Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 14, 2013 at 1:07 AM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    I don't know why it wouldn't ??
  2. Apr 14, 2013 at 1:34 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    well, it will if you have an arm with load....
  3. Apr 14, 2013 at 9:20 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    hopefully in the next 2 months i'll start working on a mini buggy/offroad go cart.
    heres a link to the plans: http://www.sadik.net/gokart/
    on the A-arms, do i want to make the top arm a little shorter? if so how much shorter? 1/2-1''?
    suspension wise i think i'll do CO's on the front and back, the engine will be front mounted, for now i'm using a mower engine and tranny, the tranny has hi and lo range, each with 6 gears and reverse.
  4. Apr 14, 2013 at 1:13 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    if the arms are equal length, then there will be zero camber change through the suspension cycle, which some dont 100% prefer. I've talked to some people who do want a little negative camber on droop and bump for handling purposes. How much shorter you want the upper arm to be compared to the lower are is up to you, and you can experiment by cycling and measuring camber change.
  5. Apr 14, 2013 at 1:47 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Unless they actually turned and moved...no.
  6. Apr 14, 2013 at 4:19 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Actually if the upper and lower are the same length it will have crazy amounts of camber change
  7. Apr 14, 2013 at 4:57 PM
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
  8. Apr 14, 2013 at 6:10 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Not if the mounting points between the upper and lower arms have the same separation at both the frame and the spindle
  9. Apr 14, 2013 at 6:25 PM
    Supermoto
    Landon
    Fallbrook
    True if the were parallel it would have no camber change
  10. Apr 14, 2013 at 6:55 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Who was asking about cages with stock interiors?
    [​IMG][​IMG][​IMG]
  11. Apr 14, 2013 at 7:01 PM
    Supermoto
    Landon
    Fallbrook
    That looks really clean. Good work
  12. Apr 14, 2013 at 7:03 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    x2. Great work JD.
  13. Apr 14, 2013 at 7:04 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Thank you sirs :D
  14. Apr 14, 2013 at 7:32 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Awesome work JD! I'm super duper impressed! It'll feel so amazing in the dirt
  15. Apr 14, 2013 at 7:55 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Honestly, I don't understand leaving most of the stock interior seeing how its extra weight. I kept my dash, center console, speakers, and such but all the plastics and seat cushions aren't necessary, especially in a caged vehicle.
    The plastics are the biggest problem imo because after a while they start falling apart and making horrible rubbing noises.
    I'm not discrediting the work that was done on that particular truck.
  16. Apr 14, 2013 at 8:20 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Mostly for sound deadening because its my DD. When it gets loud I'll switch out to dyna mat or something but its not a race truck so I'm not too worried about the extra 20 or 30 pounds of plastic and carpet and headliner. I didn't put any of the metal parts, stock seat belts, or jack or any of that, so the plastic, headliner, and carpet isn't much extra weight
  17. Apr 14, 2013 at 9:41 PM
    95 taco
    95 taco Battle Born
    ok, thanks.
    so if i want the same geometry i'd build basically a spindle with the mount points the same distance apart as on the frame, then add lift to the spindle (move the part that the bearings and hub go on, down) to get extra ground clearance.
    x3
  18. Apr 15, 2013 at 8:08 AM
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
    Extra weight? HAHAHA. It's a desert truck, weight is the last thing to be worried about. Especially a negligable amount as stock plastic interior pieces...
  19. Apr 15, 2013 at 8:24 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Alright guys need some help, installed defined sua kit and loving it. except 2 things
    -Current shocks and hoops are way to long, i have like 3" of uptravel at ride height.
    -Ride height is a lot lower than expected even with the HD pack.
    Should i get a shorter shock to utilize my current shock hoops, or use what i have and re-build the hoops?
    Also what do you guys think of the engage spring hangers that will lower the spring, therefore raise the ride height?
  20. Apr 15, 2013 at 8:26 AM
    03aztaco
    03aztaco Well-Known Member
    adam
    lake havasu,mesa
    03 prerunner
    tc lt kit, king shocks, deavers, tc hangers,tc 12" shackels, king double bypasses, cab caged, beefed taco carrier bearing drop bracket, soild motor mounts,some more to lazy haha
