Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 26, 2013 at 1:57 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    X2 aftermarket spindles have a way of doing that
  2. Mar 26, 2013 at 1:59 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    Red thread lock will take care of that.
  3. Mar 26, 2013 at 2:27 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Lol takes an act of god to get them off tho!
  4. Mar 26, 2013 at 2:36 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Just an impact if you only use a drop. An impact and a torch if you use to much.
  5. Mar 26, 2013 at 2:37 PM
    kcbmx
    Marco
    2tr-fe 4wd
    Small torch does the job. I did this when changing the rod ends on my coilovers and it worked like a charm.
  6. Mar 26, 2013 at 2:45 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Don't have a torch...prob why I've struggled, harbor freight for next job!
  7. Mar 26, 2013 at 2:55 PM
    kcbmx
    Marco
    2tr-fe 4wd
    Get yourself a portable Mapp gas toch, it goes along way and they are super cheap at lowes.
  8. Mar 26, 2013 at 2:58 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    I love mine! Work great in sand!!!
    My bfg at are snowflake rated. U need to get below E load rating or they are not snow rated. Just FYI.
  9. Mar 26, 2013 at 3:05 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Ok cool, thanks man. I'm gonna give them a shot
  10. Mar 26, 2013 at 7:08 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Race dezert or dezert rangers may have some up
  11. Mar 26, 2013 at 7:47 PM
    kcbmx
    Marco
    2tr-fe 4wd
    What kit are you going with? 8" coilovers vary with kits. Camburg and Chaos use a short body 8" that is more like a 7". Even if they do work, rod ends are longer with coilovers used in those kits to clear cv's.
  12. Mar 26, 2013 at 8:08 PM
    kcbmx
    Marco
    2tr-fe 4wd
    One benefit of running standard 8s is the larger resi. They are 2x as big. More oil better? makes sense.
  13. Mar 26, 2013 at 8:11 PM
    rcfreak201
    rcfreak201 Well-Known Member
    Hey guys this hanger snapped off my exhaust leaving a hole in it, can it just be cleaned and re-welded or do I need new tubing?
  14. Mar 26, 2013 at 8:14 PM
    Emtmeyer
    Emtmeyer Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Bondo ftw!
  15. Mar 26, 2013 at 8:16 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    JB weld....
    Take it to a exhaust shop if you can't weld if yourself
  16. Mar 26, 2013 at 8:18 PM
    FBGW01
    FBGW01 Well-Known Member
    Kaleb
    East Mesa AZ
    check my build
    I'd rub all that mud/dirt off if not grind it off and weld it back up
  17. Mar 26, 2013 at 8:24 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    URD Y-Pipe time, to match those sexy headers you'll be running. :cool:
  18. Mar 26, 2013 at 8:27 PM
    rcfreak201
    Hahah I knew you would say that once you saw the spot that broke:p
    Btw I'm heading down to the shop this week to pickup my stock headers so I'll see if he has anymore info on the release date.
  19. Mar 26, 2013 at 8:38 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Mine broke off in the same spot. Had them weld a plate on then the hanger. My pipes look the exact same as yours..... ceramic coating lol
  20. Mar 26, 2013 at 8:48 PM
    theduck911
    Max
    Locked and Geared!
    Do it do it do it! :cool:
    Get V-Bands welded in there too, all stainless and have a beauty system end to end!
