Long life towing tires?
Discussion in 'Wheels & Tires' started by Dave08, Apr 17, 2009.
  1. Apr 17, 2009 at 6:58 AM
    Dave08
    Dave08 [OP] New Member
    Port ALberni, B.C.
    2008 4X4
    I already have a set of steel rims with yokohama winter only tires and am now looking for a set of quiet, long life summer only towing capable (maybe e-rating?) tires for the aluminum rims. I will be hauling up to 6,000 lbs to Oregon this July and the stock Dunlops have to go. Looks is irrelevant to me, just want a safe, long-life and quiet tire. What works here?
    Thanks,
    Dave08
  2. Apr 30, 2009 at 4:50 AM
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    Any LR. E tire will do fine, if you want them to last a long time run the rear tires @80psi. Will ride like sh!t but will last long time.
  3. Apr 30, 2009 at 5:17 AM
    Brunes
    Brunes abides.
    Rotorhead
    Run them at 80 psi- if that's within the manufactures allowed limts and you want the middle to wear out faster than the edges.
    Run the tires at the right psi and make pressure adjustments when you are towing and most normal load rated E tire or HT/street type tire will probably work out fine.
