Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 4, 2012 at 2:30 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    So another question, for your truck would you rather have
    Open, limited slip, or locked rear diff?anf pros and cons of each.
  2. Dec 4, 2012 at 2:32 PM
    SierraExp
    SierraExp Its the Journey, not the Destination Vendor
    Sierra Expeditions
    Mesa, Arizona
    If you can afford it go with a selectable locker like ARB
  3. Dec 4, 2012 at 2:34 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    Ill have to look into that when I get back.
  4. Dec 4, 2012 at 2:51 PM
    LSK
    LSK Well-Known Member
    Burbank, CA
    Aiming to bring top of the line suspension, at a very affordable cost. As well as helping the off-road community
    The "hard" part of these spindles is the hub block. After that is done we can do pretty much anything you guys want. We're still waiting to hear back from a couple machinists about the hub blocks. after that its game on. While we want to move toward a solid product line, right now everything is pretty much "one off" and can be adapted toward your needs at very little aditional cost. Even the LT kit is as easy easy as changing a dimension from "4.5" to "3.5" in CAD and they become a 3.5 over arms. We're working with RCV for our axles so everything from stock outer and inner CVs with extended axles to full on badass 930 inners and their outers will be available based on budget . We're not some big bad suspension company that's set in our ways. haha. We love feedback.
  5. Dec 4, 2012 at 8:41 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    You know, I highly doubt Toyota decided to change the snout dimensions throughout the years so the hub/bearing assembly is probably the same as they were from 79-86 4x4 with the solid axle. Maybe try to see if they are the same and then do a snout block for the SA snouts that are 5 bolt and swap everything over. It is even possible to retain 4x.
  6. Dec 4, 2012 at 8:52 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    For the LT (4WD) I'd look into a D60 or D44 snount like Solo did, expect use an outter CV instead of a Ujoint. This would definitely be the easiest route to go, and strongest, as then stronger wheel bearings, Etc could be utilized :cool:
  7. Dec 4, 2012 at 9:22 PM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    That's a pretty good idea. I'll buy that kit once your shop makes it.
  8. Dec 4, 2012 at 9:31 PM
    theduck911
    Max
    Locked and Geared!
    I've been working on a bolt-in spindle that uses a version of the above mentioned idea for my truck for a little while now, just haven't had any time to put serious detail into it.
  9. Dec 4, 2012 at 11:37 PM
    LSK
    Burbank, CA
    That is what I'm on the fence about. The Dana 44 hub block is already done. We use it on our ranger race kit then we could just use 6 lug Chevy brake setups. On the other side is you have to worry about the speed sensor. Does anybody have issues with the stock hub assembly?
  10. Dec 4, 2012 at 11:45 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Blowing out stock wheel bearings on the 2nd Gen tacomas, its common for the wheel bearing to go bad. I'm getting ready to replace my 3rd one tomorrow. I have replaced two on the driver side and now the passenger side.
  11. Dec 4, 2012 at 11:52 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    my passenger side wheel bearing is going out for sure, i couldnt even talk to Anthony250 on the drive home tonight it was so loud.
  12. Dec 4, 2012 at 11:55 PM
    theduck911
    Max
    Locked and Geared!
    Could possibly adapt the stock brake setup onto it as well, don't see it being overly complicated for that portion.
    Speed sensor would require more work into calculating the equivalent positioning on a D44 setup vs stock, also do able.
    Stock Hub/Wheel Bearing Assemby doesn't like larger tires, so they wear out quite fast :cool:
  13. Dec 5, 2012 at 12:05 AM
    MonkeyProof
    SoCal- SGV
    Or doing this :D
  14. Dec 5, 2012 at 1:33 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Talked to Aaron over at LSK. We might be shortening the kit to 3.5 if it doesnt get rid of too much travel. Hopefully we can get started next week! :)
  15. Dec 5, 2012 at 1:36 AM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    Anyone see any f67 deavers around or 12 inch shackles? Looking to complete my rear LT and having trouble finding reasonable prices on these...
  16. Dec 5, 2012 at 7:03 AM
    theduck911
    Max
    Locked and Geared!
    There was a set on DR, trying and find the link now.
    They pop up every once in while but it may take a few weeks+ to find them. :cool:
  17. Dec 5, 2012 at 7:18 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    :cheers:
  18. Dec 5, 2012 at 7:26 AM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    I have 9" TC shackles laying around if you can run those.
    Just putting it out there.
  19. Dec 5, 2012 at 9:35 AM
    rcfreak201
    rcfreak201 Well-Known Member
    Little late on the spindle discussion but I started talking to American Motorsports about a fully fab'd lift spindle. I was thinking around 2-2.5" high and 1" wide. They're pretty busy but I might be dropping my truck off with them sometime soon to get started.
  20. Dec 5, 2012 at 9:50 AM
    theduck911
    Max
    Locked and Geared!
    Not a bad idea. Especially for you LT prerunners who need a real spindle.
    I'd try to keep the width increase to 0.5" or less to have the least effect on handling and steering feel.
    Remember the difference in the feel in steering when you switched back to stock spindles? Well you're going to loose that with a n increased width :cool:
