Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 4, 2012 at 9:56 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Actually, it clears perfect with stock spindles. Its with the maxtracs they rub...
  2. Dec 4, 2012 at 9:56 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Thats what id like idealy.
  3. Dec 4, 2012 at 9:57 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    im talking about the maxtracs since you're currently running maxtracs with spacers.
  4. Dec 4, 2012 at 9:58 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Ive been searching this thread and re reading the explanation on what a scrub radius is but I dont quite totally understand what it is. Could you possibly give me a brief explanation?
  5. Dec 4, 2012 at 9:59 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Meh, my spindles are bent with gussets , and username has stated that he has a cracked spindle with gussets.
    looking forward to the LSK spindles!
  6. Dec 4, 2012 at 9:59 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Whoops :D
  7. Dec 4, 2012 at 10:00 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Its just 1" more than tc or camburg. Is it really that bad?
  8. Dec 4, 2012 at 10:05 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    that's limited by the 8" shocks mostly, if you cut the coil bucket and use some 10" shocks the you can fully use the arms. LSK is also making recessed lower shock mounts on their race kit, like all their other kits, so you can squeeze a bigger shock in there. They cant recess the lower shock mounts on the stock replacement kits because it wont clear the 4x4 axles.
  9. Dec 4, 2012 at 10:05 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Not saying they're perfect, but I don't think the Maxtrac's are any better and for Hiatt having to run spacers on top of that just don't make sense too me :cool:
  10. Dec 4, 2012 at 10:08 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    It all really depends on preferance. I don't know if you have seen an engage kit in person like socal rodies but his is 4 in over per side and it looks fuckin huge and thats only 1/2 in wider then tc and burg. I think with 4 1/2 in over per side you would be fine if you like how wide the engage kit sits but 7 in is way to big it would look and handle retarded
  11. Dec 4, 2012 at 10:10 AM
    theduck911
    Max
    Locked and Geared!
    Wheel & Tire Setup effects it as well. Also it's only 1" wider per side but 2" overall on the track width, which isn't massive but still significant.
    Look at the Solo Motorsports kit, the kit is 4.5" wide and it's quite wide in the front.
    I'd also suggest switching out to 6"+ Wide Glass Fenders with a kit that wide:cool:
  12. Dec 4, 2012 at 10:11 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Right now Engage is pretty much the only company that makes a 4.5" over kit, and you cant use other companies' spindles with them because engage runs the lower uniball in the LCA itself, not on an adapter. LSK plans to have the uniball in the adapter like TC and Camburg, but be 4.5" over, and have boxed and heimed uppers. They will make sure it works with stock and after market spindles, along with their own fabricated stock spec spindles for 4x4 and 2wd, depending on the hubs. Their race kit will be completely different, with vertical uniballs and recess shock mounts, 2wd only.
    They have gone to a lot of people and asked what they like to see in a new kit and what they dont like about the kits that are already out there. Their aim is to really shoot the gap and make something that really does not already exist out there, and it's pretty exciting. Jen's truck is going to have their 4.5" over 4x4 kit with 930 CVs and fabricated spindle.
  13. Dec 4, 2012 at 10:13 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    pretty sure engage kits are 4.5" per side but I could be wrong.
  14. Dec 4, 2012 at 10:17 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I think they are 4
  15. Dec 4, 2012 at 10:20 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
  16. Dec 4, 2012 at 10:21 AM
    anthony250f
    Anthony
    San Diego, CA
    Ever notice that the steering wheel wants to jerk out of your hand when hitting bump or a ranything ??
  17. Dec 4, 2012 at 10:32 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  18. Dec 4, 2012 at 10:33 AM
    theduck911
    Max
    Locked and Geared!
    Well Solo claims 19" strapped and bumped with their setup, so LSK should be in the 16-19" range, depending on how the 930 Joints workout :cool:
  19. Dec 4, 2012 at 10:37 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    we're not going to really claim anything just yet, we're sticking with horizontal uniballs with the 4x4 kit unlike Solo's vertical uniball kit, so there will be a difference there, but at least people can choose to run stock spindles or LSK spindles. RCV has two kinds of CVs we're looking at, one with 24 degrees of movement, the other with 28 degrees, but there are price differences.
  20. Dec 4, 2012 at 10:37 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Not really. Why?
