Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 21, 2013 at 10:06 AM
    rcfreak201
    rcfreak201 Well-Known Member
    Hey Anthony I responded to you in my build thread but I'm not at 15" either, I'm right under 14" according to SickNick.
    On a side note you and Matt should check out your hangers, mine are slightly starting to crack. Not a defined flaw but just something to look out for since they're stock..I'll get a picture up in a few minutes.
    And my shackle rubs the frame from flexing, I can see the marks.
    Am I the only one with issues or is nobody saying anything..? I don't wanna start something again..lol.
  2. Mar 21, 2013 at 10:11 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    shoulda got the shackle brace haha i wonder how to have a whole inch more travel than me?...same kit....
  3. Mar 21, 2013 at 10:19 AM
    anthony250f
    Anthony
    San Diego, CA
    no rubbing and no cracks...... (yet)
  4. Mar 21, 2013 at 10:21 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Thank you. I like that 2 bend idea! As of now I've got 6 1/4" clearance from center line to lowest point.
    Is this Mike from ESB?
  5. Mar 21, 2013 at 10:38 AM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    haha no that's brad
  6. Mar 21, 2013 at 10:53 AM
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
    What this tool said!
    What leaf pack is defined using?
  7. Mar 21, 2013 at 10:54 AM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    Some custom deaver pack
  8. Mar 21, 2013 at 12:12 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Ppsshhh, brake lines are the new limit straps
  9. Mar 21, 2013 at 1:03 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    have you checked all the bolts and bushings adn retorqued everything? i re-torqued everything and checked bushing because im having the same issue with my shackles rubbing on the frame, bit its hardly noticeable.
  10. Mar 21, 2013 at 3:21 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    It's most likely bushing deformation/deflection. The simplest fix would be to get some Delrin Bushing made up for your shackle pivot points :cool:
  11. Mar 21, 2013 at 3:33 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    text'd you
  12. Mar 21, 2013 at 3:35 PM
    theduck911
    Max
    Locked and Geared!
    So you have to quote him to let him know about a text that you sent him :p
  13. Mar 21, 2013 at 3:39 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    If you knew Brians texting habits you'd understand :p
  14. Mar 21, 2013 at 3:45 PM
    anthony250f
    Anthony
    San Diego, CA
    he seems to be more a facebook person lol
  15. Mar 21, 2013 at 3:50 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    says the person who replies to my texts by facebooking me :rolleyes:
  16. Mar 21, 2013 at 3:53 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  17. Mar 21, 2013 at 3:54 PM
    theduck911
    Max
    Locked and Geared!
    There's a topic to this thread :confused:
  18. Mar 21, 2013 at 3:58 PM
    anthony250f
    Anthony
    San Diego, CA
    :cool:
  19. Mar 21, 2013 at 4:26 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Sure, it's BS...:)
  20. Mar 21, 2013 at 6:51 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Anyone in here go from expos to the defined kit?
