Long Term Storage Questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Norilsk, Jun 23, 2019.
  1. Jun 23, 2019 at 3:56 PM
    Norilsk
    Norilsk [OP] Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Planning to store my 18 Tacoma with 42K miles for 1-3 years in my non heated garage.
    Got few questions:
    Is it better to completely remove battery or have it connected to a battery tender to continue running emissions cycle that truck does once in while?
    Aside from changing engine oil, wash/wax, block exhaust pipe, set critters traps, put truck on the jacks, fill up with ethanol free gas and add fuel stabilizer, anything else needs to be done?
    Looking for tips if you have experience in long term storage.
  2. Jun 23, 2019 at 3:57 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    No experience in storage, but why are you storing it?
  3. Jun 23, 2019 at 3:59 PM
    Norilsk
    Eugene
    I got job that requires me to be all over country, lots of flying and hotel life with 2 weeks off every 3 months. There is no need for a truck at this point, but I still owe about $6K on the truck and it's a rare bird manual off-road ACLB, so I prefer to keep it for future.
  4. Jun 23, 2019 at 4:08 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I'd leave the battery in it and keep it on the tender. I'd also drive it on those 2 weeks off every three months, engage 4wd, etc.
    Top it off and put it back to bed.
    Edit: No climate control. If your garage is humid, I'd throw a bucket of Damp Rid in there too.
    I had a garage kept truck I didn't drive much that I couldn't stop the interior mold on what was an otherwise immaculate vehicle. A year and a half fighting it, and Damp Rid finally did the trick.
    Norilsk[OP] likes this.
  5. Jun 23, 2019 at 7:55 PM
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    The bold above plus get a Stor-Dri for the interior. Draws less than 100watts and circulates slightly warmed air via fan and very low power heat element. https://www.canadiantire.ca/en/pdp/stor-dry-warm-air-fan-for-mold-and-mildew-control-0743720p.html
  6. Jun 23, 2019 at 8:14 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If it is going to be stored for 3 years I would remove the battery.
    Brostjoe likes this.
  7. Jun 23, 2019 at 8:18 PM
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    Install a battery disconnect. Cheap and quick.
    Also put it up on 4 jack stands when it’s sitting that long.for the sake of your rubber.
  8. Jun 23, 2019 at 9:17 PM
    DanoT
    The OP said he will be out of town for 3 months at a time and then off work for 2 weeks. If he returns home for most of those 2 weeks off work then it is really 3 months storage and then drive it for 2 weeks. So battery tender, Stor-Dry to fight mold in the interior, no jack stands but put 10 extra psi in the tires in case they loose some air over time. Don't forget to check psi before driving. Driving every 3 months with some 4X4 use for lubrication, run the A/C etc., is without doubt the best way to treat the truck.
    Keeping rodents out of nesting in an engine bay: Open the hood or put a low power light under the hood. Scented drier sheets are also supposed to work. I am not sure if they do, but I put some in my MR2 when I take it off the road for the winter.
  9. Jun 23, 2019 at 9:31 PM
    Shellshock
    Iowa
    Battery tender
    Bucket of damp rid
    Store in a Place without mice
  10. Jun 23, 2019 at 9:39 PM
    sparechange
    sparechange Well-Known Member
    Snoqualmie, WA
    2016 DCSB OR
    second hand lift, fuzzy dice
    2nd the jack stand comment.
  11. Jun 24, 2019 at 9:45 AM
    Norilsk
    Eugene
    Thanks for the tips everyone! I do plan to drive it once in a while, but most likely it will be parked for a solid 1 year at least.
    I would have to switch my insurance every time I am in town from storage to a full coverage (i.e. xpensive if you are in Toronto).
    On top of that I also don’t have any need (or want:rolleyes:) to return back to Toronto for vacation time, so I can just hop on the plane and travel to places I want to go to.
    I am not concerned about tyres as much, currently there is less than 10% left, but I would put it on jacks just to release tension on the suspension I guess, plus it’s a 5 minute job to do anyways.
    I keep debating with myself if it’s better to sell this truck and let somebody enjoy it or store it and get back to it hoping nothing internally fails after long storage, decisions, decisions....
  12. Jun 24, 2019 at 9:46 AM
    Brostjoe
    British Columbia
    2017 Limited DCLB
    Doesn’t take long for flats spots depending on temperature. Makes for a bumpy first 100-200 miles
    sparechange[QUOTED] likes this.
