Long or Mid travel for overland build?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VolkswagenTaco, Sep 27, 2016.
  1. Sep 27, 2016 at 12:25 AM
    VolkswagenTaco
    VolkswagenTaco [OP] Well-Known Member
    Sean
    Compton
    2012 sr5 4x4 Canadian model with factory locker. Pyrite Mica
    hows it going. I have Been doing a lot of research regarding if I will be going the long travel or mid travel route for my overland surfmobile build. its not like a full prerunner and won't be doing high speed whoops or sand washes not needing three link or four link, more so crawling, mud, sand, rocks, water, rivers. The advantages of the long travel is I would get more travel and a slightly wider track. I don't mind if I have to get glass fenders.
    I'm slightly leaning towards the long travel set up. Not sure about the rear yet... Any more info on the long travel guys like van city would be awesome. ✌️
  2. Sep 27, 2016 at 8:42 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    The price difference between mid travel and long travel is significant. So is the amount of required upkeep. Is is worth the several thousand extra dollars for a couple extra inches of suspension travel, or would that money be better spent on other parts?
  3. Sep 27, 2016 at 8:45 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    My votes on mid.
  4. Sep 27, 2016 at 8:45 AM
    Fonzi25
    Fonzi25 Well-Known Member
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    Agreed I pondered over the same thing for a while then decided I did not need the long travel I still want it but I went with mid travel Icons and had money for more things
  5. Sep 27, 2016 at 8:59 AM
    LunaticConcepts
    LunaticConcepts Well-Known Member
    Georgetown, TX
    2015 Tacoma TSS
    TC LT, Kings, OME, Billies, ARB, stuff
    Ive got LT on mine, but that's because I wanted LT so I can do sweet jumps, and overland lol
  6. Sep 27, 2016 at 9:38 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I would go mid and set the leftovers you would have spent on LT for skids, sliders, lockers, gears..
    Iggy and DustStorm4x4 like this.
  7. Sep 27, 2016 at 9:42 AM
    Pigpen
    Dan
    Northwest Montana
    Sounds like you already know Mid suits your needs better. If you want to be a baller, SAS that bitch.
    4x4Taco09 and DustStorm4x4 like this.
  8. Sep 27, 2016 at 10:15 AM
    VolkswagenTaco
    Sean
    Compton
    Yeah. Seems like most these guys overland builds have mid travel with King or ivd 2.5" coilovers do the job even at all the gnarly 4x4 spots like Moab and tahoe and Colorado etc.
    Im leaning as far as mid travel,
    towards the king extended travel 2.5 with adjusters, total chaos uniball upper arms and a 650 pound spring for a winch and bumper.
    Anyone know about the new camburg upper control uniball 1.25 arms or would recommend the total chaos as it seems most people are running?
  9. Sep 27, 2016 at 11:17 AM
    Fonzi25
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    If your doing bumper and winch I would do 700lb coils im on 650s without anything up front
    RacecarGuy likes this.
  10. Sep 27, 2016 at 12:58 PM
    VolkswagenTaco
    Sean
    Compton
    Straight axle would be badass. This is a daily driver also.
  11. Sep 27, 2016 at 5:36 PM
    Pigpen
    Dan
    Northwest Montana
    Even better.
    Mine will remain IFS. Mid travel with shackle flip is my plan. Very versatile with a reasonable price tag.
  12. Sep 27, 2016 at 5:49 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Most the most bad ass overland second gen's on here have long travel setups. If your keeping stock lower arms mid travel will be cheaper if your going aftermarket lca's the only thing your saving on is the cost of axles. I originally went mid travel with aftermarket lca's I should of just gone lt from the get go, but I didn't want to mess with axles. You also may save on fenders, but even if I was midtravel I'd have McNeil +2 glass (I still have a brand new set sitting in the shop from before I decided to go lt) but that's just cause I'm not a fan of butchered fenders, unless you go legit like @clupi. Like everyone said, you don't need lt. But my truck rides way better on and off the road with my lt kit than it did with my mt and short of arm lengths they both had equally high end components.
    If you have the money go lt. The amount of expendable money everyone has is different so to some an extra 1-2k is a lot. To others it's just one more weekend of overtime.
    stumbles likes this.
  13. Sep 27, 2016 at 9:52 PM
    VolkswagenTaco
    Sean
    Compton
    Thanks for your insight. I appreciate it.
  14. Sep 27, 2016 at 9:53 PM
    VolkswagenTaco
    Sean
    Compton
    Can you post some pics off yours if possible. ✌️
  15. Jan 9, 2017 at 9:40 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Will a 2+ long travel with 700lbs Spring handle differently on the road compared to an old man emu with sway bar ?
