Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 4, 2013 at 7:24 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    4x4 spindles?! pls sum
  2. Feb 4, 2013 at 7:25 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    exhaust powered curling iron is my guess.
  3. Feb 4, 2013 at 7:28 PM
    LSK
    LSK Well-Known Member
    Burbank, CA
    Aiming to bring top of the line suspension, at a very affordable cost. As well as helping the off-road community
    *sandwich maker.
  4. Feb 4, 2013 at 7:34 PM
    LSK
    Burbank, CA
    yeah stock hub assembly. They don't seam to catastrophically fail very often and we like the idea of people being able to upgrade their truck one part at a time. new hubs mean new $1000+ axles. We'd like to do a badass kit with dana44 outers similar to solos kit but unfortunately not to many people have that big of a lump sum sitting around for their newish daily driver Tacoma.
  5. Feb 4, 2013 at 7:37 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Someone needs to make beefy ass spindles and bearings that fit a factory axle.
  6. Feb 4, 2013 at 7:43 PM
    LSK
    Burbank, CA
    spydertrax makes some pretty badass hub assemblies. I've wondered if one them could be adapted. Although $500 a pop makes it not really worth it. the R&D that goes into a 4x4 hub is not something very many shops like to tackle. Thats why you'll see a lot of companies like Solo using a pre existing design like the dana 44 spindle because they work great and already exist for $50 from pick ur part.
  7. Feb 4, 2013 at 8:25 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Price point on this 4x4 spindle?
  8. Feb 5, 2013 at 7:35 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    They don't Catastrophically fail, no...Yes the Idea to be able to upgrade one part at a time is quite appealing to those on a tight budget.
    As for the Dana 44 Hubs, The Idea is good, I'm not not a fan of the U-Joint outter they have on their setup or the fact that they aren't ABS Compatible. A 930 or similar joint would be more appealing, IMO. :cool:
    The Spidertrax Ultimate Unit bearings are very nice, not how they fair for high-speed application as they're designed around rock-crawling, to my knowledge.
    They would be the best option for making a bolt kit, as they are similar to the stock wheel bearing assembly. Not sure if anyone has the measurements on them exactly, wouldn't be overly difficult to take some measurements for ABS to be kept in tacked :cool:
  9. Feb 5, 2013 at 8:09 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    They look stock length but they are the 3.5" over lowers. They are basically yhe exact same as the stock lowers they make, just extended. I remember when LSK was building my kit, they sent me pics and for a sec i though the same thing. Lol
  10. Feb 5, 2013 at 8:10 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    So who is going to the trophy truck tuesday meet today?
  11. Feb 5, 2013 at 8:11 AM
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    curious if the cops have harassed you guys yet?
  12. Feb 5, 2013 at 8:27 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    Nope. They have actually been pretty cool. They said they preffer us more than the ricers. Lol
  13. Feb 5, 2013 at 8:33 AM
    dirty dangler
    adam
    simi valley,ca
    sounds about right hahaha....just keep it nice and mellow and shouldnt be any issues
  14. Feb 5, 2013 at 10:32 AM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    awesome .. can't wait to see the finished kit, and the secret upgrade :spy:
  15. Feb 5, 2013 at 11:34 AM
    theduck911
    Max
    Locked and Geared!
    Fair enough, looking again they look to long to be stock in relation to the Arms in the back :thumbsup:
  16. Feb 5, 2013 at 12:23 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    anyone know where I can get headliner fabric? I know I can use just some standard fabric stuff, but I want it rigid like the stuff in our trucks
  17. Feb 5, 2013 at 12:25 PM
    Hiatt1991
    Hiatt
    Ventura, CA
    Is your headliner damaged or is it just getting old. Have you considered pulling it out and reupholstering it? Its a solid rigid piece when you pull it out so im considering this.
  18. Feb 5, 2013 at 12:26 PM
    rondog
    Ronnie
    Escondido/San Diego
    No my head liner is fine. Since I caged, my center console and dome light no longer fit. I still plan on using the lights but I have some sheet metal showing through I'd like to cover up
    ...or I'm open to other ideas
  19. Feb 5, 2013 at 12:29 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    UFO fabrics in Vista, they have everything there
  20. Feb 5, 2013 at 1:18 PM
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Northern NV
    89 pickup 87 pickup 2016 4runner
    I did but I pulled the rear apart again to add a strut leg to each canti arm and put the metal shims back in to see if there is a difference. I had gaps between the main top leafs and the lower part of the pack sitting at ride height.
    Looks like there are some small kinks in how the arc was formed on the main and second leaf and they don't want to "spoon" together nice and tight, ha. See if the shims help. Might drop ride height a little too, all those shims stacked together are over 1/4" high.
    Pulled all the plastic sliders other than the leaf under the main which still had the holes since I didnt cut it. From what I understand the plastic sliders are there to make spring production faster/cheaper. It's a lot more labor to smooth and round the ends of each leaf so they don't grind into the next leaf up than it is to just cut them quick with a metal worker or shear leaving the edges sharp and unfinished, punch holes, pop in discs, and slap em together.
    Does any of this really matter? probably not, total waste of time? probably yes.
    There is a third senario on leafs other than them sitting too high or too low. Sitting just right! Then they will sag too low. If they sit just a tad too high, they will never sag. ha.
    Leaf springs suck.
