Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jan 10, 2013 at 4:56 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Barstow got the best of ya! :(
  2. Jan 10, 2013 at 4:59 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    I've had the red oil in my shocks for 2 seasons, no problems
  3. Jan 10, 2013 at 5:13 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    Stock spindles gusseted. If it bent it would be where the gusset meets the hub. Which is what I think happened.
  4. Jan 10, 2013 at 5:20 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Im guessing that if you have hiemed uppers, you have gotten rid of your cam tabs. If so, something def got bent. Have you checked the tabs that hold on the lower, if those are cloo, next bet would def be a bent spindle. :(
  5. Jan 10, 2013 at 6:04 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Fox RED is much better then blue. The viscosity of red over blue is different but as far as longevity goes, red outlasts blue any day.
    And since you guys are all racers, you should know that.
  6. Jan 10, 2013 at 6:10 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    This. I am mid travel and that's all I use. That or atf fluid.
  7. Jan 10, 2013 at 6:13 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Viscosity diff is red is 7wt and blue is 5wt
  8. Jan 10, 2013 at 6:17 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    i have a jig to check it in but the spindle has to be completely torn down...
  9. Jan 10, 2013 at 6:28 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
  10. Jan 10, 2013 at 7:14 PM
    Anteupp
    Anteupp Mega Member
    lol
  11. Jan 10, 2013 at 7:26 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Hmmm, everything I've seen on RDC says to change it out after a run.
    So I should go with red?
  12. Jan 10, 2013 at 7:34 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    But isn't Tyler the only one that has finished a race?
  13. Jan 10, 2013 at 7:58 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have fox blue
  14. Jan 10, 2013 at 8:04 PM
    gacandido2010
    gacandido2010 Well-Known Member
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    Bilstein 5100s, Eibach Coils, All Pro Baja Leaf Pack, Fox 2.5x16", All Pro 1.5 spacers, Deckplate Mod, K&N Filter, Magna-Flow Exhaust System, Cobra Ultra Cb with 3" Firestick, 2 Hella 500 HIDs, custom mesh grill, blacked out lettering, Limo Tint, Fog Light Mod
    anyone wanna help me install my kit?
  15. Jan 10, 2013 at 8:07 PM
    rcfreak201
    rcfreak201 Well-Known Member
    ^Um what kit is that?
  16. Jan 10, 2013 at 8:12 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    custom..................
    :crapstorm:
    :stirthepot:
  17. Jan 10, 2013 at 8:13 PM
    Anteupp
    Anteupp Mega Member
    intresting
  18. Jan 10, 2013 at 8:13 PM
    rcfreak201
    ok.:)
  19. Jan 10, 2013 at 8:16 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    got it on DR, the guys buddy from work (polyperfromance) gave it to him when he got a legit racekit
  20. Jan 10, 2013 at 8:18 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    i need shock adapters and limit straps tho. and probably new new bushings
