Long range rifles
Discussion in 'Guns & Hunting' started by noah farley, Dec 11, 2014.
  1. Oct 22, 2020 at 2:44 AM
    #1861
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Thats man, it's all for fun now anyhow, so that's good. With ammo gone or so way over priced, I'm very much eyeing my unopened reloading equipment, thinking this is what I need to do now, make my own.
    Chew likes this.
  2. Oct 22, 2020 at 4:59 AM
    #1862
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Solid! Many are surprised when they see how they're slapping the trigger,,,, especially as the round count goes up.
    @Gearheadesw I wouldn't try to out-gear this, with all dues respect, if you're not seeing your shot, practice more, it's more than likely you. Now, I will be a bit of a hypocrite here; trying a heavier buffer is cheap n easy to try,,,. Especially if you can swap over one locally from a fellow shooter. A heavier buffer can help.
    Gearheadesw likes this.
  3. Oct 22, 2020 at 10:41 AM
    #1863
    renval
    renval Well-Known Member
    Renz
    SoCal
    Check the Accu-Tac bipods, they are great!
    https://www.accu-tac.com/bipods
    Gearheadesw[QUOTED] likes this.
  4. Nov 5, 2020 at 6:45 PM
    #1864
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Build a rifle instead of buying a complete rifle. You will learn a lot more and appreciate what goes into a nice rifle.
  5. Nov 5, 2020 at 7:35 PM
    #1865
    18tacotues
    18tacotues Active Member
    North Carolina
    2018 White TRD OR 6mt
    The ruger precision rifle is a good off the shelf long range rifle. T3 is another good one. The rpr you can easily upgrade the barrel when you get to that level
  6. Nov 5, 2020 at 7:41 PM
    #1866
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    This might be as good a place as any to ask: any members here know of other rifles that shoot 7.5x55 (GP11) besides the Swiss K31 and variants? I have a ton of that ammo, but my K31 has seen better days and I thought it might be worth replacing the rifle with something else, preferably more modern, that can use that ammo. Google was no help.
  7. Nov 5, 2020 at 7:49 PM
    #1867
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    La-11
    You may only find it in a 6.5x55 but it forsho comes in 7.5x55 as well.
  8. Nov 5, 2020 at 8:00 PM
    #1868
    corprin
    corprin Well-Known Member
    corprin
    Or you can have a modern action spun onto a custom barrel in 7x55
    Chew likes this.
  9. Nov 6, 2020 at 6:07 AM
    #1869
    GrundleJuice
    Michigan
    2016 TRD Bro
    Thanks for that. I was unaware of that rifle. Squeezing off a full clip of GP11 in short order would be quite the shoulder assault.
    This thought has crossed my mind. I'm anxiously awaiting the day that no more GP11 is available and only "aftermarket" stuff is made at a high price and possibly questionable quality, which would be unfortunate no matter which weapon I have.
    I'll have to look into cost of those LA-11 rifles and go from there. I suppose once ammo is all dried up, the resale of 7.5x55 chambered stuff will tank. I like old guns but this part of the equation sucks.
    Thank you both for your help!
  10. Nov 6, 2020 at 10:28 AM
    #1870
    strider98
    strider98 Rather Large Member
    2018 Taco DCSB SR5 V6
    bupkis
    you can always replace the K31 with another :thumbsup:. Edelweiss Arms carries them along with a lot of other old Swiss guns
  11. Nov 8, 2020 at 10:40 AM
    #1871
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    Here’s my primary long range rifle, 300WM.
    -Trued and blueprinted 700 action
    -5R barrel cut to 22” 1/10 twist
    -Accuracy International Arctic Warfare chassis
    -Leupold Mark4
    -Leupold Mark4 rings
    -Badger bolt knob
    -Harris bipod
    -Dead Air Sandman-S can
    Here’s my next rifle being built, 6.5 creedmoor. I’m waiting on the barrel and action to be finished.
    -Bartlein 22” varmit contour barrel
    -KRG X-Ray chassis
    -Triggertech Special trigger, flat faced
    -Leupold Mark5HD 5-25x56
    -Badger rings
    Chew likes this.
  12. Nov 8, 2020 at 11:32 AM
    #1872
    dfanonymous
    Who’s doing your barrel spinning and action?
  13. Nov 8, 2020 at 11:38 AM
    #1873
    austin2009
    Austin
    Boise, Idaho
    MCM Firearms, they are local to me here in Boise ID. They do some fantastic work.
    dfanonymous[QUOTED] likes this.
  14. Nov 8, 2020 at 2:07 PM
    #1874
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    In the not too far distant future I'm going to put a magnum long range rifle together. Is that Mark 4 a 3.5-10?
  15. Nov 8, 2020 at 2:10 PM
    #1875
    austin2009
    Austin
    Boise, Idaho
    I absolutely love that rifle. That Mark 4 is a 8.5x25x50.
  16. Dec 19, 2020 at 11:45 AM
    #1876
    corprin
    corprin
    I’ll just leave this here.
  17. Dec 19, 2020 at 12:58 PM
    #1877
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Nice. Scored some 6.5 recently
    CrippledHo, Sleipnir and P2W like this.
  18. Dec 19, 2020 at 1:16 PM
    #1878
    corprin
    corprin
    Was going to roll my own, but components couldn’t compete with loaded ammo from Mile-High. I was shocked they still had some in stock, and $0.40/rd cheaper than everyone else.
    Glad I stocked up on double coupon day in mid November ‘16. Been flipping lowers and ammo like a MF over the past few weeks. :D
    CrippledHo likes this.
  19. Dec 26, 2020 at 7:48 AM
    #1879
    austin2009
    Austin
    Boise, Idaho
    Picked up my newest rifle! The front rifle, 6.5 creedmoor. I also stumbled across some match ammo, picked up 160rds.
  20. Dec 26, 2020 at 9:59 AM
    #1880
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2025 gx550 overtrail. 2025 limited off-road tundra.
    My 6.5 loves that hornady match. It’s boring to shoot it’s that accurate out of a sled.
    EdgemanVA, Gunshot-6A and CrippledHo like this.
