Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 11, 2012 at 10:04 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Not at all. Gotta ask if you want to learn. (searching helps too, of course ;))
    As mentioned earlier, more vertical = better as long as you have room for everything. If you haven't purchased your shocks yet and plan on upgrading your suspension at some point in the future, it'd be good to buy the longest shocks you think you'd ever need and mount them so the bottom of the shock body is even with the bottom of the frame rails.
    That way you don't have to worry about them bottoming out, and they'll already be set up for extra droop if/when you make changes in the future.
  2. Jul 11, 2012 at 10:57 AM
    whitetoblack
    whitetoblack ******
    Tyler
    SoCal
    02 Prerunner & 08 Prerunner
    Johnny Branch Fabrication, King, Deaver, Glassworks, Toyo Tire, Alpine, work in progress...
    I actually disagree on this one it seems almost best for people to ask questions somewhere like this. Questions most of the time get answered quickly because most people have gone through a lot before getting where they are with long travel. Plus then like jason said if they start a new thread it seems like more and more newbs answer questions incorrectly every day and the site gets clogged with shitty information.
  3. Jul 11, 2012 at 11:18 AM
    amaes
    amaes [OP] Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    This.
    I also think its because this is one of the few threads you actually get responses on from people that actually want to help.
  4. Jul 11, 2012 at 11:22 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    So true.
  5. Jul 11, 2012 at 12:03 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Saw this on Facebook. Figured I post it here.
    Snatch strap on a standard ball hitch = dangerous!
  6. Jul 11, 2012 at 12:19 PM
    09blacktaco
    09blacktaco Well-Known Member
    The Rockies
    09 DC 4x4 TRD OR
    :eek:
  7. Jul 11, 2012 at 12:25 PM
    mjp2
    NJ
    Whoa!
    I agree that it's a bad idea, but I have to wonder what the rating was on that ball stud for it to snap like that. Class 3 could easily snap with a load handled by a typical winch.
    The ball on the back of my diesel is rated for a 30k lb gooseneck. In my case, the ball will remain intact but the entire hitch assembly would come undone with enough load...
  8. Jul 11, 2012 at 12:59 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    You have to consider the difference in force between a static load of 30,000 and a sudden, jarring load of 5-10,000. A mired vehicle can require a metric shit ton of force, far beyond the vehicle's weight, to recover.
  9. Jul 11, 2012 at 1:06 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Yeah that what it was saying on the article. The sudden load was what does it. And since a snatch strap is stretchy it sling shotted the ball.
  10. Jul 11, 2012 at 1:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    "Metric shit ton"
    So using that one later. Thanks Chase :thumbsup:
  11. Jul 11, 2012 at 1:27 PM
    mjp2
    NJ
    It's an industry term. :p
  12. Jul 11, 2012 at 1:28 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Is that like measuring fluid in inchs?
  13. Jul 11, 2012 at 5:38 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
  14. Jul 11, 2012 at 6:19 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
  15. Jul 11, 2012 at 6:37 PM
    rcfreak201
    rcfreak201 Well-Known Member
    What kind of paint do you guys use to do the inside of the fenders? Im getting a good amount of spider cracks so im gonna do the inside and tops of my bedsides like SDHQ.
    edit: While looking at some SDHQ pics im wondering how the fuck they taped it off so perfectly :laugh:
  16. Jul 11, 2012 at 6:43 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    sdhq has the tops bed linered by a local company here. stuff is about 1/8" - 1/4" thick
  17. Jul 11, 2012 at 6:43 PM
    rcfreak201
    This is what i wanna do
  18. Jul 11, 2012 at 6:45 PM
    rcfreak201
    Hmm, well what about some textured spray paint? I know they make bedliner in a can but I've never used it.
  19. Jul 11, 2012 at 6:49 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    i did my rear bumper in a rustoelum spray on bedliner and that shit set up like concrete! Very tough and not too bad textured. About like some 200 grit sand paper
  20. Jul 11, 2012 at 6:53 PM
    rcfreak201
    Does it spray nicely with the texture and all? I'm probably just gonna do the inside and outside tops of the bedsides rather than the whole inside.
