Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. Nov 3, 2023 at 12:59 PM
    #2141
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Got a kestrel 5700 elite with AB. I still prefer Sterlok. Try to get it through the huawei app store.
    Hornady 4dof was an option but just terrible ui
    FishingInSand and smugly like this.
  2. Nov 6, 2023 at 8:33 AM
    #2142
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    You can still download the APK from other sources, it's just not on the app store.
    smugly[QUOTED] likes this.
  3. Nov 6, 2023 at 8:42 AM
    #2143
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    Upper platform at the range Saturday. This one reaches out to 1380. 6.5 cm was running about 50% hit rate. Not great but a shifting wind was messing with me causing horizontal miss. Target is a full size steel ipsc 20231104_101824.jpg 20231104_102723.jpg
    Sig45, Tnc, -Rorschach- and 1 other person like this.
  4. Nov 6, 2023 at 8:58 AM
    #2144
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I saw that...
  5. Nov 6, 2023 at 9:02 AM
    #2145
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Means you were over 9 inches off on call. Which is like only .25 mils ( not moa).
    In a similar condition, try timing the shot in the high wind if it’s a long peak gust, or in the pause if it’s a long calm. Helps with hit percentage if you’re not on a timer.
    Imo that’s why the kestrel is such a good tool, with the avg/high data.
  6. Nov 6, 2023 at 9:15 AM
    #2146
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    It will make sense to use your kestrel when you get laser range finding binos and you can 1 tap for an instant solution
  7. Nov 6, 2023 at 9:17 AM
    #2147
    FishingInSand
    Corey
    Temecula
    06 now with 4x4
    Wind is the great equalizer! The nightforce elr match in June is a blast! This past year's match we had about 30 mph gusts when we got to the 2300 yard target lol
  8. Nov 9, 2023 at 6:24 PM
    #2148
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Before and After.
  9. Nov 13, 2023 at 8:27 AM
    #2149
    smugly
    Doug
    Nice build. What scope are you running on there?
