Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Nov 30, 2012 at 8:25 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I'm actually curious about your axle to frame measurements as well RJ.
  2. Nov 30, 2012 at 8:31 AM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Thanks for the info Jason!
    I did a little more research about Defineds kit as well as the kit DMZ is working on (DMZ kit is a month or more off depending on interest) and I think its great that we as consumers have more options! I won't get into who's kit is better and who took who's idea because I have no idea! I just know both companies have very good feedback on Tw and Tora so I don't think either option would be a bad choice. What I really like about the defined kit is you can do it in stages so you don't get slapped with a $6-8k bill on day 1
  3. Nov 30, 2012 at 8:37 AM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    i think i paid 350- or 400 for them at the end of the day. he had to build two sets because the first ones were bumped slightly too early
  4. Nov 30, 2012 at 8:40 AM
    SierraExp
    SierraExp Its the Journey, not the Destination Vendor
    Sierra Expeditions
    Mesa, Arizona
  5. Nov 30, 2012 at 10:09 AM
    rcfreak201
    rcfreak201 Well-Known Member
    Just curious since it was mentioned here, why wouldn't you be able to use OEM shocks on any other SUA kit?
  6. Nov 30, 2012 at 10:16 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
  7. Nov 30, 2012 at 10:31 AM
    Redgrom
    Brent
    san clemente
    Not sure myself, maybe it's possible but no one does it because you don't get the true benefits? I just know for me it's way easier to explain spending $2-3 k each time than a $8-9k pop all at once!
  8. Nov 30, 2012 at 10:40 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    8K? i payed like 3600 or so total for my rear.
  9. Nov 30, 2012 at 10:43 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ill be in about 3k for my rear when all said and done.
  10. Nov 30, 2012 at 10:44 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    10k for a leaf sprung rear end is just crazy, I don't care how "pretty" it is
  11. Nov 30, 2012 at 10:51 AM
    Defined
    Defined Well-Known Member
    mike
    southern california
    you can ! its just that my kit is built to bump at the approiate limit so you dont over compress the shock. which means that once installed , you wont have to take the leafpack out to tear it down to set bump on your own. the stage 1 kit is engineered to use the stock length shocks and adds bolt on brackets and a nice progressive bumpstop to limit compression to an appropriate level.
    it all depends on the installers ability and/or customers budget. my SUA kit takes a lot of labor out of the equation , even when its compared to another bolt in kit.
    my stage 1 kit makes an install much easier and cheaper when you dont have the knowledge and/or ability to properly set bump levels.
    most people can center the axle, set the pinion angle and booger weld the perches on. but setting proper bump to use with the shock mounts given and making the needed bracketry is way over some peoples heads. this is where paying a few hundred more for something is worth it for certain individuals. its easily installed and gives piece of mind ,all while getting the correct leafpack under the vehicle.
    sit back, enjoy the better ride and save up for the all consuming that comes along with the sport. just my basic kit alone will save you hundreds in install costs and even more if you or some friends can do the install. thats like 4 extra trips out to the desert or more depending .
  12. Nov 30, 2012 at 11:04 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Well I would gloat in the fact I paid less than $1500 for mine, but stepping up to bypasses is going to add to that.
    Tyler I had a question for you about SAW's. I am trying to order the wear band for the piston (not resi) from Poly for my 2.5's and they only have it listed as the "resi piston wear band" and it says its made out of teflon coated bronze PTFE. My resi piston has a plastic type wear band and the piston with the shims has a teflon covered bronze wear band. Did they just list it incorrect or do I have the wrong band on my resi piston?
    https://www.polyperformance.com/shop/Sway-A-Way-2.0-2.5-Reservoir-Piston-Wear-Band-p-16448.html
  13. Nov 30, 2012 at 11:34 AM
    Redgrom
    Brent
    san clemente
    My $8k figure was all new out the door. I know you can save tons of $$$ if you can find used shocks and bumps but I have yet to find someone willing to box the frame for less than $1,000 or build a custom cage that does what I want for under $1,500. If I could weld it would be a much different story for sure. Also the labor to install adds up quick, but if you can only produce "booger welds" like me it's worth it:)
  14. Nov 30, 2012 at 11:49 AM
    97yota4wd
    Eric
    Mesa, AZ
  15. Nov 30, 2012 at 11:53 AM
    Redgrom
    Brent
    san clemente
    What did sick nicks charge you for your bed cage? $3.5 k for that cage,defined kit, bumps, and those 16 x 2.5 kings is a hell of a deal! Did you have to get your drive shaft modified? It was all the little things that really added up on some of the quotes I got.
    Few people on this forum. The quote was to pull the bed and plate it. (Might have been $800 not $1,000 don't have the quotes infront of me) that was plating a long bed from the cab to behind the springs.
  16. Nov 30, 2012 at 12:12 PM
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    I would defenetly get a quote from Sick Nick!!
    Ive known him for almost 20 years and he takes a lot of pride in his work. He is one of the best fabbers out there and he does not have a ton of overhead at his shop so he is more affordable. Which will save you $$$
  17. Nov 30, 2012 at 12:18 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    You will be getting a call and order from me hopefully after new years :D
  18. Nov 30, 2012 at 12:20 PM
    97yota4wd
    Eric
    Mesa, AZ
    too bad your not in az.... i could get it done for less than 300 for you i bet.
  19. Nov 30, 2012 at 12:23 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Ok so I was curious about the DMZ making a bolt on kit using stock hangers. so I talked to Tim about it and this is what I was told and I quote from Tim "We will be modifying the existing kits to have a bolt on option. Because of the sexy design, it is a little more work than just drilling a couple of holes in the existing design, but things shouldn't change too much!".
  20. Nov 30, 2012 at 12:42 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
