Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 9, 2012 at 12:37 AM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    my black shafts came today
  2. Oct 9, 2012 at 12:45 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
  3. Oct 9, 2012 at 1:12 AM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
  4. Oct 9, 2012 at 6:42 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Wayyy cooler than any gymkhana video.
  5. Oct 9, 2012 at 6:45 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  6. Oct 9, 2012 at 9:02 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    the guy who owns that diesel lives here in slo :p
  7. Oct 9, 2012 at 9:26 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    those of you who have experience in adjusting dual rate coilovers. for the top spring i need to set where the top spring will bottom out, so i spun (sorry dont know what they are called) the little ring on the shock body down to where i need it, easily done by my fingers, then you have the top ring that is supposed to lock that one in place, this one is way harder. i used a hammer and a punch to turn it, then it got to the same point on both sides and will not budge at all anymore. but the bottom ring i can spin freely everywhere??
  8. Oct 9, 2012 at 10:12 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Go on Pirate 4x4 and read the Coilover Bible (Part 1 & 2). I'd link it but I'm on my phone :cool:
    You'll find everything you need there.
  9. Oct 9, 2012 at 10:15 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
  10. Oct 9, 2012 at 10:19 AM
    theduck911
    Max
    Locked and Geared!
  11. Oct 9, 2012 at 10:26 AM
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    that vid was insane. its going to my FB haha
  12. Oct 9, 2012 at 10:29 AM
    Cr250jumper
    The moon
    50 shades of tan©
  13. Oct 9, 2012 at 10:57 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    i have seen some modify the rings with a set screw to lock them in place, but im sure you would have noticed that
    sometimes king puts an oring between the two adjustment rings, maybe you spun the rings right over it and they just happen to lock up at the same point..
    only thing i could think of since both the rings are the same.
    on some of the ttb fords ive done i dont even use the rate adjuster.
    if the upper rings are in the right place just tighten the lower ring into it and problem solved for now
  14. Oct 9, 2012 at 10:59 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Thats it Eric, I did notice a small piece of rubber coming out of the threads of the upper when trying to move it down. I almost guarantee we threaded it over the oring. We stopped when it started getting difficult to make sure we didnt mess anything up. Thanks
  15. Oct 9, 2012 at 11:17 AM
    Bfoster133
    Blake
    i was unsure if i wanted the bolt on top ones or the pinch cans so i got the bolt in style... wont see much black lol but im unsure on how im gonna mount it haha
  16. Oct 9, 2012 at 11:24 AM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    front. my C/Os are King, my bypasses are SAW. The King body is longer than the SAW body. same 8" stroke but different shock bodies.
  17. Oct 9, 2012 at 11:26 AM
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    guess who won the general tire give away at the expo!!
  18. Oct 9, 2012 at 11:34 AM
    Bfoster133
    Blake
    matt??
  19. Oct 9, 2012 at 11:36 AM
    97yota4wd
    Eric
    Mesa, AZ
    right i saw a little piece of rubber coming out of 1 side too.
    so how do i get the rubber o-ring out of it?
    do i need to get a new rubber o-ring?
  20. Oct 9, 2012 at 11:37 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Your going to want to move the adjuster back up and it should come out, then see what the oring looks like. Once you move the oring down by hand you should be able to spin the top one like the bottom does
