Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Feb 21, 2013 at 10:58 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Shoulda gone heimed lowers. Bushings are annoying.
  2. Feb 21, 2013 at 10:58 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i know....my stock ones were nothing but problems too
  3. Feb 21, 2013 at 10:59 PM
    anthony250f
    Anthony
    San Diego, CA
    i cant remember....it was between 100-120 though....but it looks/feels like it tightened way more than the stock bushings....the rear ones look 100% fine
  4. Feb 21, 2013 at 11:03 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    go delrin bushings
  5. Feb 21, 2013 at 11:04 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    this
  6. Feb 21, 2013 at 11:05 PM
    anthony250f
    Anthony
    San Diego, CA
    i have those for the rear...where can i get the correct ones?
  7. Feb 21, 2013 at 11:07 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    buy a stick of delrin from ebay, 2' diameter, at least 12" long, and take it to any shop with a lathe. shouldnt cost you more than $100 to make a set of 8 for the front, less if you get hooked up with the machining or do it yourself.
  8. Feb 21, 2013 at 11:08 PM
    anthony250f
    Anthony
    San Diego, CA
    does your tc lowers have a front crush sleeve?
    sweet thanks...i might as well solid mount it as well.
  9. Feb 21, 2013 at 11:11 PM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Engage doesn't use crush sleeves for their bushings. So when you tighten the cams they squish the bushings into the slot and it tears the bushings apart... same reason your truck will never hold an alignment. And the ones I have fixed some off the arms are off by over a 1/4" so its an absolute nightmare to get the lower in with delrin bushings
  10. Feb 21, 2013 at 11:11 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    LSK sells these machined pieces that you fit between the alignment tabs and it has a hole drilled out perfectly for the alignment cam bolt. All you have to do is pop it in and weld it in and you're solid mounted. Stronger and more exact than weld washers. It's pretty cool.
  11. Feb 21, 2013 at 11:12 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Thats pretty nifty. How much do those run?
  12. Feb 21, 2013 at 11:13 PM
    anthony250f
    Anthony
    San Diego, CA
    will that work even if i need both of my cams maxed in to maintain proper camber? if i did weld washers i would need them all the way in....and i do have the heims adjusted out also.
  13. Feb 21, 2013 at 11:14 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    not sure, they made it for Jen's truck. PM/call them and ask them.
  14. Feb 21, 2013 at 11:16 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    if you're maxed one way with cams, then you should be able to adjust more with your upper heims. The machined pieces are set so your arms are at the outer end of your cam holes, so max negative camber. then you adjust the upper heims out.
  15. Feb 21, 2013 at 11:18 PM
    anthony250f
    Anthony
    San Diego, CA
    my heims are already adjusted out a ways...like 1/2 to 3/4" out
  16. Feb 21, 2013 at 11:19 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    oh boy. You are in quite a pickle.
  17. Feb 21, 2013 at 11:20 PM
    anthony250f
    Anthony
    San Diego, CA
    i know....with stock uppers/lowers i had almost -3* camber .... atleast now its almost perfect..
  18. Feb 22, 2013 at 8:54 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    What do those run?
  19. Feb 22, 2013 at 10:40 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
  20. Feb 22, 2013 at 10:41 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
