Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 4, 2012 at 9:45 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    With Mis-Alignment spacers :confused:
    It shouldn't move side to side at all:cool:
  2. Oct 4, 2012 at 9:56 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    It doesn't movie side to side. It rotates or twists side to side
  3. Oct 4, 2012 at 10:26 PM
    theduck911
    Max
    Locked and Geared!
    If it does it easily then you'll probably have to have them replaced. Almost all shocks are are setup like that. The C/O's on the front of your truck are probably like that too. They should be very stiff, like a brand new uniball. :cool:
  4. Oct 4, 2012 at 10:37 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I can't rotate my king heim joints with my hand haha.....also I took out all the oil and nitro ....one if the resis leaks a little bit,but when I rotate that one it makes a gravely noise
  5. Oct 4, 2012 at 11:13 PM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    that doesnt sound good lol
  6. Oct 4, 2012 at 11:30 PM
    ocherp
    ocherp Well-Known Member
    Gilbert, AZ
    2016 V6 4X4
    SDHQ built
    I know mine feels lighter in the front end when my tank is low. I guess it also depends on how you have it set up, behind the cab or farther back. With a full tank, everything feels really even and smooth. BTW, you won't pass smog with one is that's an issue :p
  7. Oct 5, 2012 at 2:01 AM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    As long as you reuse all your stock senders, pumps, filters, etc it should pass. If all you changed was the physical tank size and location. At least that's what I've been told.
  8. Oct 5, 2012 at 7:13 AM
    Socalrunner
    Glendora
    Icon Coilovers
    My kings up front have a type of rubber bushing on the top mount and a heim at the lower mount.
  9. Oct 5, 2012 at 8:02 AM
    Bandwagon
    Bandwagon Well-Known Member
    Escondido/San diego
    Camburg long travel, full glass,
    it wont pass the visual inspection, my buddy has a 240 and tried using all the stock stuff and it failed still. he put the stock bladder back in took it down passed flying colors. pain in the ass
  10. Oct 5, 2012 at 8:27 AM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    Are the Allpro 2" over axles the same as the TC's? I mean will they work with the TC LT kit?
    Or are they all a little different in length?
  11. Oct 5, 2012 at 8:50 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    As long as you have misaligments on them it shouldnt matter, they should be able to twist. That is why they are uniballs and not standard bearings
  12. Oct 5, 2012 at 9:41 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    the shock body will rotate on the upper uniball once they are even a little worn. that is why king makes bushing that goes between the shock body and the mounting tabs. to prevent shocks from slapping from side to side.
  13. Oct 5, 2012 at 9:58 AM
    SoCalRoadie
    Jim
    Burbank
    interesting. I will keep this in mind.
  14. Oct 5, 2012 at 3:35 PM
    Cr250jumper
    The moon
    50 shades of tan©
  15. Oct 5, 2012 at 4:47 PM
    Anteupp
    Anteupp Mega Member
    its got dimple dies, seems legit..
  16. Oct 5, 2012 at 4:48 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    dimple dies=panty dropper
  17. Oct 5, 2012 at 7:10 PM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    With these gas prices I have to drive up to the expo in my girls Camry.
  18. Oct 5, 2012 at 7:46 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    Gas is $5.49 where I'm at right now
  19. Oct 5, 2012 at 8:13 PM
    Anteupp
    Anteupp Mega Member
    ouchh for regular?
  20. Oct 5, 2012 at 8:16 PM
    anthony250f
    Anthony
    San Diego, CA
    fuckkk.....im gonna go pick up my defined kit soon...now i gotta pay a million dollars per gallon
