Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. Feb 14, 2020 at 6:54 AM
    #1601
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    What magazine is in there? I wasn't aware of a polymer magazine that would work with the AX platform (double feed with a lip on the front of the magazine).
  2. Feb 14, 2020 at 7:11 AM
    #1602
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Never post here but always try to stay up to date on the posts and vast amounts of info here. Wednesday there was no wind so I shot a few rounds off (sitting on the ground bi-pod, back leaned up against a tree.) Ended up 7 for 7 on apples at 300yrds with 1st one being cold bore. Was pretty happy with that. 6.5 CM Franken AR-10. Nowhere near the long range y'all shoot but was good for me. Hope to stretch out some long shots when summer rolls around.
    Chew and whitebread like this.
  3. Feb 14, 2020 at 7:46 AM
    #1603
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    A 2.5" target at 300 is definitely precision shooting, whether or not it's at "long range." That's a small target.
    Chew likes this.
  4. Feb 14, 2020 at 7:49 AM
    #1604
    mightytacoman
    Kel
    4.5L 1grfe
    mehh I'd say they were closer to 3" apples give or take a bit
    Martyinco likes this.
  5. Feb 14, 2020 at 7:54 AM
    #1605
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Ah fine then, you suck that's a massive target lol
    Still props, mighty fine shooting.
    Chew, corprin, Martyinco and 2 others like this.
  6. Feb 14, 2020 at 12:18 PM
    #1606
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Anyone in need of a 6-9 or 9-13 harris bipod? I have 2 I need to get rid of since I came into possession of an atlas.
    Both have notched legs, and the 9-13 has the adjustable cant. The 9-13 was installed and safe queened, the 6-9 has had maybe 3x out on the range.
    Thinking like $60 shipped for the 6-9 and $80 for the 9-13
    Pics when I get home from work.
  7. Feb 17, 2020 at 7:01 PM
    #1607
    corprin
    corprin Well-Known Member
    corprin
    long range for rimfire...
    Put the deposit on a home for this little bit of unobtanium I’ve had for years.
    Gunshot-6A and P2W like this.
  8. Feb 17, 2020 at 7:40 PM
    #1608
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Ok, I give, what is it?
    I see elevation and windage adjustments, so I'm guessing some kind of scope/site mount?
  9. Feb 17, 2020 at 7:51 PM
    #1609
    SitrucR
    SitrucR Well-Known Member
    Denver
    2019 OR DCSB 6MT
    OME/Dakar
    Leupold’s new MK5 line is a much needed departure from the overpriced-underspec’d stuff from the old Mk6/mk8. Really good glass and turrets, especially for the money (NF guy, so not a biased opinion).
  10. Feb 17, 2020 at 8:09 PM
    #1610
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I agree and I’m aware. I had a mk5 that I sold on sniperhide. Still for $2000 there’s other options out there. However my bias is towards the mk4 and the amount I seen go down, and the malarkey of the company as a whole. Like their lawsuit against nightforce. Also the misconception that they’re a more “American company” because they turn their own scope tubes and turret caps. So what? All the other parts are still from Asia.
    SitrucR[QUOTED] likes this.
  11. Feb 17, 2020 at 8:21 PM
    #1611
    corprin
    corprin
    It’s a rear aperture sight assembly.
    I emailed Merit to see if they still have a #4 adjustable iris lying around. If not I might spring for a Gehmann or rob the Merit I have on my 40x.
    On edit: I got the black MDT vertical grip with my ACC and I’m not happy with its girth vs my dainty paws. Installed and used for a 40rd range day. Mounts to AR style interface. $40 shipped, check and PayPal gift welcome.
    https://mdttac.com/us_en/mdt-vertical-grip.html
    Chew[QUOTED] and shane100700 like this.
  12. Feb 18, 2020 at 5:51 AM
    #1612
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I've got the MPA non-adjustable equivalent. It wouldn't mount to my XLR but putting it on my AR for feel felt great. I'm kinda tempted to modify it to take the spring/detent so I can build out a precision AR, but realistically I should just pick up an Oryx Chassis, throw it on there, and shoot more.
  13. Feb 25, 2020 at 11:18 PM
    #1613
    token3495
    token3495 Well-Known Member
    Kevin
    Snohomish
    08 4Runner
    My recently built lefty 7 SAUM
  14. Feb 26, 2020 at 6:02 AM
    #1614
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Whatcha got planned for it? That barrel and cartridge scream hunting, but the tripod, chassis, and trigger look very PRS.
  15. Feb 26, 2020 at 6:11 AM
    #1615
    BCV
    BCV Active Member
    2014 Tacoma Texas Edition
    Here’s one of my LR rigs
    CRASHMAN50, Chew, token3495 and 4 others like this.
  16. Feb 26, 2020 at 2:01 PM
    #1616
    token3495
    Kevin
    Snohomish
    08 4Runner
    It will eventually be a hunting rig and occasional non-competition long distance rifle. I’m still deciding on what stock to go with but leaning towards a manners. I just grabbed a bunch of my spare PRS gear to start load development and store it upright in my safe.
  17. Feb 27, 2020 at 5:28 AM
    #1617
    mightytacoman
    Kel
    4.5L 1grfe
    Maybe a dumb question- Does storage position of a rifle make a difference in accuracy?
  18. Feb 27, 2020 at 7:23 AM
    #1618
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    no,..
    smugly and Chew like this.
  19. Feb 27, 2020 at 7:32 AM
    #1619
    Gunshot-6A
    Conner
    Everett, WA
    New scope mounted up! She drives tacks but she's a heavy bish. A cruise ship is missing its anchor somewhere, esp with this new 3 pound scope.
    3-18x50 Vortex Razor
  20. Feb 27, 2020 at 7:34 AM
    #1620
    mightytacoman
    Kel
    4.5L 1grfe
    When he specifically mentioned storing upright in a safe. It has me second guessing my ways lol
