Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Dec 11, 2012 at 4:16 PM
    flesh2
    flesh2 Well-Known Member
    08 DB Cab long bed
    TC Lt, Dmz kit, Hnm bedcage
    I had a similar noise , I thought it was my steering but found out it was my lca bushing needing to be greased
  2. Dec 11, 2012 at 4:25 PM
    brian65oh
    brian65oh Well-Known Member
    Brian
    Nor Cal (currently stationed in Jax beach FL)
    05 pre runner
    camburg long travel w/ race runner 2.5x8 co Deaver springs spintech race muffler kn cold air intake
    i have checked every bolt under the truck and its so strange that it will not happen when i go over any type of roll over bumps where the suspension gets to cycle, it almost sounds like the bed is loose that the kind of noise im geting. im going to grease everything and take the shock off and move the kit around to see if I can hear anything ill let you guys know the outcome
  3. Dec 11, 2012 at 4:28 PM
    SierraExp
    SierraExp Its the Journey, not the Destination Vendor
    Sierra Expeditions
    Mesa, Arizona
    how are your bedsides mounted? I have seen it before where a loose bedside will contact the pinchweld at the back of the cab creating a loud knocking noise
  4. Dec 11, 2012 at 4:32 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i had this....the noise was very loud, but i could tell it was coming from the rear.
  5. Dec 11, 2012 at 4:39 PM
    brian65oh
    Brian
    05 pre runner
    sometimes i think it is my bedside but all the bolts are tight and i checked by putting a layer of tape on the cab pinch weld to look for rub marks and it was un touched.
  6. Dec 11, 2012 at 5:02 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Could also be the actual bed bolts being loose. Mine come loose all the time. Grab the bottom of the bed near the cab and try and lift the bed up..
  7. Dec 11, 2012 at 6:12 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Secondary hoops, Coil Bucket Cross Bracing, Battery holder and Coilovers compression added. Should all be done tomorrow, ready to get back out been 3 weeks
  8. Dec 11, 2012 at 6:15 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Secondarys fit with factory bump?
  9. Dec 11, 2012 at 6:18 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Pretty sure they do, secondaries aren't going in now just the hoops for more support. I have a wedding I'm saving up for can't blow money like I did the past year :(
  10. Dec 11, 2012 at 6:19 PM
    08pretaco
    az
    I havr a noise like described. Its my fuel door, look into it.
  11. Dec 11, 2012 at 6:23 PM
    anthony250f
    Anthony
    San Diego, CA
    i have this noise to! thought my truck was falling apart the first time i took it out....you ever notice that the pump clicks off alot when adding fuel? it only happened since adding the rear glass...
  12. Dec 11, 2012 at 6:26 PM
    08pretaco
    az
    Mine never clicks off when fueling just when full. My fuel door opens when I go out.
    Once I started getting a clixking while driving I found my noise to be the fuel door rattling. Little tape and stopped the noise.
  13. Dec 11, 2012 at 6:31 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Also just to make sure that arm doesnt hit the hoop at full bump, I custom made my secondary hoops with a friend, and just cycled my arms the other day looks like my hoop taps my arm at full bump.
  14. Dec 11, 2012 at 7:25 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    I'm sure Total Chaos took that into consideration when they made them, my uppers aren't that different from TC to run into issues.
  15. Dec 11, 2012 at 7:30 PM
    Anthony250
    Anthony
    Rialto CA
    Oh ok gotcha, thought they werent TC.
  16. Dec 11, 2012 at 7:34 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    They aren't, they are Built-Right :D
  17. Dec 11, 2012 at 7:37 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    And TC's actually do hit ha
  18. Dec 11, 2012 at 7:41 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Isn't that what the bumpstop spacer is for?
  19. Dec 11, 2012 at 7:42 PM
    anthony250f
    Anthony
    San Diego, CA
    any idea what br will charge for one of those braces? i kinda want one just in case lol
  20. Dec 11, 2012 at 7:46 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
