Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 20, 2013 at 5:02 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
  2. Mar 20, 2013 at 5:09 PM
    BradyT88
    BradyT88 Well-Known Member
  3. Mar 20, 2013 at 5:10 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    :confused:
  4. Mar 20, 2013 at 5:13 PM
    Anthony250
    Anthony
    Rialto CA
  5. Mar 20, 2013 at 5:14 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    Hahahaha huh???
  6. Mar 20, 2013 at 5:14 PM
    BradyT88
    :rofl: So is there any difference between the ebay bypasses you posted and the bypass shocks you posted from poly? I am new to this long travel stuff and haven't put in my research yet... Basically is there a difference between a smooth body shock and a bypass shock? Does the bypass dampen more or less agressively or sooner or later than a smooth body? I was under the impression that ideally you want two shocks per wheel. A regular shock and a bypass. Is that close to true? haha
  7. Mar 20, 2013 at 5:17 PM
    Anthony250
    Anthony
    Rialto CA
    The ones on ebay are used, the ones on poly are new. Bypass- bypasses same thing. Smooth body and bypasses are different as the bypasses as bypass external tubes that bypass the oil inside , but on those bypass tubes there is an adjustment for the person to tune them to whatever desired "stiffer , softer ,etc".
  8. Mar 20, 2013 at 5:24 PM
    BradyT88
    I see. Why would you want to bypass the oil though? Wouldn't that make the shock not dampen very well?
  9. Mar 20, 2013 at 5:26 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    To put it simply, it allows you to have different valving at different points through the travel. When the oil "bypasses", it blows through a specific tube that has an easily adjustable valve on it. Bypasses can be on compression or rebound side of things.
    It makes tuning easier and allows you to have a softer ride during your first few inches of shock travel and to stiffen it up as you move through the shock's stroke.
  10. Mar 20, 2013 at 5:27 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Bypasses are position sensitive.
    Allows you to have have less dampening through the chop so it's not so bumpy and more dampening for the big hits.
    And with leaf springs, you want the leafs to drop out as fast as possible, even with a light valve stack that's difficult due to the natural dampening of leaf bushings. Rebound bypasses allow the axle to drop out much cleaner.
  11. Mar 20, 2013 at 5:28 PM
    Anthony250
    Anthony
    Rialto CA
    So you can adjust the flow, like on the tubes for rebound, adjust one way and you get faster rebound and opposite for the other way, same thing with compression adjust one way and it will make the shock stiffer, and likewise for softness. Now this is greatly an advantage over smooth bodies shocks as those have no external adjustment and any change of the shock you would have to open them up and play with the valving. Now do you really want to go out offroading and decide you want your shocks stiffer. Then have to take off your shocks ,take them apart ,have all the correct tools and put them back toghether? Or Would you rather get pretty much two tools out and adjust the shock and hop back in the truck and be on your way! haha.
    This is a quick easy way to sum it up.
  12. Mar 20, 2013 at 5:34 PM
    BradyT88
    Wow! Lots of answers. haha. Thanks guys!
    That is genius how they work!
  13. Mar 20, 2013 at 5:52 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    It is, but not very many people know how to tune them properly, they just turn tubes and call them good.
  14. Mar 20, 2013 at 5:58 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    What about smoothies with compression adjusters on them lol...would that be about the same?
  15. Mar 20, 2013 at 6:12 PM
    BradyT88
    From what I gathered, smoothies would have the same amount of compression throughout the entire stroke while bypasses can have really light compression for the first few inches then a little heavier for the next few inches and then maybe light again for a couple and then the last few inches are really heavy. Or however else you would like to tune them and depending on how many bypasses they have.
  16. Mar 20, 2013 at 6:13 PM
    VolcomTacoma
    Jeff
    NorCal
  17. Mar 20, 2013 at 8:05 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    unsubbed
    (no longer an owner of a LT Tacoma)
  18. Mar 20, 2013 at 8:07 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    oh dang, he sold the truck! congrats!
  19. Mar 20, 2013 at 8:07 PM
    BradyT88
    Was I wrong? haha I get the idea you already knew the answer though...
  20. Mar 20, 2013 at 8:09 PM
    VolcomTacoma
    Jeff
    NorCal
    No, I'm just kicking myself for buying smoothies now :D
