Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. Oct 16, 2019 at 2:59 AM
    #1301
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I never did. Never trusted other people’s calls unless I knew they were solid in their shit. I’d use my kestrel to collect readings between stages. On my wrist where my dope print off usually is, I’d have 5, 10 and 15 mph on wind for all my interpolate between usually, but when I started prs I had kestrel Horus and now (for awhile) AB.
    So it’s a little bit of a head start but if wind is off for whatever reason, then I can interpolate between my dope card and the kestrel dope. The wind reading struggles, for me anyways, is at ELR distances. I’ve always just been so so with reading mirage and terrain.
  2. Oct 18, 2019 at 7:50 PM
    #1302
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Am I turtley enough for the turtle club? Bergara B14 in 6.5CM with a Weaver 3-10x mil/mil. Gonna go get a zero on it this weekend!
    Chew, whitebread, P2W and 4 others like this.
  3. Oct 18, 2019 at 8:22 PM
    #1303
    corprin
    corprin Well-Known Member
    corprin
    That’s pretty
    Gunshot-6A likes this.
  4. Oct 18, 2019 at 8:48 PM
    #1304
    Gunshot-6A
    Conner
    Everett, WA
    Best part was that it was on the consignment rack for a couple hundred off new and still had packing grease on the bolt! It was a safe queen for someone.
    P2W and Adventurer_Alex like this.
  5. Oct 18, 2019 at 9:35 PM
    #1305
    dfanonymous
    Any chance you’ll be running a tall target test on that scope when you go to zero?
    Gunshot-6A[QUOTED] likes this.
  6. Oct 19, 2019 at 7:02 AM
    #1306
    Gunshot-6A
    Conner
    Everett, WA
    I wasnt planning on it. I did use a plumb line after mounting to confirm alignment and any minor variation will have minimal effects at distance as compared to the guy holding the stick in the first place.
    shane100700 likes this.
  7. Oct 19, 2019 at 12:14 PM
    #1307
    Gunshot-6A
    Conner
    Everett, WA
    Broads with NODs. Hawt
  8. Oct 19, 2019 at 3:02 PM
    #1308
    dfanonymous
    A tall target is for tracking error. All scopes have them in one way or another.
    Having a level scope is nice though.
    Gunshot-6A[QUOTED] and Chew like this.
  9. Oct 19, 2019 at 5:00 PM
    #1309
    Gunshot-6A
    Conner
    Everett, WA
    Oh, I got you. I always heard that called a tracking drill.
  10. Oct 19, 2019 at 5:52 PM
    #1310
    dfanonymous
    Dammit I hate typing.
    No, just shooting in a horizontal and vertical line to establish tracking is kind of like just seeing if there is noticeable error, and maybe measuring. This can be done at different distances, and is referred to as a box test.
    Running a tall target, you are at your zero distance more than likely and it is critical to measure your actual distance. So leave the range finder and just use some engineer tape to mark out 100y/m or whatever you fancy.
    Shoot group to establish zero, then mark up 10 mils or 30 moa, shoot group and measure center to center of group.
    Since you using mrad let’s say you’re measurement between the two groups was 37 inch, but 10 mils is 36 inches at 100y.
    The formula for the correction factor would be something like this 10 milsx100yx.03599(constant)= 35.99
    Then to get the correction factor divide this number by you’re group measurement...
    So 35.99/37 inches= a correction factor of .9727
    That’s you tracking value. You’re not dialing one mil, you’re dialing .9727 mils and you can add that into your firing solution.
  11. Oct 19, 2019 at 7:42 PM
    #1311
    corprin
    corprin
    You’re number e^(2pi*i)!
    #marriedtomathematician
  12. Oct 19, 2019 at 8:54 PM
    #1312
    dfanonymous
    #calculatorshavefeelingstoo
  13. Oct 21, 2019 at 7:00 AM
    #1313
    corprin
    corprin
    This was fun.
  14. Oct 21, 2019 at 7:08 AM
    #1314
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    I have absolutely hate the boat stages. At one of the Guardian matches three or four years ago, they had an actual boat strung up by three points - that was way easier to shoot off. Those hanging platforms are the worst. By the time you start to figure it out, there is one shot left in the stage. :rofl:
    P2W, Gunshot-6A and shane100700 like this.
  15. Oct 21, 2019 at 7:44 AM
    #1315
    corprin
    corprin
    I went 3/4 on that thing at a 633yrd IPSC(?). Also cleared a 5 target 8-2” KYL stand at 630yrd in 7rds with a double strike on the 4” because I forgot what target I was on. Oops
    P2W and whitebread like this.
  16. Oct 21, 2019 at 7:54 AM
    #1316
    Gunshot-6A
    Conner
    Everett, WA
    Ah, boats are a little tricky, but I got absolutely slayed by a polish plate rack at a 2GAM competition.
  17. Oct 21, 2019 at 9:53 AM
    #1317
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    We did something similar to that by suspending a picnic table from the rafters of the shooting pavilion
    Another devious stage we came up required you to tie a Swiss seat, you were then carabined into a rig and suspended from the roof. Your only support was the 8x8 post in front of you. Engage 5 targets from 375 - 675 with 10 rnds bonus points for clearing the targets with rnds left over 90sec, clock starts on the first shot
  18. Oct 21, 2019 at 11:34 AM
    #1318
    corprin
    corprin
    Clock should have started whe
    Should have started 10’ from Swiss seat. Evil laugh for watching balls getting crushed.
    P2W[QUOTED] and Gunshot-6A like this.
  19. Oct 21, 2019 at 12:24 PM
    #1319
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    funny you should mention that,..
    One of our LEOs decided not to use our 25mm line for the Swiss seat and wanted to use his own 10mm,.. We warned him, but no
    Took about 10sec from when we loaded the over head rig for him to start yellin in much higher pitch “I can’t feel my nutts!”
    “Feck you all, This isn’t funny you guys, my nutts!”
    “Somebody get me down, oh damm! My nutts!”
    One of the other LEOs in the group says not before we get a picture for the board
    Adventurer_Alex and Gunshot-6A like this.
  20. Oct 21, 2019 at 3:59 PM
    #1320
    corprin
    corprin
    Yeah, me and Swiss seats go waaaay back. Will spare the details.
    There’s a reason I climb, belay, rappel, etc in my black diamond :)
    Only good about the Swiss seat is Aussy style, and I have ZERO reason to do that again. At this point in my physical prowess, it’s ranked right there with fast roping... in the “yeah kids, I’ve done that before” box.
    Adventurer_Alex and shane100700 like this.
