Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 20, 2013 at 11:59 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    what are you moving onto now?
  2. Mar 21, 2013 at 12:01 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
  3. Mar 21, 2013 at 7:25 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    If you find out let me know, mine is 13.5".
    Guess that's why "up to" was used:
    "The system is capable of achieving up to 15” of vertical wheel travel"
  4. Mar 21, 2013 at 8:02 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Correct me if I'm wrong please, but aren't linked vehicles illegal on the road?
  5. Mar 21, 2013 at 8:06 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You're the 4th person i know that cant get more than 13.5...im interested to see what defined says.
    He told me he has never seen anyone with less than 14.5
  6. Mar 21, 2013 at 8:10 AM
    BradyT88
    BradyT88 Well-Known Member
    Well that is disappointing... although I only have like 8" of travel right now so I would be happy with that.
  7. Mar 21, 2013 at 8:16 AM
    VolcomTacoma
    Jeff
    NorCal
    What other premade kits such as defined are on the market right now?
  8. Mar 21, 2013 at 8:18 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    ouch, my 5lugs getting 13" with just a custom alcan. it goes to 14-15" but the leafs separate a lot.
  9. Mar 21, 2013 at 8:18 AM
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
    You are wrong, many stock vehicles come from the factory linked. 1 for example, toyota 4 runner.
  10. Mar 21, 2013 at 8:20 AM
    BradyT88
    Giant Motorsports makes one, but it isn't as bolt on as Defined's.
  11. Mar 21, 2013 at 8:20 AM
    esbyota
    B-Rad
    AZ
    05 4x4 Taco
    I'd be willing to be if you stepped down on the axle it would get a little more travel. If you were to jump it without limit straps in the rear you would have inertia, tires, and shocks pulling the leafs down. Right now you have an arced spring sitting at a static position...
  12. Mar 21, 2013 at 8:21 AM
    BradyT88
    I hope you have replace your brake lines since this pic. haha
  13. Mar 21, 2013 at 8:22 AM
    disc0monkey
    yeah, now i need straps tho. haha
    leaf separation at full droop
  14. Mar 21, 2013 at 8:23 AM
    VolcomTacoma
    Jeff
    NorCal
    Hmmmmm that makes alot of sense. If anything...strap it out to 14.5 so the leafs don't get messed up...or strap to 15" if Defined took into account the full 15" of travel. Interesting. Maaaaaaan I need to hurry up and start my new job so I can pay off the truck and get my 4x4!!
  15. Mar 21, 2013 at 8:23 AM
    esbyota
    B-Rad
    AZ
    05 4x4 Taco
    Links look great! I would try and put two bends in the lower plate. More ground clearance at bump, even 1/2" is alot when rocks are everywhere and welding up new links SUCKS!
  16. Mar 21, 2013 at 8:30 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Did you put a slip yoke in your driveshaft? If not, any chance that's binding?
    Run thru the same droop exercise with the ds unbolted and two of your buddies standing on each side of the axle at droop.
  17. Mar 21, 2013 at 8:34 AM
    esbyota
    B-Rad
    AZ
    05 4x4 Taco
    Don't think thats the problem. Either has a slip joke or it slips in the tranny and once it goes past the splines it will fall out on the ground...
  18. Mar 21, 2013 at 8:41 AM
    anthony250f
    Anthony
    San Diego, CA
    I do have a slip yoke.
  19. Mar 21, 2013 at 8:50 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    We're not linked.
    My ds gets shorter as I droop till my leafs splay out. Once you go past a certain point then yes, it starts extending again...but again, not linked so that doesn't happen.
  20. Mar 21, 2013 at 10:04 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Leafs have a S shaped pattern.... Just another reason why they suck :D
