Long Travel 4x4 Tacoma
Discussion in '1st Gen Tacomas For Sale (1995-2004)' started by TanTaco98, Apr 22, 2022.
  1. Apr 22, 2022 at 4:25 PM
    TanTaco98
    TanTaco98 [OP] Well-Known Member
    Gavin
    Apple Valley, California
    This is my 2001 4x4 long travel Tacoma, I bought the truck bone stock in 2013, has just over 180,000 miles now. Clean title, passes legit smog. Everything was done by myself or Sam Hall, Hall Fabrication. Truck works well, everything works as it should, ac, heater, 4wd, etc. build list:
    Front;
    Camburg 3.5 kit
    Fox dsc coilovers
    Oem tundra axles
    Tundra big brakes w/ brembo rotors
    Total chaos coil bucket gussets
    Foa bump stops
    Advanced fiberglass (glassworks) 4”? Fenders
    OG glassworks scooped hood
    Spyder one piece headlights w/ led bulbs
    New grille and filler trim pieces with blinker
    4.88
    Rear;
    100% tig welded bed cage by hall fab, frame is boxed in
    18” fox 2.5 chromed triple bypasses
    Tundra rear end regeared to 4.88 with a spool
    Fox bump stops
    Wilwood distribution valve
    Amber dust light
    Glassworks 7” bed sides
    Optima yellow top
    Total chaos shackles
    Total chaos lower shock mounts
    Can run single spare or stacked
    Clifford remote start
    “Auxbeam” switch panel, uses solid state relays, not programmable like spod or switchpro but it works really well and super simple
    Kicker q class 6.75” components on a Memphis 600 w amp
    Kicker “10 L7 on a kicker 800w amp
    Upgraded cs144 140 amp gm alternator
    Rewired all the main grounds, with quality 4 awg and 1/0 cable
    Set of 6 method true beadlocks, 4 35” tri ace tires
    18,000 obo
    Located in SoCal, 760-985-2471, feel free to call, but if i don't answer please send me a text.
    723FBE04-4B8F-47C4-B185-0D26AA4E6582.jpg FEA09B89-119C-445D-835E-C90EB13FC764.jpg IMG_0534.jpg IMG_0523.jpg IMG_0524.jpg IMG_0530.jpg IMG_0148.jpg IMG_0149.jpg IMG_0150.jpg IMG_0151.jpg IMG_0440.jpg IMG_0453.jpg IMG_0460.jpg IMG_0523.jpg
  2. Apr 23, 2022 at 6:41 AM
    02hilux
    Planet: EARTH
    List a price or ad might get delete. Nice truck BTW
  3. Apr 23, 2022 at 8:18 AM
    TanTaco98
    Gavin
    Updated, thanks for the heads up, I copy and pasted so I didn’t even realize.
  4. Apr 28, 2022 at 6:45 AM
    TanTaco98
    Gavin
    Bump, $17000
    Doug4x2 likes this.
  5. Oct 3, 2022 at 12:42 PM
    TanTaco98
    Gavin
    Bump still for sale, just put new denso starter, new plugs and fresh oil change. 16k takes it.
    airmax233 likes this.
