Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. May 15, 2020 at 12:04 PM
    #1781
    corprin
    corprin Well-Known Member
    corprin
    Be cautious, be safe. A few #itsascam folks at the match I attended last Saturday are now showing symptoms.
  2. May 15, 2020 at 12:07 PM
    #1782
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I never wish ill on anyone, but this reaping of Karma makes me feel a little warm inside right now.
    Speaking of though, went to the store. All the 6.5cm is gone like the wind. :mad: As is the 8mm Mauser.
    Sig45 likes this.
  3. May 15, 2020 at 12:46 PM
    #1783
    corprin
    corprin
    Yeah. They all mocked me for my mask and staying the eff away from them.
    I get 6.5 CM, but 8mm Mauser?!?
    Then again I had a bunch of Nosler Custom ammo loaded for my K98k A few years back. Still have 110rds of that batch. Since I shoot it once a decade or so...
    Gunshot-6A[QUOTED] likes this.
  4. May 15, 2020 at 12:47 PM
    #1784
    Gunshot-6A
    Conner
    Everett, WA
    I know. That and 30-30 is all stocked out. They didnt carry that much of it on a good day but still...
    But SGAmmo had a bunch. Got a fresh stock on the way.
  5. May 15, 2020 at 1:09 PM
    #1785
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    @corprin I know there were some unofficial/hush-hush matches around here. I didn’t participate.
  6. May 15, 2020 at 5:46 PM
    #1786
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    The goal here is to try to take my first firearm and make it what I wanted from it when I bought it (before I knew anything), knowing that I'll likely never make up the difference in price, and incorporate what I've learned since then while trying out a variety of setups. The next rifle will be more economical/sensical.
  7. May 17, 2020 at 10:52 AM
    #1787
    huskyhog0317
    huskyhog0317 Well-Known Member
    A Constant Nightmare
    2020 Tacoma TRD Pro
    Yea I figured as much. I ended up ordering a 20 Tacoma TRD Pro to drive around while I'm here (should be in later this month). Figured once it becomes a problem back in the states with range days, I'll trade it in for a LB OR or Tundra.
  8. May 22, 2020 at 5:58 PM
    #1788
    all_mota
    all_mota @def.hub
    2020 Taco TRD OR(Quicksand)
    Was finally able to shoot what I've been putting together.
  9. May 22, 2020 at 6:02 PM
    #1789
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    TRD493, huskyhog0317 and shane100700 like this.
  10. May 24, 2020 at 11:55 AM
    #1790
    corprin
    corprin
    What is your budget and what is your goal?
  11. May 25, 2020 at 7:25 AM
    #1791
    huskyhog0317
    2020 Tacoma TRD Pro
    Beautiful.
    How do you like the DMR308 stock? I was thinking about grabbing the 556 version for my MRP.
    all_mota[QUOTED] likes this.
  12. May 25, 2020 at 7:47 AM
    #1792
    all_mota
    all_mota @def.hub
    Thank you. I really like this stock. Very well made, the controls that adjust the cheek riser and shoulder pad feel solid and have a nice locking stick in between the different settings. The other nice thing about this is that it allows you to use a standard buffer extension.
    huskyhog0317[QUOTED] likes this.
  13. May 25, 2020 at 5:12 PM
    #1793
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    You using factory ammo?
  14. May 25, 2020 at 5:50 PM
    #1794
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Nope. 6x47 Lapua - I need to use 6.5x47 brass and neck it down to 6mm.
    oni06 likes this.
  15. May 26, 2020 at 7:59 AM
    #1795
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Minimal, and configure it for Mammoth Sniper Challenge .308 B-shooter (plus look like the "Sniper Rifle" I wanted as a kid). I figure I want to throw another 300-400 at the gun (stock and .308 magazines) to finish it out after I've got the barrel mounted/threaded/brake attached. After that, shoot it til the barrel is shot out or I start making enough to pick up a BigHorn Arms action and build a homebuilt custom. Mammoth means lower weight is good and I only need to engage to 800 yards, which should be more than doable with good bullets.
  16. May 26, 2020 at 8:16 PM
    #1796
    corprin
    corprin
    I don’t want to sway your opinion or push you one way or another. It’s your rifle, and your money, so it’s your choice.
    Out if the box Savages are good enough for most. I have confidence and repeated experience hitting IPSC silhouettes at 1170yrds with my 12lrp in .260.
    If you are ping straight budget rifle with goals of Zermatt/Bighorn down the road. Get a used Remington 700 SPS Varmint .308 with a <1k round count. Then all your mods will work when it’s time for a new barrel in 4-5k rounds.
    EubeenHadd[QUOTED] likes this.
  17. Jun 3, 2020 at 10:12 AM
    #1797
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
  18. Jun 3, 2020 at 5:56 PM
    #1798
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    The initial specs I dug up on the 6mm ARC this afternoon look very promising. I can dig the 100+ grain projectile with ranges of 800-1K out of an AR-15 platform. I will wait until we get a few more companies making barrels before I build one.
    oni06, Chew and huskyhog0317 like this.
  19. Jun 3, 2020 at 6:09 PM
    #1799
    corprin
    corprin
    Looks like Faxxon and Ballistic advantage are doing an exclusive deal with brownells.
    I was looking into 6mm Grendel a couple months ago to extend the range/BC of the 6.5 Grendel with the light weight bullets, while not having to get new bolt/mags for the .224 Valkyrie... and I don’t like using a .22 for white-tail. From what I was reading it was a solid option for my next barrel, but rare wild cats are not my thing yet.
    Now I can get the SAMMI registered round with the marketing machine of Hornady promising it takes off. I feel a 1k 6mm in an AR15 will be almost unfair in PRS.
    P2W likes this.
  20. Jun 4, 2020 at 5:49 PM
    #1800
    EubeenHadd
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    I'm especially encouraged by the fact that Barrett is shipping REC7's in 6ARC to the DoD. New whiz-bang calibers are cool and Hornady has been on-point with bringing them to market, but .mil acceptance means it'll probably be here to stay.
