Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Oct 9, 2012 at 4:08 PM
    rcfreak201
    rcfreak201 Well-Known Member
    I do have an 18" right now and the guy at king said to go to a 16". He said it would fix the coil bind and i wouldn't need as much preload to keep the same height. :notsure:
  2. Oct 9, 2012 at 4:27 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    If i understand correctly an 18" spring at 500# will require more preload than a 16" spring at 600# since that spring is rated for more weight per inch. A 16" spring will be 2" shorter so the preload collar may end up in the same spot. however since the spring starts less compressed there you will end up with less coil binding.
    i think...
  3. Oct 9, 2012 at 4:31 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    If the nub was actually on the airbox and not the intake tube, it goes to EVAP.
  4. Oct 9, 2012 at 4:32 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    yes if there too much preload you can get coilbind.
    one way to check is look at the area on the coil where each coil would contact eachother . if the power coating is worn ,wearing , or flaking off you could be going into coilbind. and if thats the case all the force is going to go through the coiltowers instead of the bumpstop.
    the best way is to pull the spring off (leaving the adjustment collar where it is) and cycle the suspension. measure the coilsprings total collapsed length and compare that to the spring specs from king. i would take the spring off anyway and see if it has an arc in it just standing up on its own on the floor. if it has a noticeable arc send to king for warranty, but be prepared to prove they dont go into coilbind if need be...
  5. Oct 9, 2012 at 4:37 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    From Poly: (18" spring has more travel by a little)
    Length/ID/Rate/Block Height/Travel/Load @ Block height
    16.00"/3.00"/600/7.72"/8.28"/4,968lbs
    18.00"/3.00"/600/9.65"/8.35"/5,010lbs
  6. Oct 9, 2012 at 4:44 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i think i might be putting too much preload on my c/os as well... oh well guess we will see after i go out. ill be sure to check for wear.
  7. Oct 9, 2012 at 5:39 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    You should be more concerned about all the dust that filter is going to let into your motor
  8. Oct 9, 2012 at 5:58 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    maybe i was out of the loop, but for those of you who haven't looked go check out Aaron's build thread - full cage now and it's pretty sick.
  9. Oct 9, 2012 at 7:16 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I know gas is bad right now but you could always be the first hypermile LT :notsure:
  10. Oct 9, 2012 at 7:17 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    ^ banner worthy
  11. Oct 9, 2012 at 7:20 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Because snowplow.
  12. Oct 9, 2012 at 8:40 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    I also I have 18" coilovers 600lbs spring rate. I don't have any preload on mine. Sounds Like you just need a stiffer 18" spring.
  13. Oct 9, 2012 at 9:07 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    sounds like i know why my ride is so rough... 2wd, 2.4, regular cab with, you guessed it. 18'' 600lb coils... i found some 550's 16'' and ordered some 6'' 500lb (i need them to lower the truck about 3-5 inches) for my "tender" coil. fingers crossed its a winning combination.
  14. Oct 9, 2012 at 9:37 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    so im a newb, but will someone explain what will happen if i remove preload from my kings and revalve with some more compression?
  15. Oct 9, 2012 at 9:45 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Hey guys, What size tubing do you think this bed-cage is?
  16. Oct 9, 2012 at 9:48 PM
    Socalrunner
    Glendora
    Icon Coilovers
    Are you getting rid of your cage RJ?
  17. Oct 9, 2012 at 9:49 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Negative ghostrider.
  18. Oct 9, 2012 at 9:56 PM
    jeffz0rz
    san diego
  19. Oct 9, 2012 at 10:01 PM
    Cr250jumper
    The moon
    50 shades of tan©
    That will lower the ride height of the front. Preload is mainly used to control ride height. More compression valving will make it feel stiffer on bumps. Think of it as springs support the weight, valving controls the speed of movement
  20. Oct 9, 2012 at 10:02 PM
    PLC721
    Patrick
    Chandler, Az
    When Paden revalved it brought his front up? :confused:
