issues' involved with 'dino' oils using polymers to achieve the same varied viscosity.
    An oil 'sample' is taken at mileage/hour service intervals, usually determined by filter life, & tested for substances in order to indicate engine component wear/possible failure.
    I would suggest purchasing a quality filter rated at 10k along with quality oil (synthetic) rated at 10k, & schedule a 7,500 mile interval (gives you a little leeway)
  10. Jan 15, 2011 at 5:43 AM
    PPower05
    Perry
    Ranson, WV
    2010 SR5
    Thanks guys, the filter was only like $8.79, so it wasn't like I was paying more than what a conventional filter is.... I think I will be more than fine, I am just going to replace filter and oil as I always do, at 5K miles....
  11. Jan 15, 2011 at 7:15 AM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
    I've been using the Mann too, with Amsoil XL5w30...I'm sticking to the recommended 5000 mile oil change for now until my warranty runs out.
    I noticed last night that Amsoil has redesigned their oil filters so they are compatible with the Toyota engines again.
    http://www.amsoil.com/products/ea_filters/EaFilterStory-2.pdf
    I might have to look into those again, but you can't beat the price of the Mann ($14.95 vs $4.95).
  12. Jan 15, 2011 at 7:16 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    The Fram Extended Guard filter isn't that bad, and built like a Tank. It actually has Metal end caprs and there is a metal screed sandwiched between the filtering media; also it uses a silicone ADBV. This is the only filter of Fram's I'd use and shouldn't be confsued with their crappy orange can or silver extra guard filter; both pieces of crap IMO.
    OP, so are you going to change your oil every 5K and change your filter every other oil change? THe question would be why? If you're going to change the oil, then you might as well change the filter. However, if you are using a high mileage filter and a quality full synthetic, you should be fine running a 10K interval. Once my warranty is up, I might go this route.
  13. Jan 15, 2011 at 7:20 AM
    BartStar
    pa
    Maybe I was too complicated for people to understand, let me try to explain a better way:
    Synthetic oil will clean the internal parts of the engine maybe 10 times better than convential oil, synthetic will pick up and carry and clean the small micron dirt particals that conventional oil will miss, cause synthetic is a uniform much smaller oil molecule in size, it gets into the tight places where conventional oil won't and runs off.
    The oil filter will trap this dirt, BUT a high quality oil filter with a small micron filter media will trap the very small size microns of dirt, where in the other hand a bad oil filter that same small micron of dirt may pass thru the filter media and go back into the engine.
    As the synthetic does an excellent job cleaning the engine and depositing the dirt into the filter the oil filter will fill up more quickly with dirt, now when its full of dirt it goes into bypass and all that dirt inside the filter will pass back into the engine.
    If you're going to keep an oil filter on for 10K miles then I would suggest a cheap, high micron filter and aviod the good filters.
  14. Jan 15, 2011 at 7:20 AM
    crf69
    Ohio
    ummm yeah
    omgosh man thanks i use the eao on my altima with 0-30 once ayear....im using 0-30 once a year and the mann every six months.....excellent results
  15. Jan 15, 2011 at 7:43 AM
    John3
    Maryland
    That's my plan once my warranty runs out. I have always looked at the signature line of oil, but never wanted to spend the money for a 5000 mile oil change. $10.50 a quart :eek: I was thinking about trying out the new Amsoil filters then and change only the filter every six months like you are doing now. It's a small price to pay when you compare it to a new engine.
    Like BartStar said...
    Unless you have a bypass filter system set up, changing the filter frequently is the next best thing.
  16. Jan 15, 2011 at 8:06 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Our engines are no different than the over the road truckers ( internal conbustion) ours use 5.5 qts, there's maybe 10 gals.Ours are low compression there's are high compression.
    The reason they do an oil analysis, and change only the filter, its a cost thing if your using 10 gals of synethic at every oil change, and puting on on 30-40K miles a month,thats alot of oil changes, and down time, v/s a $25 dollar analysis and just a filter. Of course you have to understand the resuslts of the oil analysis.
    Myself I change the filter everytime 5K intervals and use dino oil.
  17. Jan 15, 2011 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are very different. Diesel engines have much different piston ring engineering for one thing. Tolerances are not as tight, they dont use aluminum engine blocks, larger cooling system, etc.
  18. Jan 15, 2011 at 8:47 AM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
  19. Jan 15, 2011 at 8:50 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Trd filter FTW
  20. Jan 15, 2011 at 9:08 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Honestly, after Chris4x4 took a part bunch of filters I am surprised there are still people advising using FRAM
    Bottom line this is why I check so much when buying used cars. Crappy filter crappy oil will wear engine, cost you later in fuel and performance.
    No wonder people get so crappy mileage with our trucks.:rolleyes:
