Long Travel 4x4's?
Discussion in 'Long Travel Suspension' started by Stillfly199, Jan 17, 2010.
  1. Jan 17, 2010 at 4:43 PM
    Stillfly199
    Stillfly199 [OP] ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    This is mainly concerning the kits other than the All Pro kits. The serious LT kits. With having the extended axles, doesnt it make the axles a lot weaker? Does it affect the 4wd capabilities?
  2. Jan 17, 2010 at 5:02 PM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    My question is, why do they need longer axles in the first place?
  3. Jan 17, 2010 at 5:04 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    b/c the LT kits push the wheels and spindles further out from the truck, so u need longer axles to reach them
  4. Jan 17, 2010 at 5:10 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    the steel (or differnet metal...i can't remember what type they use) is a LOT stronger than the stock axle metal is so i cant see them being weaker
  5. Jan 17, 2010 at 5:12 PM
    jhodge83
    SC
    17 XLT Sport
    ^^i think most are chromoly or whatever....stronger than stock
  6. Jan 17, 2010 at 5:30 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Ok, I can understand that. Thanks for the input
  7. Jan 17, 2010 at 6:37 PM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    While that makes sense, my un-stated question was: Why do you need the wider wheelbase in the first place?
    Sorry I wasn't clear - mind-reading isn't a requirement.
  8. Jan 17, 2010 at 6:51 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Long travel allows more wheel travel, and allows you to haul ass through the desert
  9. Jan 17, 2010 at 7:36 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    It comes down to geometry. Put your arm out horizontally and move your finger up and down you can move it like 2 inches before things would bind. Now move your arm up and down at you're elbow. You would be able to move it like a foot before things would bind theoretically speaking if it were a control arm.
    I hope this makes sense.
  10. Jan 17, 2010 at 7:42 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ^ great way to explain it!
  11. Jan 18, 2010 at 2:57 AM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    Yeah, that makes sense.
  12. Jan 19, 2010 at 8:50 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Somewhat related to this thread, I found a post from a guy who documented (with pics) how to replace a broken front axle on his FJ. He made some good comments about the CV joint being the weakest link in the axle.
    --BellyDoc (Jon) from fjcruiserforums
  13. Jan 19, 2010 at 8:53 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
  14. Jan 19, 2010 at 9:27 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    To bring that article into the topic, by increasing the length of the control arms and effectively using bump stops and limiting straps you keep the driveline angles well within their functional capacity with the same or more wheel travel.
    Yes, you could run LT without limiting straps or bump stops for super travel but you'd also be increasing torsion at the fulcrum and the CV axle would have to do more work (force over distance) at the same driveline angles as stock. Then you'd be back to grenading CVs like it's going out of style. You'd be worse off with a long travel set-up allowed to run to the extremes of articulation.
