Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 25, 2011 at 5:51 AM
    #2341
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    TC will tell you not to use them on a DD. I liked them because they took a lot of slop out of the steering. The vibes are noticeable but worth it in my eyes. You just point it and go with the nylatron bushings. The engine cage was put on at the same time and added to the vibration too since the shock mounts dont move anymore.
    If everything is reinforced and cant flex then the vibration has to go somewhere and in my case it was the steering wheel.
  2. Mar 25, 2011 at 6:19 AM
    #2342
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    Yeah, kartek sells them. Make sure you get bushings with a big shoulder to keep the leafs together. My problem was my leafs would move around and the delrin stopped that.
  3. Mar 25, 2011 at 7:11 AM
    #2343
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Delrin bushings are good just expensive. On the front end of the prerunner/4x4 every bushing I had got killed in a matter of a month. I looked further into my issue. Factory arms have a metal washer on them where it touches the frame. So you need to get a washer or something in there so the slots for the alignment cams dont rip the bushings apart. I dont have alignment cams anymore so I put a weldable washer then the small gap filled the slot in with weld then ground smooth:D
    Delrin is a great product. Squeeks like a motherfucker. Requires a ton of grease when installing and expensive. Last I looked Kartek was around 12bucks a piece. Unless you can find someone that can machine them for you. On the prerunner/4x4 u need 8 for the lower arms and for leafs you need 12. Thats a pretty penny.
    Baja Mike at Kartek showed me some red hardened urathane bushings. There around 6bucks a piece. I have them on my front arms and my rear leafs. My rear bushings squeeek so im guessing i didnt get enough grease in them. I have had them on my truck about a year to day and are still holding up great. Only down fall I saw with them is there too big and I have to cut them down on the bandsaw. the flange is close to 1/2" wide.
  4. Mar 25, 2011 at 7:16 AM
    #2344
    Tacorunner87
    Chino Hills Ca
    To much to list!
  5. Mar 25, 2011 at 7:23 AM
    #2345
    bajamoon
    STEVE
    Whittier
    ^^^ yeah they squeak like a som bitch, I killed my oem bushings in about a month too.
  6. Mar 25, 2011 at 7:24 AM
    #2346
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  7. Mar 25, 2011 at 8:06 AM
    #2347
    Tacorunner87
    Chino Hills Ca
    To much to list!
    Ya, I talked to him. He said he fixed it. The frame was bend so you cut the frame off at the firewall and is going beams. I think need beams so people can talk shit!:D
  8. Mar 25, 2011 at 8:26 AM
    #2348
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    So does that mean since my Camburg kit has uniballs in the inner lower arms would those bushings not really be needed or still beneficial in the upper arms? I guess that means I will have even more vibes than the bushings too?
  9. Mar 25, 2011 at 9:03 AM
    #2349
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I got those bad boys up front on my LT and was just thinking to put them in the rear shackle hanger. Turn my front end squeak to a whole truck whoop chirp-er. Yeah pretty much the only place I found that has them is Kartek. I know a few fab shops make their own. I might call them up to see if they machine them to leaf spring size.
  10. Mar 25, 2011 at 9:04 AM
    #2350
    Fisheez
    Fisheez Built Ford Tough.
    Zack
    So Cal
    Tacomaless For Now
    I'd rather have beams tbh..
  11. Mar 25, 2011 at 9:29 AM
    #2351
    bajamoon
    STEVE
    Whittier
    Engage made mine, i would just buy the material and have a shop machine them, it's plastic can't be that hard.
    Check Mc Master carr, they might have the material since they have everything else.
  12. Mar 25, 2011 at 11:05 AM
    #2352
    Tacorunner87
    Chino Hills Ca
    To much to list!
    as for your lower arms you will not need bushings since it has the uniballs. But for the upper I dont know if these bushings would work since since i dont know tube diameter and the bolt size.
  13. Mar 25, 2011 at 11:08 AM
    #2353
    Tacorunner87
    Chino Hills Ca
    To much to list!
    mc master carr may have the material I think Aircraft spruce in corona sells it as well
    :thumbsup:
  14. Mar 25, 2011 at 11:28 AM
    #2354
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Same here
  15. Mar 25, 2011 at 1:19 PM
    #2355
    Cr250jumper
    The moon
    50 shades of tan©
    I just meant in general when you guys are doing those bushings for a TC kit do you do the top arms too or just the lowers? I was just thinking the lowers are where most of the flex would come in. Mine are brand new so I wouldnt replace them right now anyway. Just trying to gain some knowledge
    Also if the vibes get worse with stiffer bushings, and I have uniballs, does that mean Im gonna get the vibes like a hooker on nickle night?
  16. Mar 25, 2011 at 2:20 PM
    #2356
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    you're a dirty hooker
  17. Mar 25, 2011 at 3:41 PM
    #2357
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    Shh, you promised not to tell anyone.
    He's lying, im clean.
  18. Mar 25, 2011 at 3:50 PM
    #2358
    blackhawke88
    SGV, CA
    07 TRD Offroad
    come over to beer pong tonight and we'll see how clean you really are
  19. Mar 25, 2011 at 4:51 PM
    #2359
    bajamoon
    STEVE
    Whittier
    homo
  20. Mar 25, 2011 at 4:52 PM
    #2360
    blackhawke88
    SGV, CA
    07 TRD Offroad
    dont hate cuz i didnt invite you :cool: you get enuf azn as it is
