Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. Jul 13, 2020 at 2:56 PM
    #1841
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Central Alabama? You consider doing any shooting at the CMP Talladega center? They run a Vintage sniper match thats perfect for your Mosin. 300 & 600 yard team match.
  2. Jul 18, 2020 at 12:26 PM
    #1842
    renval
    renval Well-Known Member
    Renz
    SoCal
    Just finished putting this one together, ready for some trigger time!!! Let me introduce you The Black Widow!
  3. Jul 26, 2020 at 11:36 AM
    #1843
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Yeaaaaaaaa.......
    Imma need some specs
  4. Jul 31, 2020 at 12:28 PM
    #1844
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    For a general purpose DMR with very occasional match use, is there any reason not to do a 50/200 zero in favor of something else? I shy away from 25/300 because of the extra hold under at middleground ranges. Use will be primarily paper killing, but occasional yote,marmot,etc.
    Sleipnir likes this.
  5. Jul 31, 2020 at 1:12 PM
    #1845
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    I'm a big fan of 50/200 as a walkabout setting. Especially on anything flat shooting, it works well on smaller targets.
    Gunshot-6A[QUOTED] likes this.
  6. Jul 31, 2020 at 2:46 PM
    #1846
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    you should try the 36/300.
    Second, just about every eotech, or aimpoint is zero’d somewhere around 25/200 to 50/200.
    The point of a dm and thus the DMR is to reach out further then the typical capacity of the team and to that end they will be running a different optic. You asked about a DMR, so we should start there. If you’re running a LVPO, in mil or moa, or a bdc reticle you should be zero’d at a 100 so you can dope it at 4,5 and 600.
    oni06 and Gunshot-6A[QUOTED] like this.
  7. Aug 1, 2020 at 3:54 AM
    #1847
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    all my optics are zeroed at 200yd except my 22 trainer, that’s zeroed at 100, it’s just what works for me
    unless your looking to setup a point blank zero
  8. Aug 1, 2020 at 12:03 PM
    #1848
    Gunshot-6A
    Conner
    Everett, WA
    I settled on a 50/200 zero. My LW barrel is scary good with 77gr imi razors. 6.5 was zeroed at 100 for now until i can bear to be outside again in the Utah desert.
    P2W likes this.
  9. Aug 1, 2020 at 12:34 PM
    #1849
    dfanonymous
    So you were more or less asking what the best PBR zero range was I’m assuming?
  10. Oct 19, 2020 at 2:50 PM
    #1850
    Gunshot-6A
    Conner
    Everett, WA
  11. Oct 19, 2020 at 6:41 PM
    #1851
    corprin
    corprin Well-Known Member
    corprin
    Which can. Area419 makes adapters for many of the popular cans so you can keep the wedge part on your barrel and swap out can for brake.
    https://www.area419.com/product/hellfire_suppressor_mount/
  12. Oct 19, 2020 at 6:58 PM
    #1852
    Gunshot-6A
    Conner
    Everett, WA
    Didnt know they made conversion kits, but spending $140 to convert a can when it comes with its own muzzle brake QD mount for free doesn't make sense to me.
    In other news, I think I lined up a buyer.
  13. Oct 20, 2020 at 12:34 PM
    #1853
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I'm not the shot I used to be, shitty sight now, don't bend like I used to. But, I still like to go shooting, mis being able to walk around with a gun just shooting at random stuff, practicing off hand shooting at every step. But going to the range shows you exactly what's up at certain distances, or in my case, how bad i'm doing. Like 4 inch groups at 200 yards, ouch, just chase it around the dot. I keep trying to tone down the gas with my adjustable gas block, but I'm jumping all over the place after each shot. 14 pound gun with a 24 inch barrel, I was expecting a softer hit. I built this one, .308, all aero upper and lower, CMC trigger, 45x Leopold comp scope that I get lost in, no hold over marks, still trying to learn going from one distance to another.IMG_0189.jpgIMG_0190.jpg
  14. Oct 20, 2020 at 12:46 PM
    #1854
    Tnc
    Tnc Well-Known Member
    Tim
    NE Oklahoma
    2017 DCLB TRD OR
    Upgrade the bipod to an Atlas and get a lower power scope. 45x is excessive for any practical shooting. 15x is plenty
    If you’re sitting at a bench, try standing up behind the bench and bending at the waist to be semi-prone directly behind the rifle. Gas guns are a different animal when it comes to managing recoil compared to a bolt gun.
  15. Oct 20, 2020 at 12:53 PM
    #1855
    Gunshot-6A
    Conner
    Everett, WA
    And a scope reticle with holdovers, be it mil dots, etc while you're at it.
    Chew, Gearheadesw and Tnc[QUOTED] like this.
  16. Oct 20, 2020 at 1:03 PM
    #1856
    Gearheadesw
    Davenport Fl
    Have a Burris 5x25 with hold over retical that I thought was hindering me out at 300yards, but no, it's me. I'll see if I can't the competition scope down, some of the guys at the range are real helpful, we'll see. Not going to the range much now, as it's expensive to replace stock.
  17. Oct 21, 2020 at 7:41 PM
    #1857
    Gearheadesw
    Davenport Fl
    You're right, I do need an Atlas Bipod, thanks for that, I don't like the MagPul, moves all over the place. The only reason this gun shoots, is at paper, I know, I know, I'm a gun enthusiast, I don't live or die by my guns, and I don't like killing things, just me. But I miss the days of being able to walk around and practice shooting offhand at every step, plinking for hours. Run out of ammo or tire of shooting, which ever came first. The range seems sterile to me, I need to get used to it.
    Tnc[QUOTED] likes this.
  18. Oct 21, 2020 at 8:06 PM
    #1858
    18tacotues
    18tacotues Active Member
    North Carolina
    2018 White TRD OR 6mt
    I rather like my Magpul bipods after a little work. Running on my 338lm and my 308 ruger precision. I had to mess with the dial up front to stiffen it up but after that it's great. If your using a pure bench gun add a weight to the bipod mount or strap a sandbag right under it. If that helps you know the right direction. If not you can look further.
    Also have someone watch you take a few shots, that can help a lot. I take a GoPro and video practice and matches for help with diagnosing problems.
    Finally what ammo are you using? My rpr .308 and ar-10 in 308 like rather different rounds. Do you reload? If not try a few different weights and brands. My ar-10 when I got it was a 2-3 moa rifle with factory ammo, with some work to the rifle truing the barrel to the upper mostly 1.5-2 moa with factory ammo. .75-1 moa with reloads.
    Gearheadesw likes this.
  19. Oct 21, 2020 at 8:20 PM
    #1859
    Gearheadesw
    Davenport Fl
    I took like 3 decades off from shooting, just wasn't in the cards working out of motels on the road doing heavy construction for a while. I just don't bend or see like I used to, just need more seat time at the bench. I've got a bunch of reloading stuff, but just get lost trying to start up. I've run all sort of store bought ammo, some real cheap, some real expensive, and I still just shoot in circles around the dots. I can shoot from corner to corner, then at the middle, at 200 yards, but i don't make real groups, just not settled enough. Old dog new guns with scopes it seems.
  20. Oct 21, 2020 at 8:48 PM
    #1860
    18tacotues
    North Carolina
    4" at 200yards is not bad out of a semi auto. 2 moa is not a bad thing. Groups will come with repeatability, ammo is top of that list in my book.
    Most of all just get rounds down range, refine what you are doing and don't let someone tell you 2moa is bad. Battle rifles are 2-6 moa so your doing just fine especially after not shooting for so long.
    If you have reloading questions feel free to message me.
    MattCowsmasher, Chew and Gearheadesw like this.
