Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. May 24, 2018 at 3:00 PM
    #681
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Heck, I couldn’t reacquisition my target to see the verified impact without it.
  2. May 24, 2018 at 5:02 PM
    #682
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    That's what sucks about my gun. It's a tack driver out to about 1200, but if i shoot at anything less than about 600 i cant see the impact.
  3. May 24, 2018 at 5:04 PM
    #683
    Nomad_Pilot
    Clay
    Ft Collins
  4. May 24, 2018 at 5:08 PM
    #684
    smugly
    Doug
    That’s why I kept the break on mine, so I could see those inside 600 yard shots
  5. May 24, 2018 at 5:09 PM
    #685
    smugly
    Doug
  6. May 24, 2018 at 5:28 PM
    #686
    Nomad_Pilot
    Clay
    Ft Collins
    Yeah no shit right?? But of all the tests I have read, that one is always at the top for both 308 and 300
    smugly likes this.
  7. May 24, 2018 at 7:24 PM
    #687
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    X3
  8. May 24, 2018 at 11:03 PM
    #688
    Nomad_Pilot
    Clay
    Ft Collins
    Well i scoured the internet for about 30 minutes now, i cant find one instance were a lantac is being used on a 300 win mag, or a bolt action rifle period.
  9. May 25, 2018 at 3:33 AM
    #689
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Josh @ Patriot Valley makes them specifically for the 3Win
    Don’t just go by the cost, his brakes do not use a crush washer or shims to index it. The brake uses a double nut configuration, thread the brake on to index then seat the nut against the barrel shoulder to lock it down.
    smugly likes this.
  10. May 25, 2018 at 3:34 AM
    #690
    smugly
    Doug
  11. May 25, 2018 at 9:38 AM
    #691
    Nomad_Pilot
    Clay
    Ft Collins
    Hmmmmmm
    Edit: yep, gonna be buying that https://youtu.be/XzzNCRPuqLk
    P2W[QUOTED] and dumontrider like this.
  12. May 31, 2018 at 5:08 AM
    #692
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    I'm amazed with how much that brake reduced recoil. Making 300WM easy.
    smugly likes this.
  13. May 31, 2018 at 6:05 AM
    #693
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    What do you guys think about using a 4-16 scope out to 1000 yards? I am gonna go to a range and qualify out to 1000 yards but want to be sure I wont have issues with the scope. I'm using a savage model 10 T-SR in 6.5 Creedmoor with a Vortex Viper HST
  14. May 31, 2018 at 6:12 AM
    #694
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    A few words from people more knowledgeable than I on the subject:
    http://8541tactical.com/magnification.php/
    TL;DR: Yeah, I think a 4-16 will do fine. I've heard of guys using very low mag (3-4x) at long ranges to prove a point.
    smugly and Sleipnir[QUOTED] like this.
  15. May 31, 2018 at 6:17 AM
    #695
    smugly
    Doug
    Have you looked though it @ 1000 yards? If you can see the target fine, than it works for you. Do remember, the higher the power, the less eye relief and vertical turret travel you'll have. (generally speaking) The turret travel wouldn't necessarily be an issue @ a 1000 yard, but if you wanted to go out farther, ( and the round is quite capable of it) It might become an issue if your scope is not canted when you get into higher powers.
    Sleipnir[QUOTED] likes this.
  16. May 31, 2018 at 8:18 AM
    #696
    JimmyAGR
    JimmyAGR Well-Known Member
    Jimmy
    2016 Taco ORD DC
    I use a 5x25 Night Force at 1000, but I keep the magnification to around 12-14 power. This gives me a better field of view and less mirage. I only crank it up to max when I need to see where I am hitting the target without using a spotting scope.
    Sleipnir[QUOTED] and smugly like this.
  17. May 31, 2018 at 9:31 AM
    #697
    Nomad_Pilot
    Clay
    Ft Collins
    They don't sell that model any more, nowe they sell one called an inducted something or nother. They say it outperforms the other one though soo
  18. May 31, 2018 at 9:31 AM
    #698
    Nomad_Pilot
    Clay
    Ft Collins
    I don't think you will have any problems doing that once you get it dialed in
  19. May 31, 2018 at 10:21 AM
    #699
    oni06
    oni06 Well-Known Member
    Please explain how magnification effects the total amount of turret travel?
    If I have 15 Mil elevation in my turret @ 6x I am still going to have 15 Mil of elevation in my turret @ 24x.
    I ask because in the past 10+ years I have never heard anyone say you lose/gain turret travel based on your magnification setting.
  20. May 31, 2018 at 10:29 AM
    #700
    oni06
    As others have said you should be fine. Most PRS/NRL shooters tend to have their scopes set around 15-16x most of the time.
    Something to note though. The Viper HST is second-focal-plane. Basically the reticle is only accurate at one magnification setting (usually max magnification).
    If you are dialing your dope (elevation and wind) then there is no issue as you will always hold at the center of the cross hairs on any magnification.
    However if your holding for elevation and/or wind then your reticle will not be accurate unless the scope is at max magnification.
