Long Travel Biography
Discussion in 'Long Travel Suspension' started by jtlachac08, Feb 15, 2012.
  1. Jul 2, 2012 at 6:06 PM
    #41
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    You would shit your pants if you let us valve them for you. Night and day difference.
  2. Jul 2, 2012 at 6:28 PM
    #42
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I'm game. My front shocks came "valved" from DSM but every truck is different once your done adding weight all over
  3. Jul 2, 2012 at 6:34 PM
    #43
    Cr250jumper
    The moon
    50 shades of tan©
    Haha and thank you for posting in the other thread battlescars, I didnt realize your build was in here. I noticed you have a solid mounted motor too, you can vouch that a floppy motor can make a suspension feel weird too. I recently solid mounted mine and cannot believe the difference
  4. Jul 2, 2012 at 6:40 PM
    #44
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Do it! Im house trained tho
  5. Jul 2, 2012 at 6:52 PM
    #45
    Cr250jumper
    The moon
    50 shades of tan©
    Im rookie at valving so this is just speculating here, but I think he may have meant the opposite. You know all of the oh shit moments you've had in the desert?
    When you dont valve your shocks you end up driving a little too fast. When you drive too fast you hit things harder than you want. When you hit things harder than you want you shit your pants. Dont shit your pants, get rid of stock and upgrade to better valving.
    Brought to you by DIRECTV
  6. Jul 2, 2012 at 7:02 PM
    #46
    noSKills858
    Alex
    Poway, CA
    LOL that's fucking great.
  7. Jul 2, 2012 at 7:06 PM
    #47
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    wow JD [​IMG]
  8. Jul 2, 2012 at 8:43 PM
    #48
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Who is 'us '?
  9. Jul 3, 2012 at 7:17 AM
    #49
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Truck w/ Mileage- 2009 Tacoma Access Cab V6 4.0 54,xxxx mi
    Front Suspension- Built Right Fab
    Front Shocks- King Remote Resi 2.5x8" w/ OEM Top Mount, King 2.5x8" 3 Tube Bypass Shock
    Rear Suspension- Built Right Fab rear shock towers, Custom frame bumps back, Deaver E30 Pack, 11" Built Right Shackles
    Rear Shocks- 16" King 2.5" Triple Bypasses
    Front Spring Rate- 600lb
    Front Valving- 12/15 compression, 12 rebound
    Front Bypass Settings- King Default
    Rear Valving- 12/15 compression, 8 rebound
    Rear Bypass Settings- Tubes 3/4 in on both compression tubes
    Front Fenders- Glassworks 4" Flare 3" Rise
    Rear Bedsides- Glassworks 4.5" Flare 3" Rise
    Front Track Width- Haven't measured
    Rear Track Width- Haven't measured
    Wheels- Method Racing Standard
    Tires- General Grabber 285/75-16
    Engine Modifications- Flowmaster Catback
    Drivetrain Modifications- Driveshaft shortened with slip yoke, BORA 1.5" Wheel Spacers in Rear
    Gussetting- Cam Tabs, Spindles, Shock Towers, Rear Frame Boxed and wrapped.
    Additional Specs-
    Additional Modifications- Truck Shop Bumper Front & Rear Soon, Three Kragen 7" HIDs, 22" LED combo bar
    Estimated Investment After Truck Purchase- <> $18K
  10. Jul 3, 2012 at 8:07 AM
    #50
    gatz25
    gatz25 Active Member
    Sandy ut
    LT tacoma 4x4
    front and rear fenders triple byepass kings in the front with total chaos front end rear bedcage with kings double byepass also prerunner front bumper with 3 hid lights
    Hey man first off I wanna say the trucks bad ass, I have one that looks close to it anf I am wondering how you keep your bed sides looking so good I have rock chips up the ass
  11. Jul 3, 2012 at 8:12 AM
    #51
    Cr250jumper
    The moon
    50 shades of tan©
    You take pics from far away lol. With wider suspension up front and flared rear fenders they are going to chip, you can get better paint to resist chipping longer but its going to chip eventually
  12. Jul 3, 2012 at 8:22 AM
    #52
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    mahaloTaco likes this.
  13. Jul 3, 2012 at 9:07 AM
    #53
    TC yota
    Tyler
    Escondido
    Ha
    that was the first trip out with the new front end I made, I didn't have time to mount glass. I literally finished the day before Halloween haha
  14. Jul 3, 2012 at 11:53 AM
    #54
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    You guys know that Fox has your valving stamped to the dust cap if you bought them new right? and King normally sends a little tag with the valving specs on it. DSM does as well.
    I'll fill mine out after lunch I need to measure track width.
  15. Jul 3, 2012 at 3:50 PM
    #55
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Truck w/ Mileage- 2000 Access Cab 4x4 152,xxx
    Front Suspension- Total Chaos Long Travel Kit
    Rear Suspension- Custom Deaver f67 pack with 12" TC shackles and all TC mounting hardware. Full bedcage
    Rear Shocks- Fox 18" 2.5 Triple Bypasses
    Front Spring Rate- 600lb Eibach Springs
    Front Valving- 12,12,F,20’s on compression, 12’s on rebound Per King, Total Chaos and DSM advice. Lucas Synthetic shock Oil
    Front Bypass Settings- N/A
    Rear Valving- 3.1 / 70 per Fox and Karteks formula with the weight and setup I'm running.
    Rear Bypass Settings- Need to be tuned more. Rebound all the way open then half tun in. Compression tube 1 about 2cm of thread and compression tube 2 1.5cm of thread.
    Front Fenders- Glassworks 4.5" Flare
    Rear Bedsides- Glassworks 6" flat tops
    Front Track Width- 79""
    Rear Track Width- 76"
    Wheels- KMC Enduro 15x7 4.5BS
    Tires- 32x11.5x15 BFG KM2s
    Engine Modifications- TRD Supercharger, URD 6 injector kit with piggy back ECU, Warbro fuel pump, URD S/C pulley 10lbs of max boost
    Drivetrain Modifications- Altered Pinion Angle, HD flange out of the TCase
    Gusseting- Some basic gusseting but could add some more
    Additional Specs- Strapped Front at 13" from full droop, Strapped Rear 17.5" @ full droop. Inner CVs joints out of a Tundra to allow for more travel and Porsche 930 Bates style CV boots on the Inners. (3) 33w flood HIDs with amber covers on bumper. (5) spot beam 55w HIDs on a fold down fully adjustable light rack. Cup holder bedsides and bottle opener in bed. Large tool box mounted to bed.
    Estimated Investment After Truck Purchase- <> $6K
  16. Jul 3, 2012 at 8:38 PM
    #56
    gatz25
    Sandy ut
    LT tacoma 4x4
    Ya I guess they look good from far away, this is my first lt truck so there are things to get used to I guess.
    Dalandser likes this.
  17. Jul 3, 2012 at 8:41 PM
    #57
    Sunner
    Sunner Well-Known Member
    You gotta do something with that bumper man, not the best look IMO, if you like it then great.
  18. Jul 3, 2012 at 8:42 PM
    #58
    lembowski
    Rolando, CA
    Jeeper Creeper
    Looks good to me, just needs to be black...
  19. Jul 3, 2012 at 8:43 PM
    #59
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    i agree. too vertical and too blue
  20. Jul 3, 2012 at 8:46 PM
    #60
    Sunner
    Black would be nice, I think it has way too much going on too, a more simple w/ steeper skid plate would look much better, just my opinion though.
