Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. Jul 12, 2018 at 6:46 AM
    #801
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    I get that, it's one of the reasons I'm happy sticking to .223 right now. Supply is rarely an issue.
  2. Jul 12, 2018 at 6:51 AM
    #802
    Mac1owry
    Mac1owry Well-Known Member
    Corpus Christi TX
    2012 Baja TX
    yup, actually this rifle was initially .223. I love shooting .223. helps you learn to read wind better.
    this is a switch bolt head/barrel type rifle build.
    azshooter40 likes this.
  3. Jul 12, 2018 at 7:02 AM
    #803
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    That's cool. I've thought about doing a similar thing with my axis. The cheap and easy availability of donor rifles means that I could feasibly have one rifle and multiple barrels for it, all I'd have to do is use a Barloc or similar to switch cartridges on the fly. And I REALLY would love to build the world's first 7SAUM Axis. All things in time...
  4. Jul 19, 2018 at 11:43 AM
    #804
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Chassis expected to arrive Wednesday. Hoping to take it out Thursday with some new development loads and get started on making these ELD's sing.
    oni06 and smugly like this.
  5. Jul 24, 2018 at 11:23 AM
    #805
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    So Im trying to learn some stuff about reloading. A friend has a 6.5 creedmore and is working with different powders with 140grain bullet. Is there a specific powder or powder load that holds really good groups? Also should you look for muzzle velocity or accuracy down range? He's got a bunch of different powders, I just wondered what is the best muzzle velocity and accuracy with the 140gr bullet? Thanks.
  6. Jul 24, 2018 at 11:27 AM
    #806
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    According to precisionrifleblog.com, PRS shooters send 140gr rounds at 2770ish out of most 6.5's. I know that H4350 does well for that application. I think the formula I've heard works very well is a berger 140gr hybrid over H4350 and a CCI 450 primer, in Lapua brass. 6.5 Creedmoor or 6.5x47 Lapua.
    smugly and wilcam47[QUOTED] like this.
  7. Jul 24, 2018 at 2:40 PM
    #807
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    You need to tune the load to the rifle. Find a powder and projectile you would like to work with. Load up some rounds, I usually will do 0.2 grain steps I start just below max published and go up. Don’t get too wadded up about chasing velocity, your gun may like 2725 maybe it likes 2780, I’ve gone through as few as 20 rnds tuning a load and as many 50+ I would look for accuracy more so than velocity
    wilcam47[QUOTED] and smugly like this.
  8. Jul 24, 2018 at 3:10 PM
    #808
    oni06
    oni06 Well-Known Member
    H4350 is the go to powder as stated above.
    I have run it with .260 Remington (6.5mm), .243 Winchester (6mm), and 6x47L (6mm) with great results.
    As @P2W stated accuracy over velocity. If you find a load that shoots good @ 100 yards then also test further out to make sure it works at distance as well.
    P2W likes this.
  9. Jul 24, 2018 at 4:17 PM
    #809
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I don’t know if I would categorize one powder being better over another because they will perform differently form one barrel to another and that’s part of the fun and the Chase is figuring out what is optimum for your barrel but most people tend to gravitate towards this powder although it seems quite hard to find, probably because they’re all looking for it! LOL
    Edit, sorry guys I didn’t see all your responses above
    wilcam47[QUOTED] and oni06 like this.
  10. Jul 25, 2018 at 10:52 AM
    #810
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Baboom! Bad picture, but the XLR chassis looks dope. We'll see how it affects groups soon I hope.
    dumontrider, smugly and P2W like this.
  11. Jul 25, 2018 at 11:10 AM
    #811
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    45gr RL19 with a COL of 2.835 I have found to make the smallest groups with my 6.5 CM (~2700fps)
    EDIT: with 140gr Nolser RDF.
    EubeenHadd, oni06[QUOTED] and smugly like this.
  12. Jul 26, 2018 at 9:39 AM
    #812
    Mac1owry
    Corpus Christi TX
    2012 Baja TX
    you want to look for an accuracy node. first find a node with a low ES(extreme spread) for multiple charges. then fine tune by adjusting the bullets seating depth from there, to shrink the group.
    that's how you'll find a consistent load. like other have said. I wouldn't chase speed. chase consistency, repeatability, reliability.
  13. Jul 26, 2018 at 9:43 AM
    #813
    wilcam47
    Will
    Bourbon state
    I figure velocity doesnt matter, just accuracy. If you chase velocity then your accuracy might change...
    is the H4350 good in different temps? Thats what Im reading is the H4350 is what most people like.
  14. Jul 26, 2018 at 9:50 AM
    #814
    Mac1owry
    Corpus Christi TX
    2012 Baja TX
    h4350 is very good/popular. it's temperature insensitive.
    fyi-i'd don't normally load develop until after 100-150 rounds. break in the barrel, cause they tend to speed up around then. so I do it afterwards.
    smugly and wilcam47 like this.
  15. Jul 26, 2018 at 9:51 AM
    #815
    wilcam47
    Will
    Bourbon state
    good to know.
  16. Jul 26, 2018 at 9:52 AM
    #816
    wilcam47
    Will
    Bourbon state
    If anyone has some Rcbs 300 win mag dies for sale cheap let me know ;)
  17. Jul 27, 2018 at 4:01 PM
    #817
    smugly
    Doug
    This is a perfect example of one rifle preferring a certain combination over other rifles. You can clearly see the my 6.5 prefers the IMR powder over the H powder
    F0443EAD-BDDB-45A1-B897-98AED2D4BB92.jpg A2FFC9EC-5984-4ADB-BA89-840EC483CA5C.jpg
    That was today’s fun project trying 7 different loads
    wilcam47[QUOTED] and TACOVRD like this.
  18. Jul 27, 2018 at 4:12 PM
    #818
    Crazyhorse6901
    Crazyhorse6901 Fuck It...
    Lee
    Hampton,Va
    At this point clueless...
  19. Jul 27, 2018 at 4:31 PM
    #819
    smugly
    Doug
    22LR?:D
    NC15TRD and oni06 like this.
  20. Aug 11, 2018 at 4:23 PM
    #820
    smugly
    Doug
    Did some camoing to day!
    Coolerman, wilcam47, P2W and 2 others like this.
