Long term fuel trims at +20 - help
Discussion in 'Performance and Tuning' started by Rldanie, Feb 8, 2020.
  1. Feb 8, 2020 at 2:57 PM
    Rldanie
    Rldanie [OP] Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    2002
    3.4
    S/C
    New MAF (denso)
    New fuel filter (Toyota)
    New fuel pump (AEM high flow)
    No vacuum leaks (Smoke tested)
    Reset ECU 3 times
    Need to tune FIC, but fuel trims are obviously bad.
    Not sure what else to do
    HELP!!!
    CHMM and 1997tacomav6 like this.
  2. Feb 8, 2020 at 4:52 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    What have you done with the fic so far?
  3. Feb 8, 2020 at 4:53 PM
    Rldanie
    Colorado
    Nothing
    Trying to get my Fuel trims sorted out first
    Installed with all zeros
  4. Feb 8, 2020 at 4:54 PM
    eon_blue
    Azusa, CA
    Did the lean trims happen before or after replacing all that stuff?
    12TRDTacoma likes this.
  5. Feb 8, 2020 at 4:58 PM
    Rldanie
    Colorado
    Before fuel pump
    Not sure on everything else
    Started testing after new MAF (denso) and fuel filter
    Tested
    +20
    Changed fuel pump...nothing
    Found ALL small vacuum leaks with smoke test and fixed...nothing +20 LTFT
    Already reset ECU 3 times....trims back to +20.
  6. Feb 8, 2020 at 5:08 PM
    eon_blue
    Azusa, CA
    Weird that fixing the vacuum leaks didn't change it at all.
    If unsure whether it was before or after the new MAF sensor then I'd double check that the new sensor is a legit OEM/Denso one and not aftermarket. Aftermarket sensors and Toyotas do not play well together
    Jon64l likes this.
  7. Feb 8, 2020 at 5:10 PM
    eon_blue
    Azusa, CA
    Also beware of fake Chinese OEM /Denso sensors on eBay and Amazon. If the price is too good to be true then its likely fake
    b_r_o and 12TRDTacoma like this.
  8. Feb 8, 2020 at 5:12 PM
    Jon64l
    Jon
    How does it drive?
  9. Feb 8, 2020 at 5:14 PM
    Rldanie
    Colorado
    Got it from the dealership
    12TRDTacoma and eon_blue[QUOTED] like this.
  10. Feb 8, 2020 at 5:14 PM
    Rldanie
    Colorado
    Lean in boost until open loop
  11. Feb 8, 2020 at 5:16 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a bitch but you may need to get a fuel gauge set up to it.
    I've seen pressure regulators fail on 3.4's. It's not common, but possible.
    So is injectors, but not all 6 at once, you are talking both banks LT is +20 right.
  12. Feb 8, 2020 at 5:17 PM
    Jon64l
    Jon
    Ok start there.
    Have you setup the Fic maps scale? (Psia & rpm)
    Have you calibrated the Rpm and Tps signals?
    Rldanie[OP] likes this.
  13. Feb 8, 2020 at 8:57 PM
    Rldanie
    Colorado
    No
    I thought my fuel trims should be 0 before I could do that?
  14. Feb 8, 2020 at 9:36 PM
    Jon64l
    Jon
    You have a modified vehicle, Ltft wont be 0.
    Setup the fic so you can start making adjustments.
    mechanicjon likes this.
  15. Feb 9, 2020 at 8:50 AM
    Rldanie
    Colorado
    This is kinda what I was thinking but others have 0 LTFT with a S/C...weird right?
    I was thinking with more air the ECU would have to inject more fuel right?
    I’ll get started on programming the FIC
    At least my intake pipe is tight as a snare drug now!
  16. Feb 9, 2020 at 8:56 AM
    Kinoah24
    Kinoah24 Member
    02 Tacoma
    I am having the same issue 1st gen 3.4 new engine, I think I have it down to with bad cat or o2 sensor
  17. Feb 9, 2020 at 9:00 AM
    eon_blue
    Azusa, CA
    My LTFTs and STFTs are around 5 on average.
    What are your short term numbers
  18. Feb 9, 2020 at 9:03 AM
    Rldanie
    Colorado
    5 ish at most
    0 at idle
  19. Feb 9, 2020 at 9:06 AM
    Jon64l
    Jon
    The Fic is going to be stuck in 1 cell. You need to get the x and y axis scaled and calibrate the rpm and Tps signal. Then you can click "guages" and see what area of the map the fic is working from.
  20. Feb 9, 2020 at 9:08 AM
    1997tacomav6
    Denver
    Those are good numbers at idle!
