Long shifter, instead of short shifter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DunhamAll, Apr 10, 2012.
  1. Apr 10, 2012 at 5:40 PM
    DunhamAll
    DunhamAll [OP] Well-Known Member
    Jordan
    Baltimore, MD
    '12 Access cab, MT, TRD OR
    Rear diff. breather, BHLM, Wet Okoles.
    Anyone seen one, or know where to get one?
    I'm looking for a shifter that's 4-6" longer than the stock 6Spd shifter.
  2. Apr 10, 2012 at 5:45 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Uhhh.. Why?
    InfernoPhil likes this.
  3. Apr 10, 2012 at 7:27 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Actually I wouldn't mind it being 3" longer with a double bend to the left.
    If done right the concept is getting the stick closer to the steering wheel. Both hands on the wheel when not shifting, and minimum motion to reach the shifter, is the goal. Ideally the throw is REALLY short but the shaft is long so at the actual point of knob travel the distance isn't changed, but in really it doesn't happen that way much.
    I remember a few years back a small company was making straight shifter extenders that just threaded on for the Honda size. Top of the knob was even with the top of the dashboard... oh those were a sight to behold.
  4. Apr 10, 2012 at 7:42 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    My only contribution is that an older toyota (aisin) shifter might work, say from a G52, W56, or R151??? Even if you have to swap the lever with the pivot ball to the original pivot flange. All this is just an idea and is hypothetical, you would have to match things up yourself. The length and shape would be about right for the descriptions.
  5. Apr 10, 2012 at 8:45 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I had a Chevy chevette that the shift knob broke off. So I had an 18" 1/2" copper tube that I put over the shifter. It added about 14" to the shifter. Hey I was only 17, but hey you should try it.
  6. Apr 10, 2012 at 8:51 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    LOL!
    In high school, a guy had a 50-something pickup with a floor shift.
    He made his own lever. Came up, over the front of the seat, back to the back, and followed the back of the seat up.
    Big ole' fugging 8-ball screwed onto the top and it sat at shoulder-height!
    Looked badass with the fuzzy dice.
  7. Apr 10, 2012 at 9:22 PM
    badger
    badger Well-Known Member
    07 SR5
    I built a 3" extension with an adjustable 2" offset. It bolts to the shift lever and tightens onto the taper of the lever. I could adjust it for the perfect offset, then once tightened, it's rock solid. It would take a small puller to remove it now. My hand comes off the wheel and falls right on the knob without any looking or fumbling. No reaching either because I coupled it with a short throw kit from URD. :D
