Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. May 14, 2018 at 6:47 PM
    #601
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    4 times easier. No having to measure the 10 feet and timely set up , and I got much more accurate results. Definitely worth the money.
    azshooter40 and oni06 like this.
  2. May 14, 2018 at 6:47 PM
    #602
    oni06
    oni06 Well-Known Member
    Easier. Just make sure its on properly so you don't shoot it.
    smugly likes this.
  3. May 14, 2018 at 7:18 PM
    #603
    smugly
    Doug
    I will state that after doing a lot of homework and reading reviews between the different models, it made it easier to pick the V3 over the sportster, The sportsters had a lot of movement issues where as in the V3 it just wasn’t an issue.
  4. May 14, 2018 at 7:20 PM
    #604
    oni06
    Good choice
  5. May 17, 2018 at 9:26 AM
    #605
    Mac1owry
    Mac1owry Well-Known Member
    Corpus Christi TX
    2012 Baja TX
    all listed. it's a quick change bolt head, multi caliber/cartridge set up.
    my AI is as well, but only with standard bolt face cartridges in a short action.
    both quick change barrels.
    smugly[QUOTED] likes this.
  6. May 18, 2018 at 7:36 AM
    #606
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    When did a quick change bolt head with exchangable barrels become a choice for anything that has to do with accuracy?
    smugly likes this.
  7. May 18, 2018 at 7:38 AM
    #607
    Nomad_Pilot
    Clay
    Ft Collins
    This is a legitimate question. Not trying to ruffle any feathers.
    smugly likes this.
  8. May 18, 2018 at 8:40 AM
    #608
    Mac1owry
    Corpus Christi TX
    2012 Baja TX
    Barret. Desert Tech(DTA), Accuracy International(AI).savage has been doing it for awhile.
    I got my Accuracy International AX in 2013. it's been my main competition rifle since.
    the BigHorn TL2-3 came out awhile back.
    its more of a consistent platform for me. instead of have 3+ rifles/scopes/chassis, etc... just have 1, with interchangeable barrels I can swap myself.
    my gunsmith chambers a bunch of barrels for me. that I can swap out myself. its a wear item anyways.
    P2W likes this.
  9. May 18, 2018 at 2:37 PM
    #609
    smugly
    Doug
    I am assuming then, you have to re-zero your scope every time you re-barrel, correct?
  10. May 18, 2018 at 2:47 PM
    #610
    Nomad_Pilot
    Clay
    Ft Collins
    That's what I was just thinking about lol
  11. May 18, 2018 at 5:38 PM
    #611
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Depends on the muzzle velocity, if your with 50-100fps the shift is not that big depending on the caliber selection the data may be close as well.
    As an example my 556 75gr DMR load is within 0.2 mil of my 175gr 308 out 750yds
    But yes you would recheck yer zero after a cal change, I check my zero every time I go to the range, right after I run a coldbore.
    wilcam47 likes this.
  12. May 18, 2018 at 7:48 PM
    #612
    Nomad_Pilot
    Clay
    Ft Collins
    Your a better man than me. I am a one woman, one caliber rifle kinda guy
  13. May 18, 2018 at 9:46 PM
    #613
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I just dont like the confusion...If I pick up my 270 I know its a 270. I dont want it in 3 or 4 different calibers, then find out the hard way its not what I was intending on shooting.
    Nomad_Pilot[QUOTED] likes this.
  14. May 19, 2018 at 4:32 AM
    #614
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Yes, the possibility of bringing the wrong ammunition to the range is increased. I double check everything the night before when I setup my kit.
  15. May 21, 2018 at 10:37 AM
    #615
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    TBH, I'm with you on this one. I plan to have one case, one gun, many barrels. If they end up having repeatable POI between installations (They should, if they were made by anybody with more skill than your average HS shop student), you don't even necessarily need to rezero, just establish dope relative to your original caliber/load.
  16. May 21, 2018 at 11:04 AM
    #616
    smugly
    Doug
    :eek:
  17. May 21, 2018 at 11:33 AM
    #617
    Dom Mazzetti
    Dom Mazzetti Well-Known Member
    Dom
    Do you think i could build a complete long range rifle (including optics) for under 1k?
  18. May 21, 2018 at 11:35 AM
    #618
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Depends on what you consider long range mostly.
    My tikka in 308 will shoot 3/4in groups at 100 yards. Ive shot it out to 1k and been happy with the results. I have about $800 into it w/ glass.
    Thrres also this guy and a bunch of others on YouTube that have done similar stuff.
    https://youtu.be/ZNVw2Cnyns8
    Dom Mazzetti likes this.
  19. May 21, 2018 at 11:43 AM
    #619
    Dom Mazzetti
    Dom
    awesome, can i get some details on your build?
  20. May 21, 2018 at 11:58 AM
    #620
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    ?? You may could grab SWFA optics for $300 or so?
    Rem700 is easy to work with,but I changed stocks,trigger,and added little better optic.i would say $1500-but depends on what you want.
