Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 14, 2011 at 2:06 PM
    #2621
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's not really tightness you're looking for. It's dependent on the desired ride height when the coilovers are installing in your truck.
    The exactly settings are specific to each truck and will be a trial-and-error thing as you make adjustments, measure, adjust, measure, etc.
    The driver's side will need more preload than the passenger side to compensate for the extra weight on that side of the truck.
  2. Apr 14, 2011 at 2:12 PM
    #2622
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I use an allen wrench that fits tight in the hole. Im pretty sure its an SAE size. It works pretty good and leaves very small marks but doesnt bother me. Otherwise you will have to get one of these
    http://www.kartek.com/product/Tools/SpannerWrenches.html
  3. Apr 14, 2011 at 2:14 PM
    #2623
    Cr250jumper
    The moon
    50 shades of tan©
    Do not tighten them yet though. You will most likely have to put at least one of them in without a coil while installing your suspension so you can cycle the suspension
  4. Apr 14, 2011 at 3:59 PM
    #2624
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Factory mounts are around 1/8-3/16 if I remember correctly. I built mine out of 1/4"
    If your baller status you can go that route. I bet your looking close to 300+ I know thats what Bonzen and DMZ both quoted me. I built mine cost me about 40bucks to make mine including metal, bushings, sleeves, 9/16" bolts, and 5/16" bolts. Granted it did take me about 3 days to get them installed.:(
  5. Apr 14, 2011 at 5:27 PM
    #2625
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Don't forget that it's not just the motor mount that can break. I pushed a motor mount through the wall of the frame and didn't even break the motor mount. Luckily the shop was able to get in there and rebuild everything (and gusset it).
  6. Apr 14, 2011 at 5:33 PM
    #2626
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Do you need to remove the front diff to gusset the motor mounts?! or what's the best way to reach them, looking to do this when I gusset everything else!:cool:
    Thanks
  7. Apr 14, 2011 at 5:48 PM
    #2627
    Tacorunner87
    Chino Hills Ca
    To much to list!
    Im sure that is possible figuring the frame is only about 1/8 -3/16" thick but rare at the same time. When i did my new frame side I plated the frame in that area with 1/8"
    Edit: didnt see you have an 06 dont know if the frame thickness is any different but I doubt it is. But again pre-taco's had a fully boxed frame all the way back.
    Tell you the truth there is no real easy way to do it since the engine bay is pretty much in the way. I welded as much as I could from underneath then crawled into the engine bay the best I could and did the best I could. I plan to clean them up some when I do cage work.
  8. Apr 14, 2011 at 5:54 PM
    #2628
    Cr250jumper
    The moon
    50 shades of tan©
    ^ Did you do yours with the engine in? I didnt think that would be possible
  9. Apr 14, 2011 at 8:26 PM
    #2629
    Tacorunner87
    Chino Hills Ca
    To much to list!
    Yea, It was a giant pain in the ass. Hardest part was cutting to old mounts off without hitting starter, and power steering hoses with the grinder.
  10. Apr 14, 2011 at 10:27 PM
    #2630
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    Ok so im going to be ordering some rims. Now with the engage race spindles will the 4.5 backspacing clear 35s. I dont want them to rub on the spindles. What width should i order as well?
  11. Apr 14, 2011 at 10:38 PM
    #2631
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    They clear, ask Hassim. Can't go wrong with bfg at's. good all around and they last.
  12. Apr 14, 2011 at 10:58 PM
    #2632
    Socalrunner
    Glendora
    Icon Coilovers
    Thank you Steve.
  13. Apr 14, 2011 at 11:06 PM
    #2633
    Fisheez
    Fisheez Built Ford Tough.
    Zack
    So Cal
    Tacomaless For Now
    ..if it was linked it'd be a diff. story.
    ofcourse it's worth much more since everything is proffessionally built, but still
  14. Apr 15, 2011 at 6:02 AM
    #2634
    Mxpatriot
    No, but they had to pull the half axles.
  15. Apr 15, 2011 at 8:13 AM
    #2635
    Tacorunner87
    Chino Hills Ca
    To much to list!
    I didnt have to pull anything. But again im 2wd:D
  16. Apr 15, 2011 at 8:14 AM
    #2636
    Tacorunner87
    Chino Hills Ca
    To much to list!
    If its a race proven truck which I don't think this one is but I'm sure it can be. It would sell for that without links.
  17. Apr 15, 2011 at 1:04 PM
    #2637
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Cool LT taco. I'd see it going for 16-17K though depending on how quick he is trying to get rid of it. It hasn't been abused yet because the shocks arent tuned yet for the truck. Speaking of tuning I'm still too lazy to pull out a few shims out of my rear shocks.
  18. Apr 15, 2011 at 1:11 PM
    #2638
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    join the lazy club... i got truck work to do too... i'll do it next weekend haha
  19. Apr 15, 2011 at 1:13 PM
    #2639
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    im beginning to shift my focus from my truck to little mods for Jen's truck. I just got her something as a little surprise. I hope she doesnt read this post :anonymous:
  20. Apr 15, 2011 at 1:25 PM
    #2640
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    little surprise...4 link...??? hahaha
