Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Sep 6, 2012 at 7:03 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Maybe a spacer under the bump so you hit the bump before slamming the misalignment through the fender well?
  2. Sep 6, 2012 at 7:20 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Ya exactly what I will be doing.
    Total Chaos LT kits come with a 1" spacer, iirc the size, that gets welded between the bump and the bracket.
  3. Sep 6, 2012 at 7:23 PM
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    Yeah, when you cycle it, you will know how big of a spacer to run too
  4. Sep 6, 2012 at 7:26 PM
    08pretaco
    az
    Wish I did more probing with questioning and research before I installed the kit.
    IE: what the valving was
    asking about the spindles with the kit
    I no longer have adjustment left in my tie rods due to the extension, no more threads available
    Oh well, live and learn. Now I will get it done right eventually.
  5. Sep 6, 2012 at 7:34 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Im sure you know this but the 2nd gen Camburg kit pulls 15" with 2wd. Im not sure if the extra is up or down or both but I would get a BFH and move the fender well
  6. Sep 6, 2012 at 7:37 PM
    08pretaco
    az
    Well it cant be up because on the passenger side the ABS hydraulic motor....is exactly where the uniball cup beats into the fender well, ask me how I know :rolleyes: Unless you are supposed to move the motor, bend new hard brakes lines and things of that nature.
    I think its down-travel cause there is no CV's to bind at droop
  7. Sep 6, 2012 at 7:45 PM
    Cr250jumper
    The moon
    50 shades of tan©
    No I'm saying that may be why your hitting the UCA so hard and other 2nd gen camburg kits are not. Im pretty sure your upper adapter that goes in the coil bucket is different than the 4wd version and that is why your smashing the fender well. Where did RJ move his ABS motor?
  8. Sep 6, 2012 at 7:48 PM
    Cr250jumper
    The moon
    50 shades of tan©
    ^^This, cycle it without springs and move everything thats in the way. Give yourself a tiny bit of room on the shock shaft and hydro bump it right there. I know thats not all possible right now but thats what you want the end goal to be. The only real problem with rubber bumps is your guessing how far they finish compression
  9. Sep 6, 2012 at 7:48 PM
    08pretaco
    az
    Maybe he took the time and properly bumped the front. Going to shoot him a PM.
    Thanks JD
  10. Sep 6, 2012 at 7:50 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Well he has no fender wells so he had to move it lol. I know he mounted everything on his engine cage Im just not sure of where each thing went
  11. Sep 6, 2012 at 7:52 PM
    08pretaco
    az
    Oh, well maybe the placement is different between the V6 and 4 cylinder which I am. Shot him a PM anywho.
    F* it...maybe I will remount the motor, already have an outline of the upper arm in the fender, just cut out that sheet metal.
    Seriously considering getting those SAW doubles tomorrow
  12. Sep 6, 2012 at 7:54 PM
    08pretaco
    az
    Speaking of which JD...its after Labor Day :)
    When we doing this?!?!?!
  13. Sep 6, 2012 at 8:06 PM
    Cr250jumper
    The moon
    50 shades of tan©
    I cant this weekend but I should be able to next weekend
  14. Sep 6, 2012 at 8:08 PM
    08pretaco
    az
    We will keep in touch, idk if I can next weekend lol
  15. Sep 6, 2012 at 8:12 PM
    08pretaco
    az
  16. Sep 6, 2012 at 8:25 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
  17. Sep 6, 2012 at 8:27 PM
    08pretaco
    az
    Did not even notice the price posted. Just noticed he mentioned to call or text for prices.
  18. Sep 6, 2012 at 8:35 PM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    He didn't post a price I texted him but its a first gen kit 1500 with coils
  19. Sep 6, 2012 at 8:49 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  20. Sep 6, 2012 at 8:54 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
