Long Live Atkinson Cycle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toyota3.5, Jun 12, 2016.
  1. Jun 21, 2016 at 5:56 PM
    #41
    Manvan
    Manvan Well-Known Member
    Paul
    2016 SR5 double cab
    Today's drive home :
  2. Jun 21, 2016 at 6:18 PM
    #42
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    I only have 1150 miles on my '16 and my calculations so far are within 3/10's per MPG of the on board computer. I was kind of surprised how accurate it is but still plan to calculate my own numbers for a while at least. BTW so far my full tanks have averaged 19.3 MPG but that number has stayed the same even after putting 265/70/17 BFG's on which makes me think I may be getting at least .5 MPG more then when I had stock tires at this point. The tank I'm on looks like it may be closer to 20 MPG even with the taller tires.
  3. Jun 21, 2016 at 6:32 PM
    #43
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    It really does. I was a hyper miler with my diesel jetta, so I know how to make this engine drive efficient. But in the same breath it's really a good transmission and engine combo. The close ratios and the shifter make this thing a blast on the back roads. I find myself just taking them for the fun of it, heel toe rev matching, taking it up to the redline brings you right in the power band of the next gear. It's a blast.
  4. Jun 21, 2016 at 9:08 PM
    #44
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Here's my fuelly in the signature. Why is mine so high compared to all of you assholes?
    I have a lot of alow off road miles, too
  5. Jun 22, 2016 at 4:22 AM
    #45
    ItsSadButDrew
    ItsSadButDrew Well-Known Member
    drew
    2016 access cab TRD offroad
    tire pressure folks.
  6. Jun 22, 2016 at 4:27 AM
    #46
    usadaytrader
    usadaytrader Well-Known Member
    I am getting 21 mixed driving with auto 4x4 v6. less than 1000miles on it so far. Highway driving is around 70-75mph
  7. Jun 22, 2016 at 4:38 AM
    #47
    Tacoma_Jake
    Tacoma_Jake Well-Known Member
    2016 Tacoma TRD OR DCSB
    What are you running for tire pressure in your OR? (Assuming you still have stock OR Tire setup)
  8. Jun 22, 2016 at 6:43 AM
    #48
    perpetualenigma3
    perpetualenigma3 Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    I am averaging between 19-20MPG at 80-85MPH. (on a closed road circuit)<-for the popos out there lol. 20160620_135656.jpg 20160620_131623.jpg
  9. Jun 22, 2016 at 8:40 AM
    #49
    DrVonEvilSatan
    Toyota Truck
    For me 46 front and 40 rear. Last tank was 20, tank before was 20.
  10. Jun 22, 2016 at 8:49 AM
    #50
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Yikes.
  11. Jun 22, 2016 at 9:32 AM
    #51
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I keep my pressure at least 45 psi. With D or E rated tires the psi must be higher to avoid too much flex.
  12. Jun 22, 2016 at 9:42 AM
    #52
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    True...kind of. 45 PSI is too high; unless you're running something like a 50 series.
  13. Jun 22, 2016 at 9:48 AM
    #53
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I am running Toyo LT265-75-16. The tech where I bought them said they should be at 55psi. I told him ya maybe if I had a 6000 Lb truck. We both agreed on 45psi after a beer.
  14. Jun 22, 2016 at 10:36 AM
    #54
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    They should be. They always sell Tacoma's with the gayest tires.
  15. Jun 22, 2016 at 1:34 PM
    #55
    ItsSadButDrew
    drew
    off the lot had 29psi in all 4. i have 38 ft 35 rear right now. i'll report back on mileage soon... only 110 miles so far.
  16. Jun 22, 2016 at 2:33 PM
    #56
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Worse than liters alone, why do they think L/100km makes more sense than km/L?
    We don't say "my truck uses 5 gallons for every 100 miles I drive", we say "I get 20 miles per gallon".
    It's counter-intuitive and goes against our American "bigger is better" philosophy.
    Tcoma16 likes this.
  17. Jun 22, 2016 at 3:34 PM
    #57
    Manvan
    Paul
    2016 SR5 double cab
    Today's drive home. I keep it at or below 1500rpm. Ride in is about 1.5 mpg less. I love it - I love to drive the speed limit that is image.jpg
    PROseur likes this.
  18. Jun 22, 2016 at 3:54 PM
    #58
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Not all of us like the metric system. I am bitter about the whole anti-English system. I can't express enough how much I hate it. Most of us Boomers and older are still using English units.
    Pittrider likes this.
  19. Jun 22, 2016 at 4:27 PM
    #59
    DrVonEvilSatan
    Toyota Truck
    Tires can take 51. It's not optimal for the trucks handling but it's not overkill.
  20. Jun 22, 2016 at 5:24 PM
    #60
    Z50king
    Eric
    Southern California
    Stock and loving it
    Wow I run 35 cold in all 4 and I thought I was high. I will air up to 40 next time. I like less rolling resistance
